Old 02-05-2009, 06:16 PM   #496
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by NUCRPTRACER View Post
One last question on spool V. oneway fixed......Wouldnt the oneway be so much faster steerin wise and still give you the rip out of the corner?
Yup, corner exit should be the same as a spool, but no front brakes and looser on entry. I might be the wrong guy to answer though, never had any luck with a one way. Rarely see the Xray team guys runnung them.
pcar951 is offline   Reply With Quote
Old 02-05-2009, 06:55 PM   #497
jland's Avatar
Trader Rating: 74 (100%+)
Originally Posted by jland View Post
Does anyone know of an on-line shop that has the 52mm ECS drive shaft sets in stock?
It looks like Nexus had a few today but are now sold out, anywhere else?
jland is offline   Reply With Quote
Old 02-05-2009, 07:43 PM   #498
GTRtuned's Avatar
Originally Posted by BILKO1 View Post
I'm using a brand new 009 set up as per manual, i race on a dusty concrete track. Im using cs22 and tried sorex 20, the motor is a Novak 13.5. The car is very fast compared to my old FK05 (might be some of the problem) Whats happening is when i exit a tight corner the back end just lets go under acceleration it goes into the corner fine. I had a similar problem on the FK05 and loosening the rear diff solved that. Anyone got a tips to try as a starting point. Its so bad i was only getting 14 laps when i can get 20 with the old car but the 009 is a lot faster on the straight.
The 009 is a great car! The rear end is a little looser than the 007 but it is fast. What I did was run a 1 mil shim on the rear hubs. I run the camber links long and low. Also you can run 5 dropp in the front and 4 in the rear. A little droop in the rear will help keep it down. I also run 2.4 springs all around and that gives me good traction. When the traction goes up I run 2.6 springs all around. I also run no sway bars on low traction and run sway bars when there's high traction. We do a lot of low traction asphalt racing here in So Cal and this car is dialed. It's all set-up and when you find it, you'll win a lot of races. Check this site for set-up help:
http://forum.teamxray.com/xsheets.php
If you search my name you can try a fast So Cal stock or 19 turn set-up.
Walter Cosico
RC America/ X-ray/ SRG www.superradgraphics.com/ Hudy/ R1wurks/ TeamBocaBearings
GTRtuned is offline   Reply With Quote
Old 02-06-2009, 09:24 AM   #499
Cheers, i've removed the roll bars and hope to try it out tonight but the 6 inches of snow dosen't bode well
BILKO1 is offline   Reply With Quote
Old 02-09-2009, 05:42 AM   #500
Trader Rating: 20 (100%+)
Hi All,
I'm thinking of getting a set of alloy shocks for the 009. At the moment i'm tossing up between
308306-O XRAY T2'009 Alu Shock Absorber - Set - Orange (2)
or
Tamiya TRF 84008
The Xray are a bit pricey and the Tamiya ones are a lot cheaper but not sure if they fit or work on the 009. I've heard a few ppl use the Tamiya ones in their 008 and had good results.
I would appreciate your input on which one is better for the 009? or any other alternatives.
Thanks in advance
bee200sx is offline   Reply With Quote
Old 02-09-2009, 05:56 AM   #501
RFALLON's Avatar
Send a message via AIM to RFALLON
Originally Posted by bee200sx View Post
Hi All,
or
Tamiya TRF 84008
Thanks in advance
Tamiya will fit the xray but will look kinda out of place with all of the orange
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
RFALLON is offline   Reply With Quote
Old 02-09-2009, 11:53 AM   #502
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Hi All,
or
Tamiya TRF 84008
Thanks in advance
You could always try out the RCAtomic alumi shock bodies. Think those go for $15 a pair.
ChristopherKee is offline   Reply With Quote
Old 02-09-2009, 12:39 PM   #503
miller tyme's Avatar
Do you have a link for those shock bodies?
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 02-09-2009, 01:15 PM   #504
ebay =). I forget which of the HK sites here has them but they list on ebay all the time. rcatomic.com is there site, and I think RCMart is the HK site.
You can also get a full set of the 008 front/rear swaybars from them for $15. They work.
Old 02-10-2009, 08:13 AM   #505
Hey just wanted to post I ran the P.Lemieux Novak race setup w/a few changes in VTA and it was nailed high traction...To bad I didnt have better skillz behind the wheel but I made a few changes shoot me a PM and I will send it to ya...I know there are a few guys runnin these in VTA....Thanks..
NUCRPTRACER is offline   Reply With Quote
Old 02-10-2009, 06:29 PM   #506
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
anybody know where I can get a multi-diff??
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 02-10-2009, 06:39 PM   #507
I just used a 007 multi diff and bought the 008 multi diff axle Only difference of course is the overall legnth.....pluse the main axle you get about anywhere..
Old 02-10-2009, 07:47 PM   #508
RFALLON's Avatar
If anyone is wondering where to get one, A Main Hobbies has both EU and US in stock right now for $504
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
Old 02-10-2009, 07:55 PM   #509
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
You can use the 07 multidiff but you have to shim the pulley 1mm (I think or maybe 2mm) away from the main axle.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-10-2009, 08:38 PM   #510
Stormers has em for $490, should have mine tomorrow
Ken Miller
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
