Old 05-06-2009, 08:29 AM   #976
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by JamesReilly View Post
Actually with everything shortened up like that more then likely binding the pivot balls by the increased angle of the linkage, try putting a 1mm shim under the vertical pivot ball ( the one on the bell crank ).
This used to happen with the older xray cars as well.
The linkage doesn't bind in the slightest. The servo is infinitately hard to spin by hand even out of the car altogether.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-06-2009, 08:41 AM   #977
Trader Rating: 198 (100%+)
You can try loosening the servo case screws. It could be the case top cover is causing the binding issue.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 05-06-2009, 08:58 AM   #978
Super Moderator
Ok, Ill try that when I get home.
When the servo arm is still, it takes a TON of effort to get it to start spinning.. once it is moving, it seems almost normal, but still pretty stiff. The moment the momentum of the spin is over, it locks back down again.
- RCSpecialties -
Old 05-06-2009, 09:01 AM   #979
JimmyMac's Avatar
Looks like you have plenty of room to me. My layout is tight with motor fwd option. If you grab your tires and turn left to right by hand, it should turn smoothly with a 9551. As others have said, check your servo linkage to be sure it's not binding up.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-06-2009, 09:24 AM   #980
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Besercoe View Post
I have never seen that receiver before, is it much smaller?
Same size (unfortunately), but no antenna. Not available in the US (yet?), but works great with the US 4PK.
syndr0me is offline   Reply With Quote
Old 05-06-2009, 10:34 AM   #981
Johnny Wishbone's Avatar
Hey Captn America, just a observation, if you where to move your antenna mount ahead ever so slightly, you could tuck the reciever in more for a cleaner look. Just a suggestion.
Old 05-06-2009, 11:11 AM   #982
Skiddins's Avatar
Originally Posted by Cpt.America View Post
Ok... so, sorry for posting once again, but using BOTH forward servo holes (forward rear hole.. and one counter weight hole), I ended up with tons of room for my 603 receiver, and RS pro. I shorted the servo link arm up all the way to as short as it would go, and everything looks good. I have full servo throw both directions, looks smooth and nothing hits. Here is a PIC: Question... is the 9551 supposed to be so tough to manually turn? My normal crappy servos turn really easy.. this guy is SUPER HARD!
How long have you been using that servo in that position?
I don't fancy it's chances of surviving long with that angle on the servo mounting screw nearest the front of the chassis
Why don't you just turn the receiver on it's side so the plug holes face the back of the car?
Or you could try the 'flipped' drivetrain idea so the belts run the other around, the front belt would end up nearest the lipo while the rear belt would move to the radio side.
Skiddins
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-06-2009, 11:14 AM   #983
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
put the servo posts in the closer holes, and for gods sakes take the preload out of that servo ear!!! next, put two fingers on each tie rod like you were picking up a tooth pick. rotate each tie rod, they should be reasonably free. if one is exceptionally tight, replace the plastic ball cup.
cheers
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 05-06-2009, 11:19 AM   #984
RC MARKET's Avatar
use this weight balance !
RC MARKET is offline   Reply With Quote
Old 05-06-2009, 11:51 AM   #985
Super Moderator
It doesn't fit
There is no preload on the servo ear..its not being bent if that is what mean.
They are completely free.
- RCSpecialties -
Old 05-06-2009, 11:54 AM   #986
Super Moderator
...duplicate post...
- RCSpecialties -
Old 05-06-2009, 11:55 AM   #987
Super Moderator
???? why, what's wrong with the gold plate?
- RCSpecialties -
Old 05-06-2009, 01:04 PM   #988
LowBoost's Avatar
Trader Rating: 63 (100%+)
Has anyone tried the Rubber-Spec Conversion Set - 38T Pulley?
Any feedback?
Does the Lipo balancing chassis weight will fit with a Hyperdrive lipo tray?
Any pics (installed)?
Sorry for the newbie questions... just planning on getting back to sedan racing after 10 years. So much to catch-up. Will get a T2 '009 and I am just doing my homework about what I need to purchase.
I will be using SMC 5240 hardcase batteries. BTW what are your recommendations on servo?
LRP Comp TC esc, Tekin, other(s)? Brushless (open mod) motor (I need something in the 3x)?
LowBoost is offline   Reply With Quote
Old 05-06-2009, 01:26 PM   #989
revo523's Avatar
I dont think you can use the Hyperdrive lipo tray.
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 05-06-2009, 01:40 PM   #990
LowBoost's Avatar
Revo523:
Do you like how the battery sits with the lipo weight balance kit?
How would it compare with a Hyperdrive tray?
I am just debating which I should get. Does it help and make balancing the car easier, compensating for battery weight or it simply keeps the battery in place better?
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
