Old 05-02-2009, 07:34 PM   #946
JamesReilly's Avatar
Trader Rating: 58 (100%+)
Originally Posted by JoeGlover View Post
Just what do you think your doing in here Reilly!!
I don't know Joe I can't Xplain it? I must have gotten lost. How come you didn't make the Canadian challenge?
Reilly Paint ([email protected])
JamesReilly is offline   Reply With Quote
Old 05-02-2009, 07:36 PM   #947
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
James you lost again?
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 05-03-2009, 08:54 PM   #948
JimmyMac's Avatar
Ran the motor fwd today with the eccentric "1" bearing holder up front. Front belt tension was much better than before. Not running a bow string anymore. Running the eccentric "1" in the rear made the rear belt either a tad too tight, or too loose.
So far I like it.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-04-2009, 01:20 AM   #949
dawgmeat's Avatar
diff problem
Ran this past weekend outdoor rubber and at the end of the day I noticed that diff was binding a little got home took it apart both diff bearings are good diff screw seem to be straight so i put it back together agin without the diff balls tightened it down same problem.could it be the trust bearing because i dont have a snap ring toolthanks in advance
dawgmeat is offline   Reply With Quote
Old 05-04-2009, 04:39 AM   #950
miller tyme's Avatar
Originally Posted by dawgmeat View Post
diff problem
Diff builds don't last forever, the will get dust an crap in them. When you put it back together did you clean the balls, sand the ring face, put new diff lube in? If you did, then you likely have crap down in the thrust assembly. There are some fine round tip needle nose pliers that will work in place of snap ring pliers. Nexus even features such a pair in there Xray tips section.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 05-04-2009, 05:23 AM   #951
niznai's Avatar
diff problem
If you have one of those compasses they used in the old days when drafting was done manually, you can use that to take out the snap ring if you replace the lead with the spare needle point.
See here (second from bottom):
http://commons.wikimedia.org/wiki/File:Reisszeug_1.jpg
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-04-2009, 05:39 AM   #952
I just had too much going on and couldn't make it. would have been nice to race MOD rubber too
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 05-05-2009, 12:47 PM   #953
bigdadracing's Avatar
drew,
on your 13.5set up for novak how much up travel on your droop do you set on your car front/ rear thanks
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 05-05-2009, 06:20 PM   #954
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Servo problem:
So i just bought a brand new Futaba 9551 servo... but it doesn't fit in the car. The servo posts are about a millimiter to close together... can't even force it to go... Tips? tricks? did i get bunk holes in my chassis?
Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-05-2009, 06:28 PM   #955
revo523's Avatar
Originally Posted by Cpt.America View Post
Servo problem:
Cpt.
Did you try loosing the servo post screws? And then try to fit the servo.
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 05-05-2009, 06:30 PM   #956
Super Moderator
oh yeah, of course.... nowhere close... the physical case of the 9551 is too big.. or the holes in the chassis are too close together.
- RCSpecialties -
Old 05-05-2009, 06:39 PM   #957
revo523's Avatar
Can you measure the size of the servo with a digital caliper to compere it with mines.
Spektrum DX3S
Old 05-05-2009, 06:42 PM   #958
JimmyMac's Avatar
Servo problem:
Cpt.
No issues here. I run the same servo. You have to run the rearward servo holes.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-05-2009, 06:57 PM   #959
JimmyMac's Avatar
Here are pics....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-05-2009, 07:18 PM   #960
Super Moderator
HHmm.. I see. I have a stack of older airtronics servos, and old futaba servos. All the futaba servos (including my new 9551) are 1mm wider than the airtronics. All the airtronics fit in like a glove, and none of the futabas fit. Running that rear hole will leave me with not enough room to run my receiver and ESC... bummer!! Id almost rather grind down the inside of the posts..
Thanks for the help there, appreciate it.
Cpt.
- RCSpecialties -
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
