XRAY T2’009
Old 02-21-2009, 11:00 AM
  #541
okayplayer
Guest
Posts: n/a
Hi !
I went to subscribe at my local rc club today with a friend of mine and he has the same setup than I will have.
Track is asphalt, he went with rubber tyres... the car was sloppy (really) looks like a bit a drifting car in sometimes...
After that someone gave him some foam tyres (GRP 40 I assume) and even if they were already used .. the car was more manageable.
He was advised to go to 35 shore ....
It's kinda expensive here to buy foam tyres Do you know if this jaco tyres fit (especially the rear ?
http://www.amainhobbies.com/product_...ducts_id/29946
Because I cannot install "rear" tyres on my T2, the back of the wheel will touch. In fact I just need to find good "normal" foam wheels for my T2 009
Thanks a lot,
Cιdric
Old 02-22-2009, 03:26 PM
  #542
HELP>>>>.Allright I am running 17.5/13.5 Rubber tire on carpet w/oneway....Cant stand the spool.....I could plow snow w/the car it pushes out it pushes in.....Saw alot of guys running a diff
Frnt:
Oneway
4,degree caster
1.5mm droop
1.3 sway
3rd hole out shock
1mm shim at C-hub
40wt shock oil 50% reboud 3hole piston
3.0 springs
Standard roll center
No post
0 degrees toe out
1.5 degrees camber
1mm shims behind arm mounts
REAR
2.0 dgrees toe in
no sway
30wt oil 50% rebound 3 hole piston
1mm droop
2.8 springs
3rd hole shock position
1mm shim at C-hub
Arms shimmed forward for wheel base
5mm ride hieght frnt and 5.5 mm rear
High traction w/Jaco blues
tekin speedo
smc 5000 lipo
ppd plate
20grams behind motor and batt
KO propo servo 2413
Any help would be awesome...
NUCRPTRACER is offline
Old 02-22-2009, 03:48 PM
  #543
Trader Rating: 23 (100%+)
- Where's your ackerman set, steering links straight or more angled??
- A small change in ackerman can make a big difference. More rear droop will make the car turn in harder but, you gotta soften the front a bit from where you're at.
- top links long and high (inside) will lower roll and give you more grip on that end of the car.
One of our guys is running a oneway at the club, he's got a ton of steering so, it's there, you just gotta find it with the rest of your setup. I'm still running spool and my car has loads of steering too in fact it's lose in the rear. Can't imagine a diff turning harder than a oneway ....ever, in or out.
I'll try to post my setup, maybe it'll help.
pcar951 is offline
Old 02-22-2009, 05:28 PM
  #544
Skiddins's Avatar
Frnt:
Oneway
4,degree caster
1.5mm droop
1.3 sway
3rd hole out shock
1mm shim at C-hub
3.0 springs
No post
0 degrees toe out
1.5 degrees camber
REAR
2.0 dgrees toe in
no sway
1mm droop
2.8 springs
1mm shim at C-hub
tekin speedo
smc 5000 lipo
ppd plate
KO propo servo 2413
Looks like you may have gone too stiff at the front.
Try 30W oil at both ends and 1.4mm & 1.2mm roll bars with 2.8 & 2.4 springs front and rear respectively.
Remember, rear roll bars help turn in as well as balancing the car.
Have you removed any of the front screws to allow flex?
If you are braking at all you could also try kick-up on the front wishbones.
Skiddins
P.S. NO-ONE runs anything other than spools with rubber tyres
Skiddins is offline
Old 02-23-2009, 03:35 AM
  #545
I went from a car that was a little loose to a car that pushed and all I did from one day to the next was add more rear toe from 2 to 3 so I removed 1 degree back to 2 and car still pushed...I tried kick up and standard roll center and still no luck seemed like I had no front bite which really amplified when you have right to left action in chicanes...I ran some 9.6's 9.7's 9.8's and 10's one day to 11's 12's and even 13's the next nothin I seemed to do helped had to be something in the setup just cant see it......Now I am going to be running on low grip carpet so I am still searching for a good base high grip setup and low grip....I also run a 007EU in VTA and I have found a setup that will work for that car.....The funny thing is that I ran my 009 in VTA and it ran like it was on rails on high traction w/the same setup I started regular rubber w/this weekend but it didnt work....But VTA tires do have more traction and are wider......ackerman 2 at saver and outside at steering block and back on post.....I also had no center post installed 2 screws out of front bulkhead and 2 out at rear....I wiil try the lowering the front oil weight cause that could be part of the issuie slowing the weight transfer to the front..
Thanks for any and all help as always....
Old 02-23-2009, 06:16 AM
  #546
trickd122's Avatar
Default Conversion Kits
Is there such a thing as a conversion kit or a way of converting a 007 to a 008/009? If so what parts are needed if not does anyone have a 008 that they want to sell or trade for a Gas 1/10 kyosho RRR Evo w/motor and parts...
trickd122 is offline
Old 02-23-2009, 07:10 AM
  #547
No, the 007 can't be converted to 008 / 009 specs.
pcar951 is offline
Old 02-23-2009, 07:17 AM
  #548
HarryN's Avatar
The multi-diff can be converted to 008/009! Now the problem is finding a multi-diff for a 007 as well...
Any news on when more Multi-Diffs will be available from Xray?
HarryN is offline
Old 02-23-2009, 09:01 AM
  #549
JasonC's Avatar
Trader Rating: 120 (100%+)
does anyone know off the top of there head the stock springs and swaybars that come with the 009 EU kit,
JasonC is offline
Old 02-23-2009, 09:15 AM
  #550
Johnny Wishbone's Avatar
Are looking for a rubber or foam car??
Johnny Wishbone is offline
Old 02-23-2009, 09:20 AM
  #551
2.6 and 2.8 springs. It says 1.2 bars front and rear but I think the front bar is a 1.4, maybe.
Old 02-23-2009, 09:25 AM
  #552
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
What kind of rollout are you guys running on carpet, with a 17.5 motor? Like around 40mm?
BSchorr is offline
Old 02-23-2009, 09:27 AM
  #553
Foam or rubber?
Old 02-23-2009, 09:29 AM
  #554
BSchorr's Avatar
Foam, but what about rubber to?
BSchorr is offline
Old 02-23-2009, 09:34 AM
  #555
Trader Rating: 26 (100%+)
2.8 front springs
2.6 rear springs
1.6 front roll bar
1.4 rear roll bar
http://www.teamxray.com/teamxray/sho...p?file_id=4905
ldp787 is offline
