XRAY T2’009
#32
Being a great internet engineer I am quite worried that shimming the top deck will cause tweak issues, and will not be quite as consistent without the shims, just because it is not a keyed system, and as we all know, screw holes don't key things down. In short, the top deck might be able to shift too much.
#33
Special graphite pads are inserted between the top deck and bulkheads which raise the top deck by 2.5mm to allow the fitting of LiPo battery packs with a height 24 mm.
Thats a plus. Should be able to run a 5000 mah lipo with one of our weight plates as well. Hopefully the graphite shims will be mass produced so the 008 and 007 owners will have an option. But...then again that could have a negative effect on 009 sales so who knows.
Now orange xray looks like a bad idea. Why silver was replaced. I can`t get any other car which is silver anodised. Nooooo.
#34
I kinda like the orange...i wish they would put aluminum shocks as standard..especially for a kit that is so expensive.
#35
The shocks aren't aluminum because they shave off weight. But my question to that is are shocks sprung or unsprung weight?
#36
To do this correctly its not that simple IMO. You need flats on the washers to hold the diffs in place, and then there is the steering post bearing / sleeve that will barely be inside the top deck if you shim enough for a 5000 and weight plate.
I was considering building a kit to do this, but this Xray version may take care of the issue.
#37
#38
Bad color choice. Why would Xray change their identity? Maybe Hotbodies should change to Green or maybe Associated should change their color to red? Irritating to say the least...IMO
#40
Chassis
i know its a lil to early to ask. wouldl like to know if the 009 chassis fit the 008? i like the idea of battery being pushed out to fit lipo. thanx
dev
dev
#42
T2'008 EU chassis: 301125 (6cells)
T2'009 EU chassis: 301128
Both 2F remain the same (301183)
Other changes seems to be different wheel axle (305340 > 305341), rear drive shaft (305324 > 305326), and color. Any one saw any other changes?
#43
is there going to be a foam edition?
