Old 04-23-2009, 05:51 PM   #841
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by c1 racin View Post
Lets see .... What do you say are the best three TC ..... I'ld say these:
from NeXus Racing
XRAY T2'009 ~ $499.95 / $489.95 @ Stormer IN STOCK on BOTH SITES!!
from Speedtech
Tamiya TRF416 World's Edition ~ $489.99 / $599.99 @ Tower Hobbies OUT OF STOCK on BOTH SITES!
Hot Bodies Cyclone TC Competition ~ $389.99 / $419.99 @ Tower Hobbies OUT OF STOCK on BOTH SITES!
I get so tired of reading that ....
I was referring more to the price of the hudy tools than the cost of the car kit. Relax.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-23-2009, 07:10 PM   #842
revo523's Avatar
What will be a good starting point for gearing running a 13.5 with foams?
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 04-23-2009, 10:08 PM   #843
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hey guys, what do you think about adding a 1mm shim in between the composite steering and the servo steering arm? What do you think it will achieve?
Also can anyone recommend some stronger spur gears. In Mod am continually stripping them.
Thanks Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-23-2009, 10:17 PM   #844
adamge's Avatar
Between the knuckle and the steering linkage? It will achieve different bump steer dynamics.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 04-23-2009, 10:17 PM   #845
My t2 08 still serve me well but yeah my hands quite itchy these few days,duh..
sherr is offline   Reply With Quote
Old 04-23-2009, 10:25 PM   #846
Drew Ellis's Avatar
I like Xray's 104 spur that will work fine you will not need anything smaller...The biggest pinion you can fit is a 45 so your good....What size is the track and what kind of speedo are you running...That would make it easier...My gearing at the Roar carpet nats was 36/104 with a 56mm tire thats about a 35 to 36 mm rollout...The track was 94 feet long...I was running a KoPropo speedo, so you will probley need to gear higher then that...At the IIC last year I ran a Novak and my gearing was 43/104 thats a 42 to 43mm rollout on the same size track...So you see what the need to know what speedo you run is....Later Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 04-23-2009, 10:27 PM   #847
No not there i normally use a 1 mm shim for the bump steer. I am talking between the actual servo steering arm and the (302504-O - Xray Quick-Saver - Adjustable Servo Saver Set) .
Hope that makes more sense
Antoni Caretti
Old 04-23-2009, 10:31 PM   #848
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Thanks Antoni
Are you running indoor or outdoor? Parking lot or permanent track? 48 pitch or 64 pitch?
I ask because these kinds of factors could contribute to your problems. If you're running 64 pitch, on an outdoor, temporary parking lot track, with a 4.5 brushless, chances are that you're gonna have some problems. Especially if you don't perfectly set your gear mesh...An alternative to the molded XRay spur gears are the offset RW spur gears. They are machine cut (as opposed to molded), so they run a little truer. And, IMO, the plastic is stronger.
Another thing to check is your bulkhead, where the motor mounts. If your screws have gotten loose, or if one screw is missing, that could be causing a little flex under power, thus always altering your gear mesh. I would also suggest using good quality motor mounting screws, and be sure they are TIGHT.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 04-23-2009, 11:06 PM   #849
revo523's Avatar
Im running the LRP Sphere Comp with a novak 13.5 and the track is 70x35
Spektrum DX3S
Old 04-23-2009, 11:10 PM   #850
Ok thanks i will check that all out.
I run a 4.0 with lipo on a large outdoor track with 64pitch. I switched back to 48 pitch for a race meeting but i found the car didnt have the punch that it had with the 64p.
Anyone know about my other Question?
Thanks for your help,
Antoni
Antoni Caretti
Old 04-23-2009, 11:59 PM   #851
Drew Ellis's Avatar
Cool, what size tire do you plan on running thats a big part too...We run them small at a big race but at a club race you can run bigger....Your rollout shoud be around a 38mm to 40mm...So thats a 38 to 40 pinion with a 56mm tire....Later Drew
Old 04-24-2009, 03:58 AM   #852
dawgmeat's Avatar
any real ideas on how to fix the belt issue being way to tight with the fwd motor conversion
dawgmeat is offline   Reply With Quote
Old 04-24-2009, 07:41 AM   #853
mickrcarver's Avatar
Trader Rating: 98 (99%+)
302077 ecc. holders, www.nexusracing.com
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 04-24-2009, 08:32 AM   #854
revo523's Avatar
I wasn't planing on cutting my tires since its just some club races, what do you think? if i dont cut them can i run the same gearing or do i have to go a tooth or two smaller on the pinion?
Spektrum DX3S
Old 04-24-2009, 08:46 AM   #855
Super Moderator
Bumps or no bumps? I am getting ready to pull the trigger on my lipos, and will probably run the new battery weights coming out from Xray. Do you recommend getting hard packs that have the chassis bumps or would you recommend flat bottom? Im considering the Reedy 5000 35cs, flat bottom.
- RCSpecialties -
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
