Old 04-19-2009, 10:40 PM   #796
JimmyMac's Avatar
Are you in a rush not to wait on Nexus to be back up? If so, just order from RCAmerica.... of course, it may be quicker to wait for Nexus to be back up and running.......
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-19-2009, 11:18 PM   #797
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Originally Posted by tofuburger View Post
who has the new front axles in the US? nexus hobbies web page is down.
http://www.amainhobbies.com/index.php/cPath/1_25_1075
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 04-20-2009, 06:52 AM   #798
Default Spur Gear question
Im running the T2 009 EU which comes with a 84 tooth 48 pitch spur, now I run 13.5 and with this spur I wont be able to fit the right gearing on so will need a 80 tooth spur. Looking through my xray parts list most the xray spur gears are off set ?? but the one that came with the kit isnt. Not sure what off set does and do I need it. Are the RW spurs gears any good as they make some to fit the T2 009
FLAT OUT is offline   Reply With Quote
Old 04-20-2009, 07:06 AM   #799
rockstar81's Avatar
Just wanted a comparasin from people that have ran both T2 009 and the FK 05. Likes and dislikes?
Dee & Mee Hobbies, Team Academy SBV2, Xray 009, Xray 007, Castle Creations, Spektrum DX3R, Ricky Racer Customz, Tekin, Thunder Power, Duratrax Onyx,
rockstar81 is offline   Reply With Quote
Old 04-20-2009, 08:07 AM   #800
pcar951's Avatar
Trader Rating: 19 (100%+)
Yes, you should be using an offset spur, don't know why your kit came without. The RW stuff is good.
4 years of development advances things a lot. The 009 is light years ahead of the FK05, although the FK05 was a very good car in it's time.
pcar951 is offline   Reply With Quote
Old 04-20-2009, 10:49 AM   #801
rockstar81's Avatar
Any more direct comparasin, I understand it is newer. Looking more for specific advantages.
Old 04-20-2009, 11:08 AM   #802
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
well from the 05 to the 007, the suspension geometry changed making the car faster but at the same time more consistent / drivable. ....
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-20-2009, 03:28 PM   #803
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey JimmyMac,
I had the same problem to. I even set the the tension to the loosest setting 's and it was to tight. Next Time I race Im going to take out the 38 pullies and put the 34 pullies back in. That should cure the belts being to tight, and bring the ratio back to 1.70 instead of 1.90.
Hope this helps
Originally Posted by JimmyMac View Post
I ran the forward motor position today in 17.5. But it was on low/medium bite asphalt. Seemed to give pretty good on-power steering. Only problem I have with the kit is how tight the belts are. Even with the "loosest" setting, the belts are fairly tight. Anyone else have this problem?
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 04-20-2009, 03:30 PM   #804
rx7ttlm's Avatar
Originally Posted by mike ivy View Post
Hey JimmyMac,
Hope this helps
there is another alternate notch where the top plate bolts to the bulkhead you can put the adjuster there for extreme loose or tight belts.
cheers
Old 04-20-2009, 04:51 PM   #805
JimmyMac's Avatar
cheers
Doesn't work. Still too tight.
I'm thinking eccentric bearing holders might do the trick.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-20-2009, 05:03 PM   #806
JimmyMac's Avatar
Or am I thinking of something different.... I thought there was a different set of eccentric hubs for the bearings....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-20-2009, 05:06 PM   #807
rx7ttlm's Avatar
there is a different offset, I don't know if that would work tho.
Old 04-20-2009, 05:06 PM   #808
JimmyMac's Avatar
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-20-2009, 09:14 PM   #809
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
So i was looking over my xray tonight, just trying to plan out how I am going to lay out my electronics... and I found a question. Does anybody ever mount their receicer... standing on its side, in FRONT of the battery? A typical micro receiver, standing on its side clears both the little slot for battery tape, and the steering assembly / tire. It would seem to me a decent way to get a more natural balance out of the car.
Is this a good idea? bad idea? something I am not thinking of?
Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-20-2009, 09:26 PM   #810
mike ivy's Avatar
Hey Guys I tried the car with the 34t pulleys no go.... the belts where way too loose Lol... Im thinking of either getting a 18t center pulley just to ease some of the tension. But it will change the ratio to a 2.11. That might work for now.
Im going to look at other tour cars and try there belts, maybe a Associated or a Yokomo belts and see how they work. maybe they wont be as tight. All Xray has to do is redo there belts for this up grade or redo there pulleys.
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
