Old 12-29-2008, 12:31 PM   #286
Johnny Wishbone's Avatar
Originally Posted by todb View Post
my front driveshafts bind on my 009. As soon as i snug the set screw it begins to bind. These are the 50mm steel front driveshafts. I dont think that i got loctite in the joint because both fronts bind but not not the rears. I will clean it tonite and try again but any help will be appreciated. Thanks
I think it may be the pivot pin (the one that goes inside the drive shaft and has the setscrew that holds the pivot pin) that sits inside the driveshaft, when you tighten the set screw it puts a little pressure between the pin and notch for the driveshaft, almost like the pin hole isn't centered correctly. I had this happen when I set up some aluminum drive shafts from the spring steel ones as well, but I think the only fix was to switch the pivot pin. You could try to swap this part between the 4 drive shafts.
For those that are wondering about the difference between the 008 and the 009 chassis. There are extra holes for the motor mount that will change the motor location that is suppose to make it more brushless motor friendly, the official release is suppose to be later next month, probably a 2 piece replacement and different belts to make it work. The battery slots are also located more forward and very (if 1mm) out from the center, althought both are still the same overall width.
Old 12-29-2008, 12:50 PM   #287
Joel Lagace's Avatar
Originally Posted by RFALLON View Post
Thats with breaks, not 9 hours straight
I once built and painted a car in a hotel room! I was so excited to get the hpi pro3(o my god what a pos!) And started the build at 11pm and by 2am it was ready for the next days qualifiers.(ok my room mates did the shocks and body while i did the rest)
Good times..
I would not rush a build again, to me the build is worth savouring, specially an xray build
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 12-29-2008, 01:31 PM   #288
Originally Posted by gfarb View Post
Does anyone have the 52mm ECS's in stock?
I ordered some from rc-cars24.com last week. I believe they are out of Austria and they have been shipped to me already in Canada as well as the new Xray Xll and some spare parts. Not sure if I got the last two or not.
-Kane
rcdepot.us
nxgraphics.ca
Kane-o is offline   Reply With Quote
Old 12-29-2008, 02:29 PM   #289
mtbboy's Avatar
Hey all.
Where is there a conversion for the new to old spring rates?
Ie, c 2.6---d 1.5 Etc.
Thanks in advance.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 12-29-2008, 02:34 PM   #290
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by mtbboy View Post
Hey all.
Thanks in advance.
here ya go
http://forum.teamxray.com/viewtopic.php?t=6746
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-29-2008, 03:11 PM   #291
Trader Rating: 14 (100%+)
I had major binding issues with one of my rear aluminum drive shafts. After many parts swapings I narrowed it down to the drive shaft itself. It only bound up when the set screw was tightened. From all my testing I found the slots on each side of the shaft that the pin slides in are not in line to each other. A little dremeling help free up the pin. I figured it was just the aluminum shafts but it sounds like a spring steel problem also. Not very often you catch XRAY with mistake but oh well could be worse.
rushrush1 is offline   Reply With Quote
Old 12-29-2008, 03:18 PM   #292
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
What are all the light weight parts that come with 009?
Are ecs driveshafts included in front?
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 12-29-2008, 03:23 PM   #293
No ECS, just the aluminum rear driveshafts and 4 of the light axles. No other lw parts with kit.
Old 12-29-2008, 03:28 PM   #294
Thats pretty much what I was getting at with the above post and that was with the aluminum shaft (as well). I found that it was the actual center pivot pin that holds the steel pin via the set screw, only happened when it was tightened. Swapped that part out and the problem was fixed with no dremeling.
Old 12-29-2008, 04:14 PM   #295
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
an issue like this with some other companies and people would be all over it crying bloody murder, conversely still other companies the response would be 'oh its always been that way, here's the workaround'....
fickle we are
R
UltegraSTI is offline   Reply With Quote
Old 12-29-2008, 05:22 PM   #296
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
my wife got me a 009 for christmas also but i found out she had it since the 12th of dec and ordered it from europe on the 2nd it was 506 shipped
i spent thursday night(4-12) ,all day friday 11-3am and from 11-6 saturday
building the 009 (first 7-8 hours [just the build])then puttin all my electrics from my 007 into the 009 and then going thru the 007 and puttin my sons electrics into it from his fk04 then doing the balanceing act and of course the setup board/tweek station my butt/legs ached all day sunday from sittin in a wooden kitchen chair for almost 31hours i took a smoke break about every 2 hours but it was all worth it sunday night
i havnt built a kit since 2001 (tc3 FT) and the xray kit was very clean to build all you had to do was put it together (99%) unlike the associated cut, sand, check build....
i wish the old color springs would work on it though with those springs it will not go below 6mm ride height
jlfx car audio is offline   Reply With Quote
Old 12-29-2008, 05:46 PM   #297
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default 008/009
can I cut my extra top decks will it be the same as the 009 ?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-29-2008, 06:11 PM   #298
Goingfast's Avatar
Trader Rating: 29 (100%+)
I don't see why not.....
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 12-29-2008, 06:51 PM   #299
RC8
Suspended
Is there a conversion chart from the new dark springs to the old colored springs?
I have no signature, it could be misconstrued.
RC8 is offline   Reply With Quote
Old 12-29-2008, 07:00 PM   #300
Originally Posted by rx7ttlm View Post
i do believe this was bosted about 10 posts ago
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
