Old 06-17-2009, 01:27 PM   #1246
Default Minimum weight
Are you guys in the USA, running all classes at 1500gms
as adding all the lead on Lipo's and Lipo trays makes car
look ugly.
In the UK we run a series 6.5T Lipo brushless at 1450gms.
Aslo the Ansman GP at West London will run 13.5T, 10.5T and
6.5T at 1400gms to see how the cars go.
The governing body BRCA are looking to lower weight limit
for all classes at AGM for next year.
Livingston is offline   Reply With Quote
Old 06-17-2009, 07:30 PM   #1247
hanulec's Avatar
Trader Rating: 27 (100%+)
look ugly.
generally people are running lipo plates w/ their 5000 mah lipo hanging off the side of the car and use small weights at the four corners for balance.
this year IIC 2009 (Vegas, baby!) is setting the min rubber weight to 1425. after installing a Tekin RS into my T2'008 I'm right at 1500 with a heavy weight body. i think a light weight body (minus ~20-25g) and the removal of most of my balance weight will bring my weight down.
how are you fitting your lipo pack into your xray? did you raise the height of your upper deck?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-18-2009, 07:23 AM   #1248
Trader Rating: 21 (100%+)
why is it that xray have a different multi diff between a 009/008 and t2/007 whats the difference? "can" i run a 007 multi-diff in a 008?
l337 is offline   Reply With Quote
Old 06-18-2009, 01:48 PM   #1249
lochness42's Avatar
Actually 008/009 has spool in kit not multi-diff. Reason was that almost noone runs oneway in front now and new composite spool is much lighter and usable for 10.5 and mod. Yes you can still use multidiff but I belive that you'll need to use some shims if I remember well. That's all.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 06-18-2009, 03:54 PM   #1250
so only difference is i need to space the 007 one?
http://www.amainhobbies.com/product_...Diff-T1FK05-T2
http://www.amainhobbies.com/product_...lti-Diff-T2008
Old 06-18-2009, 04:10 PM   #1251
lochness42's Avatar
yes if you're using smaller diff+spool puleys - 008 had also optional bigger puley included for mod racing. 009 had again only smaller one like 007.
Pavel Balint
Old 06-18-2009, 05:46 PM   #1252
Nexus Racing's Avatar
Pic of my XRAY T2'008/9:
Can't wait to try the new sorex SJ-R tires!
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 06-19-2009, 07:40 PM   #1253
Regional Moderator
daniz24's Avatar
for EU version with rubber tyres, which one is to buy :
Equalized Corner Speed (ECS) Drive Shaft 50mm - Hudy Spring Steel™
Equalized Corner Speed (ECS) Drive Shaft 52mm - Hudy Spring Steel™
daniz24 is offline   Reply With Quote
Old 06-19-2009, 09:25 PM   #1254
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
For rubber tire racing use the:
Make sure you take them apart and loctite them, otherwise you will have to replace a lot of pins
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 06-20-2009, 04:10 AM   #1255
Skiddins's Avatar
In the UK some guys have found it can vary from track to track;
It's pretty complicated. The 50mm driveshafts tend to make the car more responsive and free the car up mid corner and exit. The 52mm are less twitchy but they give the feeling of more traction mid corner and more forward traction.
It's very hard to explain, although generally the team use the shorter driveshafts outdoors, and longer ones on carpet.
Jonny
It's all down to personal preference really, but I suppose that's only viable if you've got two sets of driveshafts to test with!
What Jonny has said regarding the different handling traits between the two types is what most people deem the rule of thumb when choosing which length driveshaft to use. Personally I ignore the physics and just go on what feels best. These are the tracks I have used each type of driveshaft at, and I have also listed the event due to the grip levels usually being higher at the larger events, outdoor ones especially:
Short driveshafts:
Cotswolds National
Stonehaven, Muchmore GP
Maritime, Carpet Wars
Long driveshafts:
West London National & KOGP
Halifax National
Don Valley, BIWS
As you can see, there isn't much of a logical explanation to these choices. For example, Halifax is a high grip track so short driveshafts would seem the obvious choice, but I preferred to use the long driveshafts as I could be more aggressive into the corners with them!
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-20-2009, 06:41 AM   #1256
Regional Moderator
daniz24's Avatar
thanks guys, i think i'll go with 52
Old 06-20-2009, 12:03 PM   #1257
I have the top deck spaced 2mm.
Demon 5000 Lipo sitting in the slots and using tape to hold in.
All my balance weights on side of Lipo.
When we run at Ansman GP will have to loose the weight and
run the Lipo's hanging out of the side.
Will have to wait until XRAY bring out a Lipo chassis, pushing the Lipo
further out and forward to get the balance.
Old 06-21-2009, 04:50 AM   #1258
Skiddins's Avatar
Why forward?
Remember, you're trying to balance the motor at the back as well.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 06-21-2009, 09:46 AM   #1259
Send a message via Skype™ to JordanC
Hi All,
Has anyone weighed the Xray Lipo balancing set yet? I would like to know if they are designed for a car to weigh in at 1500 or 1425...
Thanks,
JordanC is offline   Reply With Quote
Old 06-21-2009, 04:44 PM   #1260
Skiddins's Avatar
Originally Posted by JordanC View Post
Hi All,
Thanks,
Each of the main brass weights is 30g, the two small 'L'l shaped bits are alu so they weigh a few gramms each.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
