Old 04-18-2009, 08:27 PM   #781
RFALLON's Avatar
Send a message via AIM to RFALLON
Originally Posted by mickrcarver View Post
why the rear belt? does the rubber chassis move the bulkheads? oh and what is the difference in the chassis for the 008 and 009 rubber car?
i dont get the rear belt question. The rubber chassis you can move the bulkheads back and forth, and the battery is moved a little further out from the spur gear on the 009 and it has the xtra screw holes for moving the bulkheads back and forth.
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
RFALLON is offline   Reply With Quote
Old 04-18-2009, 08:35 PM   #782
Has anyone tried the forward motor conversion on high bite asphalt? I'm thinking of buying a second car with conversion to see if it'll work for either 17.5 or 13.5
M3dreamin2008 is offline   Reply With Quote
Old 04-18-2009, 09:27 PM   #783
JimmyMac's Avatar
I ran the forward motor position today in 17.5. But it was on low/medium bite asphalt. Seemed to give pretty good on-power steering. Only problem I have with the kit is how tight the belts are. Even with the "loosest" setting, the belts are fairly tight. Anyone else have this problem?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-18-2009, 10:46 PM   #784
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
What the rear end grip like? (with and without the fwd motor kit installed)
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 04-18-2009, 11:07 PM   #785
JimmyMac's Avatar
With Sorex 36R Speedmind premounts, it was a hair loose if you stayed on the brake too long or too quick, but it was very controllable. With Jaco Blues, it was total a$$. You lost almost a second a lap with Jaco Blues. I think before, last week (without motor fwd), the rear end was not as loose. More controllable. I think due to more weight on the rear. Now my car is pretty close to 50/50 f/r weight distro. However, for the main, I went with a softer rear spring which planted the rear better. It actually developed a slight push which let me be more aggressive on the drag brake into the turn.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-19-2009, 12:53 AM   #786
dawgmeat's Avatar
is the FDR still 1.7 with fwd conversion
dawgmeat is offline   Reply With Quote
Old 04-19-2009, 06:20 AM   #787
Default T2 009 eu shock question
Im from the UK and racing 13.5 on mostly large out door tracks on rubber tyres, Im close to finishing the build of my 009 and would like some imput from every one if I should build the shocks with adjustable pistons or non adjustable ???
FLAT OUT is offline   Reply With Quote
Old 04-19-2009, 10:29 AM   #788
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
FWD conversion? you mean the forward motor mount conversion? I believe it goes to 1.9.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-19-2009, 10:53 AM   #789
J.Filipow's Avatar
Trader Rating: 15 (100%+)
can someone tell me exactly what i need to covert 008 us foam to eu rubber car?
US Foam edition has XH arms, caster blocks and rear hubs; shorter driveshafts as well as a thicker chassis and top deck. To make it EU 009 specs, you'd technically need arms, caster blocks, rear hubs, chassis, top deck, 34T spool, 52 mm driveshafts (aluminum for the rear), stub axles, softer springs...it's actually a pretty extensive list. You might be better off selling the US 008 foam edition and buying a new EU 009.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 04-19-2009, 11:03 AM   #790
J.Filipow's Avatar
The changes I had to make to get Jaco Blues to work well at my local track (BCR in Orange, CA)was to add some more rear toe (from 2.5 to 3), add more rear camber (from 1.5 to 2.0) and add some more rear camber gain. I also moved the rear arms from fully rear position forward 2 mm. This definitely gave the car more equalized F/R balance.
The Jaco Blues certainly couldn't match the fastest lap times of our 'standard' tire at the track (Sorex 36), but by the end of the day, my stuff was pretty close with the Jaco Blues. Track temp was fairly high (120 degrees), and the Jaco Blues finished 6 minute runs about 10 degrees hotter than the Sorex 36 tire. So far, the only 'advantages' to the Jaco's is that there is less performance fall off from run to run, and they are less expensive (and more 'convenient') than the Sorex 36's.
Old 04-19-2009, 11:05 AM   #791
J.Filipow's Avatar
I believe it is still 1.7 with the FWD conversion; provided you use the enclosed 38T pulleys with the 20T layshaft pulley (and NOT the 16T layshaft pulley).
Old 04-19-2009, 11:07 AM   #792
J.Filipow's Avatar
I would recommend (and I personally prefer) the fixed pistons. I think they're more consistent and won't be prone to unequal and unintentional, mismatched settings. Maybe start with the 3 hole piston (3 open, 1 closed).
Old 04-19-2009, 11:37 AM   #793
ottoman's Avatar
R/C Tech Charter Subscriber
I loved the adj pistons. Most guys never learn how much a small piston hole size can change how your car handles. With the adj pistons you can make a quick change while everyone else puts off piston changes because its too much work.
I even ran XRay shocks on my Corally just for the adj pistons.
ottoman is offline   Reply With Quote
Old 04-19-2009, 08:17 PM   #794
JimmyMac's Avatar
The new 09EU/T2R forward motor mount kit comes with 38 tooth pulleys and belts to fit them. The new FDR is 1.9.
Jaco Blues still suck! haha. Can't give them away around here! My old worn out Sorex 36R tires with patches showing through were about .5 sec per lap faster than the Jaco Blues with no setup change. New Sorex 36R was about .7 sec per lap faster. Track temp 112. I have a lot of camber gain and already running 3 rear toe. Jaco Greens are much better than Blues. But anyways, I always run Sorex, as I've done for years. Just thought I'd try out the Jaco's for the 3rd qualifier yesterday. Won't do that again.
Anyways, ran the 09EU with forward motor kit again today on a different track than yesterday. It ran pretty good. But the belts are still tight. Anyone else have this issue?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-19-2009, 10:33 PM   #795
tofuburger's Avatar
who has the new front axles in the US? nexus hobbies web page is down.
Larry "Chef LT" Tom
StickIt1Racing.com
HobbyAction.com
tofuburger is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
