Old 03-10-2009, 03:47 PM   #616
Johnny Wishbone's Avatar
Originally Posted by Skiddins View Post
Can someone please explain why some setups have the shims inbetween the shocks on both the front and rear towers.
What is the effect of these shims?
Skiddins
A quote from Alex Hagberg/Xray site.
"I use a 1.5mm shim on the top mounting of the front shock to make it perfectly vertical... to gain more traction. "
Old 03-10-2009, 03:50 PM   #617
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Yep, and also if you move the rear forward and have 3 deg inboard toe you can use shims in rear to make the shocks not so angled too.
ChristopherKee is offline   Reply With Quote
Old 03-10-2009, 05:31 PM   #618
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Cristian Silva View Post
Thanks and.
Which power profile would be recommended?
I usually run power of 4, 2,2,2
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-10-2009, 06:59 PM   #619
If added 1.5mm shim between the shock tower & shock mount-top, any shim required between the lower arm & shock mount-bottom?
MIKA is offline   Reply With Quote
Old 03-10-2009, 07:08 PM   #620
KHoff7's Avatar
Not required but may add if you please.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 03-10-2009, 09:19 PM   #621
Think of this adjustment as a 2nd dimensional adjustment of the shock, where your "normal" adjustment is at the top and bottom of the shock, in and out on the top but none at the bottom. Now with the shim you are adjusting fore and aft of the shock. If you where to adjust both top and bottom the same amount this would do nothing, but when only doing the top adjustment, it would change the stiffness of the shock similar to the "normal" adjustment shock feel, but forward bite would be effected, instead of side bite.
Old 03-10-2009, 09:34 PM   #622
Has anyone tried to run a 009 with a fibreglass T2R Pro chassis plate instead of graphite? Im thinking the fibreglass might be much more supple for unprepared low grip rubber asphalt racing
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 03-14-2009, 06:24 AM   #623
Trader Rating: 96 (100%+)
Pickup a US 009 and while going through the car to see what kind of setup is on it, found that one rear wheel is about 4 deg toe while the other is about 2 deg toe. It has an equal amount of shims on either side, inner hinge pin is not bent, same 1 deg. blocks on either side and everything moves freely, so I dont think anything else is bent.
I did change one shim from a .03 to a .02 and that helped out a bit. I know tolerances on parts can add up and will throw some things off. A couple thousandths here and there can add up.
Short of pulling the rear bulkhead off and checking that, anyone have any suggestions?
K.Copeland is offline   Reply With Quote
Old 03-14-2009, 06:34 AM   #624
Regional Moderator
CarbonJoe's Avatar
The rear uprights are side specific (L and R designated). Maybe you have two lefts or two rights? Having the wrong one on a side will actually reduce the toe in on that side.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-14-2009, 06:49 AM   #625
The rear blocks are correct, and I forgot to mention this is being checked on a Unity setup station. It's the same when I turn the car around on the setup and rotate the camber/toe gauges, I still get one wheel that is off.
Old 03-14-2009, 08:11 AM   #626
Skiddins's Avatar
No, but have you tried the asphalt top deck, which is thinner and more flexible?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-14-2009, 09:11 AM   #627
miller tyme's Avatar
in addition to L and R blocks they are also sold in different * of toe. Maybe one side is a 0* toe and the other is 2*
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is online now   Reply With Quote
Old 03-14-2009, 10:40 AM   #628
Regional Moderator
CarbonJoe's Avatar
Do you have a lot of play in the uprights? Bearings? Axles? If there is a lot of play, that could cause 1 degree of difference quite easily.
Old 03-15-2009, 10:16 AM   #629
Hello
Can someone suggest me some good rcshop in Europe where they still have T2 009 in stock. Best would be in UK.
Logika is offline   Reply With Quote
Old 03-15-2009, 02:22 PM   #630
okayplayer
Guest
Posts: n/a
Originally Posted by Logika View Post
Hello
http://www.wheelspinmodels.co.uk/ite...ar-Kit-__3447/
http://www.apexmodels.com/gbu0-prodshow/XR300013.html
Cédric
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
