XRAY T2’009
#916
Thanks Drew.
#918
No problem..I'm going to try to stay more active on this thread to help out..So asking is the way to knowing...Drew
#919
Yes they are...The first time I ran them was at the Novak in rubber tire with a spool and I was like oh yeah...The car had more steering and felt easier to drive...It was way smooth...They are well worth the money...I am going to try them in my foam car with a diff because I like them so much...Drew
#921
They are designed to be used with a spool..They take out the chatter you get with the stock cvd when the tires turn...That really only happens with the spool because with the diff you get diff action...I just like them they are just so smooth its great...Drew
#922
Drew i have another question i have a EU009 and im running foams so i want to put the same springs colors that comes with the US009 so i tried some light purple and white from a set of xray springs i had from my 007 but i couldn't lower the car more then 6mm i check everything and i found that the old springs are longer then the ones that came with my kitany ideas to what i could do to fix this problem?
#923
To answer your question run a spool for sure...Thats the only thing I run on rubber tire asphalt..Drew
#924
#926
Well what i noticed was that the springs are longer. i compared the springs with the ones from my friends US009. What im trying to get to is that the old springs like the ones we were using on the 007 are longer compared to the 009. i hope you can understand me lol
#927
OK the shocks on my foam car are 63mm in the front and 64.5 mm in the rear...They have the short end links on them...The shock towers are the same...So check how long they are and look at you droop..Get your car to ride you said 6mm was all you can get, when the car is there back off the droop screws and check ride height if the car is over 6mm set your droop up again...Hope that made sense....Drew
#928
Oh OK but thats still not right I have springs from back in the day and they still work...Xray has not changed the colored springs at all...The black ones that come with the EU are different..But the colored ones are the same....Drew
#929
OH!!!! now i see thats the problem right there Thanks again Drew.
