Old 03-29-2009, 09:23 PM   #646
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Just picked up a pair of 009s. Can't wait for them to get here
Cpt.America is offline   Reply With Quote
Old 03-30-2009, 05:54 PM   #647
Skiddins's Avatar
Originally Posted by Adam? View Post
That's an easy generalization to make, but it's wrong.
Foam seems easy if you're just throwing them on the car and running it once. It's got way more grip and feels better than the best rubber car. However, when you start to compete, you realize even with all your grip, other guys are putting 4 laps on you. There's a lot of little tricks in foam to be fast, maybe even more than rubber. The work required to keep it there is what's driving people back to rubber tires.
A 13.5 foam car will do significantly faster laps than a 6 cell mod rubber car. I think that's part of the reason mod isn't as popular in the states. Here's an example from IIC 2008. (13.5 foam | mod rubber)
True, but racing in the US seems to be more biased towards small indoor carpet tracks where foams are used, where as in Europe the racing tends to be at permanent outdoor tracks.
The amsller the track, the less of an advantage a Mod has.
2) Why do they call them EU and US versions, and not asphault and carpet editions?
Presumably marketing for their two biggest markets
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 04-02-2009, 08:12 PM   #648
dht
Trader Rating: 16 (100%+)
What 17.5 motor is good for this car?
dht is offline   Reply With Quote
Old 04-02-2009, 08:19 PM   #649
Rdog's Avatar
Trader Rating: 83 (100%+)
Ive trie the novak and the hacker I seem to like to hacker a litte better. Ive heard the trinity duo is good too though ive never tried it.
Rdog is offline   Reply With Quote
Old 04-02-2009, 10:04 PM   #650
Powerlink's Avatar
Send a message via AIM to Powerlink
Hey Guys just built my new T209 rubber spec. ,This was an easy build for sure , My question is ,what size pinion gear to use with this 48 pitch 84 tooth spur gear that came in the kit?.I will be using a 13.5 in it . thanks
Karl Rolf
Powerlink is offline   Reply With Quote
Old 04-03-2009, 08:41 AM   #651
Super Moderator
Question:
Both of my 009s just arrived in the mail, and I see that the rear differentail comes pre-assembled. Being kind of a tech head, and like knowing how each piece of the car goes together, should I tear it down and rebuild it? Or toss it right into the build? What do you guys suggest?
Cpt.
Old 04-03-2009, 08:55 AM   #652
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
On mine, I popped them open to make sure there was enough grease on the diff balls. I didn't look at the thrust bearings because I didn't have the proper tool to get access to them. I put everything back together and after a few laps readjusted the diff and haven't looked back since.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-03-2009, 08:55 AM   #653
Regional Moderator
CarbonJoe's Avatar
Originally Posted by Cpt.America View Post
Question:
Cpt.
Just run them. Go easy the first few laps to break them in, then adjust them. They'll last quite a while before needing to be re-built.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 04-03-2009, 09:03 AM   #654
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Question:
Cpt.
I have run mine both straight out of the box and after my own rebuild. They're quite good straight out of the box, and as someone else mentioned, you cannot access the thrust assembly without a specialized tool (a pair of C-Clip expanders/compressors). Be sure to adjust the diff patiently and frequently by running it a few times on the track. I tend to run my rear diff fairly loose and it stays smooth once properly seated and adjusted.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 04-03-2009, 09:39 AM   #655
Super Moderator
So what do people tend to do? Does the thrust assembly just last forever then? (I know what the thrust assembly is, as I have built many diffs in my cars, but I admit I don't know what thrusts do)
Anymore information out there on why a "special" tool is required?
Old 04-03-2009, 09:42 AM   #656
The Evicerator
The thrust won't last forever, but it should last you a good amount of time if you break in and adjust your diff properly.
Xray diffs are some of the nicest and longest lasting around so don't feel like you're going to have to go digging into your diff all the time.
I do recommend getting some kind of c clip expander like J mentioned though... you'll eventually have to use it if you want to rebuild you diff completely!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 04-03-2009, 09:45 AM   #657
JimmyMac's Avatar
Or just buy a new assemble diff and throw out the old one... If you are lazy like me....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-03-2009, 09:58 AM   #658
Super Moderator
I guess it would depend on how much the tool is. I have NO problem spending hour after hour tinkering and re-building things on my RC cars, locked away in a room rocking out to some music
Anybody have a link to this "tool"??? Are directions for rebuilding the thrust in the assembly book? (haven't opened mine yet)
Old 04-03-2009, 10:05 AM   #659
JimmyMac's Avatar
http://www.sears.com/shc/s/p_10153_1...ap+ring+pliers
Something like that, just make sure the tips are small enough to fit in the clip. You can probably find a cheaper set at walmart or something.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-03-2009, 12:05 PM   #660
Super Moderator
Another question for you guys. being out of TC racing for the better part of 6 years, and now making the jump right into 17.5 brushless, what about all my old pinion gears of the past? I keep reading people talking about using 40 tooth pinions and such, which is HUGE comparred to what I am used to, back in the brushed days.
Considering the stock 009 spur, a redline 17.5 brushless, where would be a middle ground starting point for a pinion for outdoor/rubber/ashpault?
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
