Old 06-27-2009, 12:33 PM   #1306
Magnet Top's Avatar
Originally Posted by bigb11 View Post
I have a 009 and want to race the 17.5 class. I have a 108 spur on it now, need help in finding a starting pinion size. I am using a SPX esc and Famton motor.
thanks
I am running a 104 spur ( 1.7 internal ratio ) and that seems to get me all the FDR's I need. I know you are asking for the pinion size... so read on....
Final drive ratio ( FDR ) depends on too many things to give you a good answer. Batteries, amount of drag brakes, *timing profile**, "physical" timing in your motor, last but not least *track layout* and just to throw a last curve ball, ambient temperature. It really is a moving target, if you just want to risk it and possibly overheat your new motor you can try something way below 5.0. I've run, with the same trinity duo motor, an FDR from 4.2 all the way to 5.0 using different timing profiles and drag brake settings etc ( all of the above factoring in ) using the tekin RS ESC and the LRP SPX ESC. Basically the FDR is wildly different considering all the variables stated above especially jumping from one ESC to the next and all the settings in between.
Given all that, if you want to start with something I'd say run timing profile 6 or 7 in SPX ( and little to no physical motor timing ) and with your Spur at 108 i'd run a 37 tooth pinion to start.
That would be a 4.96 FDR ( for a generic 17.5 motor ). Temp your motor after 2 -3 minutes and re-gear accordingly ( with a target of 160 degree motor temp ).
Goodluck !
Magnet Top is offline   Reply With Quote
Old 06-27-2009, 05:04 PM   #1307
rcterp's Avatar
Trader Rating: 35 (100%+)
thanks
I'm a little different in my gearing. I run 17.5 duo, asphalt, and SPX. At profile 8 I am around a 4.1. I've gone as low as 3.9 and as high as 4.25. My temps are never above ~140. I use a 98 tooth spur, I just think it fits a little better.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 06-27-2009, 09:13 PM   #1308
Magnet Top's Avatar
Old 06-29-2009, 12:08 PM   #1309
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Do the 008 aluminum shock bodies fit the rest of the shock parts that come with the 009? I need to replace a shock body and the aluminum 008 bodies are all I see on stormer. thanks.
Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-29-2009, 03:22 PM   #1310
Nexus Racing's Avatar
Cpt.
No. The aluminum bodies are for the aluminum shock set only. You need #308331.
There is no way to switch to aluminum bodies without purchasing the complete aluminum shock set, because the plastic shocks use different parts.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 06-29-2009, 05:45 PM   #1311
Super Moderator
Awesome, thanks for the info! love you guys at nexus... always helpin us racers out!
- RCSpecialties -
Old 06-29-2009, 05:53 PM   #1312
thisguy2849's Avatar
What battery do you run? I run the same set-up as you do but my ratio is around 4.75 due to the fact that best performance ive found on the duo is around 175 nd it can handle the higher temps
thisguy2849 is offline   Reply With Quote
Old 06-29-2009, 08:17 PM   #1313
rcterp's Avatar
SMC Lightning Volt (28C) soon to be C-Max. My laptimes are up there with the best of them at the track (off by a 1/10 or 2, but that's skill level). I've tested with higher ratios (above 4.5) but I still get the best giddy up around 4.1.
Φ
Old 06-29-2009, 09:47 PM   #1314
#88driver's Avatar
Is that battery fast charge capable? If not how many amps are you charging at?
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline   Reply With Quote
Old 06-30-2009, 05:50 AM   #1315
rcterp's Avatar
I charge at 1C, but Danny at SMC says all his batteries can be charged at 2C.
Φ
Old 06-30-2009, 05:30 PM   #1316
#88driver's Avatar
So it's probably safe to say it can be charged at least at 1.5C
Colton Jaynes
rchobbiesstore.com
Old 06-30-2009, 06:50 PM   #1317
rcterp's Avatar
Absolutely.
Φ
Old 06-30-2009, 08:14 PM   #1318
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default best lipo tray for 09
yep whats the best lipo tray for the 09 car and can i see some pics and price on them thanks for info
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 06-30-2009, 10:03 PM   #1319
J.Filipow's Avatar
Trader Rating: 15 (100%+)
My Xray 009 is featured on the cover of the August issue of XRC. I wrote the review on the car and did testing at the brand new OCRC carpet track in Huntington Beach, CA. Many thanks to the guys at XRC for putting a touring car on the cover!
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 06-30-2009, 11:17 PM   #1320
Wow, not a rock crawler or some other worthless POS.
And very Yummy
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
