Old 03-06-2009, 09:06 AM   #586
Any one know of an up-grade front belt for the 09?
thay just don't seem to make them last like thay use to
shrek54 is offline   Reply With Quote
Old 03-06-2009, 11:30 AM   #587
The Evicerator
This might defy common convention when gearing spec type motors... but I have found that using the largest possible gear combination to reach a desired FDR seems to yeild better results than simply throwing the smallest spur gear you can find in the car and gearing accordingly.
For instance this past weekend I was doing some testing running a given FDR with a 116 spur... when someone else was testing with the exact same equipment and FDR but with a 112 spur, he felt like he didn't have the same grunt out of the corners that I had.
When he finally put the 116 in with the same FDR, he immediately felt increased bottom end performance.
Theoretically I think this would be due to the fact that with a larger spur you are:
1.) Gaining a better mechanical advantage on the lay shaft/drive train. (torque = force x lever arm distance)
2.) larger gears use smaller tooth deflection angles and this results in less efficiency lost than gears with larger tooth deflection.
Obviously you will not be able to reach certain gear ratios with certain spur/pinion combinations, but when figuring out your gearing choices I would always try to find the largest combination possible.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 03-06-2009, 02:43 PM   #588
J.Filipow's Avatar
Trader Rating: 15 (100%+)
dbl pst
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 03-06-2009, 02:44 PM   #589
J.Filipow's Avatar
I'm just 'someone'? I thought I was 'somebody'....
Old 03-06-2009, 02:45 PM   #590
J.Filipow's Avatar
Good to see Paulie up in the mix overseas!
http://ets.redrc.net/2009/03/lemieux...inal-practice/
Old 03-06-2009, 03:47 PM   #591
okayplayer
Guest
Posts: n/a
Hi,
Sorry, here's some information on my setup that may help you to help me.
Basics & electronics
I (will on monday) run for first time my Xray T2 EU 009, on asphalt (see the youtube video with the track) with rubber tyres (Jaco Green) or RB 4xfront foam tyres (shore 35) with a Mazda 6 bodyshell.
Car is "perfectly" setup with a hudy according to the T2 manual (EU asphalt)
My electronic is : Tekin RS PRO (v189) + Tekin 6.5T (on a 21T pinion for the moment) with a 48 - 84 Spur.
Tekin RS PRO setup:
I have in stock also a 87 spur and ordered a 17 & 19T pinions
According to the manual, here're the FDRs :
Spur 84
17T:8.40
19T:7.52
21T:6.80
Spur 87
17T:8.70
19T:7.78
21T:7.04
Hope that helps,
1/ what is the FDR to go for the 6.5T motor ?
2/ any remarks ?
Cédric
Old 03-06-2009, 11:25 PM   #592
Rommel's Avatar
X-Ray T2 '009 chassis protector for Rubber #301128 version chassis.
Rommel is offline   Reply With Quote
Old 03-07-2009, 04:37 AM   #593
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Anyone Know were you can buy the 009 stickers from? Like the ones in the kit.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-07-2009, 08:39 AM   #594
Originally Posted by okayplayer View Post
Hi,
Tekin RS PRO setup:
Spur 84
17T:8.40
19T:7.52
21T:6.80
Spur 87
17T:8.70
19T:7.78
21T:7.04
Hope that helps,
2/ any remarks ?
Cédric
Hi Cédric,
The track seems to have pretty long straight lines, I would run with a 6.5T brushless motor, a ratio between 6.2 to 6.5
Jaco green seem to be a good choice with the cold weather in France, however you live in the south of France, I would recommend a 32 shore rubber tire with warmers. Why not using the GM36 french spec tire ?
Another point to consider is the flex of the 009, I strongly recommend you to get the asphalt top deck and/or taking out some screws under your chassis.
have fun next monday !
cheers,
Raphael
Ralf is offline   Reply With Quote
Old 03-07-2009, 10:29 AM   #595
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Are there going to be any other colors available for the 009 this year?
rctouringracer is offline   Reply With Quote
Old 03-07-2009, 11:21 AM   #596
okayplayer
Guest
Posts: n/a
Originally Posted by Ralf View Post
Hi Cédric,
cheers,
Raphael
Salut Raphael,
Thanks for the help ! I'll go first with the 21T pinion (fdr of 6.80) that should be smooth and less agressive than if I get a lower fdr. Especially with the Tekin RS 189 update; they told me to gear down.
Many folks at my local rc club run foam tires instead of rubber (cause they grip way less) but I'll give it a try with my Jacos.
32 shore should have a good grip for sure.
I removed screws under the chassis according to the manual. Chassis is really flexible
Merci pour ton coup de main,
Cédric
Old 03-07-2009, 12:39 PM   #597
jjbkozack's Avatar
im wondering if anyone out there knows where to get a 64p spur gear between 70-78t to fit on the x-ray
im going to see how fast i can get one of my old 007 chassis flying and need a tiny spur to fit my massive pinion, 80t is a tight fit, i think 78 would work
jjbkozack is offline   Reply With Quote
Old 03-07-2009, 02:13 PM   #598
Salut Raphael,
Cédric
Make some tests but I am pretty sure that with the long straight line you would choose a ratio around 6.4
Jaco Green is 28 shore if I am correct,
Just put some tire sauce like LRP asphalt or even better Paragon ground effect if your local track allows it and warm your tire, you will get the grip required.
for your information, we use the GM36 spec tire on carpet without any grip issue
Old 03-07-2009, 07:12 PM   #599
RFALLON's Avatar
Send a message via AIM to RFALLON
Xray was talking about putting some new colors out there right after the 009 came out, but i havent heard anything since
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
RFALLON is offline   Reply With Quote
Old 03-07-2009, 07:19 PM   #600
dht
Trader Rating: 16 (100%+)
Default hello
I'm using 17.5 what spurs and pinion I can use?
somebody tell me us 98 spur and 48 pinion.
thanks
guys.
dht is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
