Old 04-30-2009, 07:44 AM   #931
JamesReilly's Avatar
Trader Rating: 58 (100%+)
One way spool, would be the same as running the multi-diff with the link bar in and the locking pin removed. Which is a nice option.
James
Reilly Paint ([email protected])
JamesReilly is offline   Reply With Quote
Old 04-30-2009, 08:51 AM   #932
miller tyme's Avatar
James
This option works great in the 007 for VTA
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 04-30-2009, 09:06 AM   #933
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Drew Ellis View Post
No problem..I'm going to try to stay more active on this thread to help out..So asking is the way to knowing...Drew
Staying active and starting to use some...punctuation now, too! Way to go!
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 04-30-2009, 09:15 AM   #934
revo523's Avatar
Im really bad with the punctuation. lol
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 04-30-2009, 09:38 AM   #935
The Evicerator
Default ECS Driveshaft Impressions
Just figured I'd chime in too on my opinion about the ECS shafts:
I have found that they do dramatically change the handling and steering characteristics of the car and are a great tuning option to have in your toolbox.
I found that when running the ECS shafts that direction/steering transistions in tight corners were much quicker and could be taken with more throttle input due to the reduced binding in the front end.
Also as a result of less bind in the front end was the fact that there is less "self braking" of the inside front wheel resulting in smoother radiused corners which can be a definate advantage in certain situations.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 04-30-2009, 10:30 AM   #936
Drew Ellis's Avatar
Originally Posted by bigdadracing View Post
drew i noticed that you suggest your nats setup for 13.5 .i was wondering how well it works on a medium bite track or what changes you would suggest thanks for any help!!!!!!!!!!!
That is what I run here at home on a medium bite track...I just sauce more front and make the camber link in the rear long on the hub....But try just sauceing more first and see.....Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 05-02-2009, 11:37 AM   #937
Azman Azam's Avatar
I'm having issue's of the black plastic spool drive cup breaking on me with the minute of brushes with the track dividers. Its coming up to double digits now to the amount of breakages I have.. Comments..
Azman Azam is offline   Reply With Quote
Old 05-02-2009, 12:35 PM   #938
Trader Rating: 198 (100%+)
You can try these,
http://www.teamxray.com/teamxray/pro...0Hard%20Coated
Also if you are hitting boards often then you will be breaking parts or bending parts. This will happen with any car.
Hope the info helps.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 05-02-2009, 01:47 PM   #939
mmario777's Avatar
You can also try this one -> http://www.rcatomic.com/atomic/index...emart&Itemid=1
They make them in aluminum or steel . Check on Ebay I think they was 13$
mmario777 is offline   Reply With Quote
Old 05-02-2009, 02:04 PM   #940
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Help with Springs:
So am running an out-of-the-box Eu 009, and want to spare part some extra suspension springs for tuning on the track. But, the "black" springs that come with the EU kit aren't even listed in the spring line-up. In the book that came with the car, Xray lists the following as possible springs:
14lb / Yellow / Super-Soft
15lb / Blue-Green
17.5lb / White / Soft
20lb / Light-Blue
22.5lb / Blue / Soft-Medium
25lb / Dark blue
28lb / Violet / Medum
30lb / Light-Purple
33lb / Purple / Medium-Hard
35lb / Light-Red
38lb / Red / Hard
They also list:
14lb Gold
17.5 Silver
They also list:
C=2.2
C=2.4
C=2.6
C=2.8
C=3.0
C=3.2
C=3.4
Soo... whats the delio? Where do the black fall in this painfully unintuitive thing they got going on here? Difference between pound ratings, and C ratings? Why two different kinds of ratings? Please help as I would like to have a set 1 step firmer, and 1 step softer than the factory blacks for fine tuning. Unless of course there is something else you can recommend altogether?
Thanks as usual.
Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-02-2009, 02:20 PM   #941
You will be fine with the black springs. 2.4,2.6,2.8, and 3.0 are all good rates to have. Most are not using the color springs with rubber tire. If you run foam you will want the colored springs
www.donatelife.net
Old 05-02-2009, 02:24 PM   #942
mmario777's Avatar
Hey Cpt. check out this chart , I hope it will help you
Old 05-02-2009, 02:30 PM   #943
Super Moderator
Mario, thanks, that helps a ton. Question, are the 2.4s and 2.6s different rates? I ask because they seemed to be grouped together. And why would you run only the blacks on asphault but colored on carpet, if their stiffnesses sort of run along the same lines as one-another? Are the blacks progressive but colored ones linear or something?
Thanks again
cpt.
- RCSpecialties -
Old 05-02-2009, 04:38 PM   #944
James
Just what do you think your doing in here Reilly!!
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 05-02-2009, 06:10 PM   #945
The only progressive springs Xray produces is the gold and silver from the T2 and the T2R Pro.
The reason I say to use the black springs is that you may want to use a Team driver set up or fellow racer set up. We are mostly using the black springs with the rubber tire cars now. The blacks do not go firm enough for foam. At least not for the front of a foam car
www.donatelife.net
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
