Old 05-06-2009, 04:03 PM   #1006
any feedback on running the motor forward setup? thanks in advance
quinnfrazier is offline   Reply With Quote
Old 05-06-2009, 05:01 PM   #1007
Skiddins's Avatar
Originally Posted by rx7ttlm View Post
hey, after you guys get yours let me know how the car balances on the pins.
thanks
It doesn't.
I use balance buttons, but the extra 60g in the triangular bits is too close to the centre line to balance it all properly.
The black 'L' shaped bits are actually alu so they weigh about 7g together!
The advantage is that the two centre parts can both fit in two positions each, so weight can be put forward or backward in the chassis as desired.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-06-2009, 05:58 PM   #1008
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Downstops:
Any experienced asphault runners have a recommendation on where to set my front and rear downstops at for a medium traction asphault track? Right now I have them set at 5mm front and rear...
Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-06-2009, 06:02 PM   #1009
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I have my car set at 5mm front and 3mm rear, our track varies low-medium traction.
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 05-06-2009, 06:44 PM   #1010
JimmyMac's Avatar
My question, do you still need the lipo plates under the topdeck to run the XRay weights with a tall lipo like the TP5000 40C? Or can I take out the plates? Not sure if I want to go the XRay lipo weight set, as my car is pretty awesomely balanced as is.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-06-2009, 06:46 PM   #1011
JimmyMac's Avatar
Read back several pages. There is some input there.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-06-2009, 06:47 PM   #1012
JimmyMac's Avatar
Originally Posted by Cpt.America View Post
Downstops:
Cpt.
I always run mine at 6mm front and 5mm rear when running rubber tire.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-06-2009, 06:55 PM   #1013
Super Moderator
Im pretty sure the Xray weights move the batter out from underneith the top deck... Not a lot unlike the gold lipo tray I am using. I have the Xray weights on the way, and will be able to compare the two.
so 6mm-F 5mm-R ? That sounds a little more like it... wouldn't 3mm-R be a but too much roll in the rear?
- RCSpecialties -
Old 05-06-2009, 07:01 PM   #1014
JimmyMac's Avatar
It might make the rear over-rotate in the corner off-power. I pretty much use 6F/5R everywhere I go with rubber tire. Asphalt or carpet. If I do any changes to droop, it would only really be about 1mm +/-. But that's about it. I look to other areas for setup changes. Like shock angle or a spring change. Maybe a camber link change.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-06-2009, 07:30 PM   #1015
Super Moderator
Not droop... downstops. They aren't the same things.
- RCSpecialties -
Old 05-06-2009, 07:47 PM   #1016
Skiddins's Avatar
I have just tried the XRay weights in my 008 and the Thunder Power 5000 fits without any risers etc under the top deck...just.
There is about 0.5mm between the top deck and the lipo when lipo is right up against the inner weights.
If the Lipo packs didn't have a rounded edge they wouldn't fit!
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-06-2009, 07:49 PM   #1017
Skiddins's Avatar
I thought they were
What are downstops then?
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-06-2009, 08:51 PM   #1018
Super Moderator
Originally Posted by Skiddins View Post
I thought they were
They are related, but measued indipendantly. Downstops measures the MM difference between the chassis, and the lowest part of the lower control arm. Droop, is how far the chassis rises before the wheels lift off the ground. Ride height affects droop, but not your downstops.
For example, lets say you set your downstops to 5mm all around, but you run a REALLY high ride height. You might only have 1 mm of droop (1mm before the tires lift). In that case, you could have downstops set to 5mm, but 1mm of droop.
- RCSpecialties -
Old 05-06-2009, 08:58 PM   #1019
JimmyMac's Avatar
I see your point, but you only see one side of it. I use a Tamiya "Droop gauge" (AE, Yokomo, MM, many many companies make "droop" gauges too) and measure droop as you measure your downstops. They are one and the same. But there are many, many, many different ways to measure them, as well as different terms and how to use them.
So with that said... to translate my term droop to your term downstop.... I use 6F/5R downstop.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-06-2009, 09:54 PM   #1020
adamge's Avatar
Droop 4 life!
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
