Old 12-06-2011, 08:58 PM   #2611
Originally Posted by Misiek View Post
I'm thinking of getting T2 009 as my VTA car possibly USGT later on. Do you thikn this will be good car for VTA or should I looking into something newer like T3.
How is spare parts avaiability for this car and how much longer do you things spare parts will be available for it.
I run my 09 against 07, 08 and 11 Xrays as well as some TC6's and 415's in our RC GT class. Besides the lack of driver at times my 09 still runs among the fast ones.
Personally I think the 1.7 gearing helps the car in a blinky class with a 17.5 motor. Setups arent much different between the 09 and the newer T3's
Robbob is offline   Reply With Quote
Old 12-07-2011, 06:38 AM   #2612
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
T3 and T2 cars have different geometry so setups do differ quite a bit.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 12-07-2011, 06:44 AM   #2613
What setup option part i should carry?
Im thinking of getting 6degrees and 2degrees hub, and few 1.5mm shim.
is there anything else i should get??
Vrooom is offline   Reply With Quote
Old 12-07-2011, 09:16 AM   #2614
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Your choice of hubs really should depend on the type of track you run on. If you're running a very large outdoor track with wide sweeping turns, then the 6deg hub will help. However, I know some XRay pro guys and they say they always stick to 4deg on theirs and make other adjustments to increase or decrease steering.
The one option part I highly suggest you getting is the H1/H2 or the L1/L2 roll center adjusters. One of these items became standard issue on the T3 and it really helps in tuning your cars handling. The other is to get the springs either one stiffer or one softer or both. Stock is 2.8F 2.6R, and I have a 3.0 on the front for mine.
Also, if you don't already have it in the kit, get an extra set of shock pistons. In the piston kit, there is an option for you to build it with adjustable dampening or you can use the extra pistons with different amount of holes to tune your shock the way you like it.
YR4Dude is offline   Reply With Quote
Old 12-07-2011, 09:22 AM   #2615
YR4Dude's Avatar
Default T2 009 Lipo Weights
Since upgrading to the Exotek chassis, I no longer need the Xray Lipo weights part#309860.
http://www.nexusracing.com/product_i...oducts_id=2690
If anyone is interested, I'm selling them for $25 shipped, domestic frt only.
Old 12-07-2011, 09:38 AM   #2616
Originally Posted by YR4Dude View Post
There has been nothing earth shattering from XRay since the 009 that has made any real difference. It (009) is still a very competitive car especially with the Exotek chassis upgrade. Everything outwards of the bulkheads is the the same as the T3.
The only real difference is the drive ratio which is 1.7 vs. 1.9 on the T3. Thats because the 009 uses 34T diff pullies instead of 38T pullies. For me, I don't see the difference. If you want to jump into the gear diff bandwagon you'll have to convert to 38T for your front spool as all the gear diffs for the XRay are only 38T.
Just a heads up Spec R makes a 34T gear diff. I just bought one for my 007.
rcgerber is offline   Reply With Quote
Old 12-07-2011, 10:37 AM   #2617
clparsons123's Avatar
On my 009 I run the standard chassis and gear diffs front and rear I personally like the 38tooth pulleys better the then 34 .. I am just as competitive with it racing against the 11's and 12's here in Florida . I also ran my 09 last year at birds and qualified 4th finished 3rd .
EAM (TEAM EA MOTORSPORTS),ORCA, RC AMERICA, XRAY,HUDY,EZ CUSTOMS, RSD (REFLEX RACING) , JEFFS RC STUDIO, RCTVLIVE
Cory parsons
clparsons123 is offline   Reply With Quote
Old 12-07-2011, 11:50 AM   #2618
YR4Dude's Avatar
I thought they might but wasn't sure. Most shops including my local shop only carries the 38T version. Personally I'm not a big fan of the gear diff for electrics. However for others who want it without having to change to 38T, here is the link: http://www.spec-r.com/default/index....roducts_id=214
Old 12-10-2011, 12:31 PM   #2619
What servo i should get? im thinking of Savox 1251mg?
servo spec are:-
•Speed (sec/60°): 0.1 @4.8V, 0.09 @6.0V
•Torque (kg-cm): 7.0 @4.8V, 9.0 @6.0V
is there any better servo than 1251mg?
Also, what is the ideal servo horn angle is?
i have it pointing it upward, rather than at angle like manual suggested, coz the linkages are too long...
Old 12-11-2011, 05:12 AM   #2620
orci77's Avatar
A friends uses the Savöx. He is satisfied. Also the orange is nice in the Xray ;-)
I personally use a KO Propo 2413. But it cost as twice as much as the Savöx.
Get a shorter linkage and use the angle proposed in the manual.
Xray T3'012 + Nosram Pearl SpecRacing V2 + LRP X12 17,5T / X11 9,5T / X11 6,5T
Team Associated SC10 + Nosram Matrix Reverse + LRP X11 13,5T
3Racing F1-09 + LRP Sphere + LRP X11 17,5T
orci77 is offline   Reply With Quote
Old 12-13-2011, 08:54 AM   #2621
What to do?
I got a hard case lipo battery, with 4mm female plugs built in, that hole goes under the rear of the top deck,
Has anyone got a work around to it apart from moving it outside? of top deck?
I seen people cutting bit of top deck to let the battery plug fit though, but wont that weaken the chassis etc ?
Old 12-13-2011, 08:56 AM   #2622
Dane's Avatar
What to do?
Xray makes a lipo pad set that will raise the top deck for taller lipo batteries.
Old 12-13-2011, 09:05 AM   #2623
jag88's Avatar
What to do?
Both holes will be accessible if you turn the battery 180 degress.
jag88 is offline   Reply With Quote
Old 12-13-2011, 09:35 AM   #2624
Misiek's Avatar
Will this battery fit T2 009 without any modifications?
http://www.hobbypartz.com/98p-40c-50...-hardcase.html
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Old 12-13-2011, 10:11 AM   #2625
YR4Dude's Avatar
I just got one of those last weekend. Any hardcase 2s lipo will fit. However that all depends on how your car is configured.
If you're using the XRay lipo weights like the ones I have available for sale, you can mount that battery with no problem. If you don't, and you want to mount it close to the center of the chassis right on top of where the slots are for the sub-c cells, you'll need to get the XRay lipo pads if your car is not already equipped with those. The lipo pads are graphite spacers for your top deck to clear the height of the hardcase lipo.
Lipo balancing weights
http://www.teamxray.com/teamxray/pro...=&catName=Lipo Balancing Chassis Weights
Lipo pads
http://www.teamxray.com/teamxray/pro...ia=&catName=T2 008|T2 009 Rubber-Spec Graphite Pads for Lipo - Set
http://www.nexusracing.com/product_i...oducts_id=2567
You need either or but you don't need both.
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
