Old 04-10-2009, 01:48 AM   #691
lochness42's Avatar
Originally Posted by okayplayer View Post
hey,
I'm running a t2 009 eu specs with fixed diff on the front. My club track has a huge "parabol" after the straight line so we're going full speed on the parabol.
Problem is that with the fixed diff, has one wheel / shaft is rotating at a lower speed due to the parabol... one of the wheel hudy shaft is bending, "swirling"... I assume only solution is to remove the fixed differential and replace it with the same differential that I've on the rear.
The consequence of this bended shaft is that it's "OK" for having fun .. but when you turn, it makes a vibration on the wheel ... and that's quite undriveable at high speed
Weird !
Cédric
Hi, I'm running same config in my 008 for mod - graphite grease has to help with those vibrations - but not completely - there is another solution for this - ECS shafts - it really does work. I've got them on my 009. However, I haven't bent even one standart shaft for whole time I'm running 008 car.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 04-10-2009, 01:56 AM   #692
okayplayer
Guest
Posts: n/a
Thanks for the reply.
I've got both choice
- Remove the solid axle diff and put the same differencial that I've on the read
- Keep the solide axle diff and use the ECS shafts.
Price is close to be the same
Cédric
Old 04-10-2009, 02:58 AM   #693
Cédric
Hi Cédric,
I would keep the solid axle and use the ECS drive shaft
Ralf is offline   Reply With Quote
Old 04-10-2009, 03:03 AM   #694
okayplayer
Guest
Posts: n/a
Thanks a lot for your help - I will do so
Cédric
Old 04-10-2009, 05:05 AM   #695
Skiddins's Avatar
Originally Posted by Cpt.America View Post
Yep, I found it, but it had nothing to do with with 180 degrees it went in. The HUDY graphite grease that comes with the kit... which the manual says to use on the outside of the little coupler cylinder... tured into like a glue. The cylynder would NOT spin in the dogbone... heck, I could BARELY press it back out. Once I got it out... cleaned the cylnder and inside of the dog bone out of all the dried graphite grease... it now moves free as butter.
Shame on you, HUDY graphite grease!!! it dries right to a glue.
Must be some duff stuff!
Get some graphite grease from the model shop as it will help prevent a lot of wear in the driveshafts.
Also, be carefull about the amount of tension you put on the grub screw for the pin, too much and it can bend the pin slightly causing problems.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-10-2009, 05:13 AM   #696
Skiddins's Avatar
hey,
Weird !
Cédric
Hi Cedric, do you have link to some pictures of the track?
We have a variety of tracks here in the UK that the top guys run on, most of which have what we call 'sweepers' (long fast corners at the end of straights that are entered flat out), but all the top drivers use spools (fixed diff).
Although the inside wheel normally vibrates we never notice it on the track.
How much steering lock are you using?
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-10-2009, 08:50 AM   #697
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by lochness42 View Post
Strange - I never had problems with graphite grease. It works for me very good everytime. I have problems when I forget put it in - there is more stress on axle. I deffo advice to use graphite grease - maybe you got bad batch of graphite grease?!
Grease is supposed to stay soft.. like grease, right? Well the HUDY graphite grease that came with both of our cars, dries right up like a glue after 5 or 10 minutes. Know the little coupler guy? Well.. I even had a hard time pressing it back out. When I build it without grease, the drive shafts are smooth as butter.
So the steering problem, was when both driveshafts were in teh same position, and turning the front wheels had to rotate the couplers on both corners are the same time. The steering was so stiff that I could barely rotate it with my hand (no servo in the car at the moment).
So... should I use the white differentail grease instead, or buy different graphite grease online? THanks
Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-10-2009, 09:52 AM   #698
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Cpt.
When applied, what color is the grease that came with your kit? Red, Black, White, or Blue?
ChristopherKee is offline   Reply With Quote
Old 04-10-2009, 10:03 AM   #699
Super Moderator
black... with maybe a TINY hint of purple
- RCSpecialties -
Old 04-10-2009, 01:10 PM   #700
You should always grease your driveshafts. Try Muchmore joint grease.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 04-10-2009, 02:28 PM   #701
lochness42's Avatar
Really strange Graphite grease that came with my both cars were fine. Even after more than year it's smooth and soft. I haven't noticed any drying so quickly and causing binding. My shafts are always smooth.
Pavel Balint
Old 04-10-2009, 03:35 PM   #702
Super Moderator
Is there another aftermarket graphite grease you can recommend me? I obviously got some bunk grease.
- RCSpecialties -
Old 04-10-2009, 07:55 PM   #703
Super Moderator
I have some noob questions for you guys, I hope you don't mind.
1.) The "internal drive ratio" of the 009 is 1.7?
2.) That comes from deviding the size of the front/rear pullies, by the size of the central pullies? (20/34).
3.) So running the stock spur of 84 teeth, what is a good starting point for my overall gear ratio for a medium sized asphault track, running a 17.5bl?
4.) Do guys shoot for something like 5.0? 4.0?
5.) Is "rollout" all that important in rubber TC? (i think i read somewhere that it isn't)
I need to know where to start when picking up a new set of pinion gears...
Thanks for the help as usual guys!
Cpt.
- RCSpecialties -
Old 04-11-2009, 01:36 AM   #704
lochness42's Avatar
Unfortunately not - I've only used Hudy's.
Yes
Yes
You can still use rollout from other guys. Reason why rollout isn't used in rubber is that everyone has same diameter of tires - that's why foam guys use rollout for defining their gearing.
I hope it helps. Regarding to your questions about gearing - I'm not helpful - I don't run 17.5T motors.
Pavel Balint
Old 04-11-2009, 05:11 AM   #705
rcterp's Avatar
Trader Rating: 35 (100%+)
Cpt.
1 & 2 = Yes
3 & 4 = ~3.5 - 3.7; but the best way is to check you motor temps.
5 = lochness is spot on
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
