Old 09-18-2010, 04:29 PM   #2476
Originally Posted by CarbonJoe View Post
Just sand them with 400 or 500 grit sandpaper until you can't see the black line anymore. Clean them with motor spray and re-build the diff.
Thank you very much for your help!
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 09-19-2010, 12:16 AM   #2477
Benzaah's Avatar
Trader Rating: 21 (96%+)
In the heat of battle never forget this tip Otherwise you will end up like me with a very crunchy diff after a few runs
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 09-19-2010, 08:04 AM   #2478
One last question (I think):
For wheelbearings, should I only use rubber-sealed bearings, or are metal-sealed bearings okay? I am only running on carpet.
The reason I ask, is that I have A LOT of cluth-bearings from my off-roader, and they fit in my Xray.
Niklas Hansen
Old 10-07-2010, 07:42 PM   #2479
Trader Rating: 19 (100%+)
hi guys i have a question, do the 007 a-arms make the 009 track width narrower because when i replaced my arms with them it seemed to make the car want to bite in and almost traction roll? Thanks
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 10-18-2010, 10:06 PM   #2480
waOscar's Avatar
They will work fine. I interchange between my gas off roader and xray onroader all the time.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 10-19-2010, 09:13 AM   #2481
Default rear too loose
hi just a small question
i own a xray 009 and i drive it out doors on a medium grip medium size bumpy track with 4 hair pins turns and a 50 meters strait the only problem i have with this car that is too loose from the rear but i have a lot of steering. I try ed many settings but with no success do someone had the same problem and how you think i can solve it.
thank you in advance and sorry for my bad English
Corally_27 is offline   Reply With Quote
Old 10-19-2010, 01:39 PM   #2482
JKL1031's Avatar
toe it in? We will need the current setup.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 10-19-2010, 01:52 PM   #2483
down stop f6 r5
ride hight f5.5 r6
.5 deg toe out front
2.5 deg toe in rear
1.5 camber all wheels
2.2 xray springs front and rear
shocks 2 holes front 4 holes rear 30wt oil all wheels
if you need some thing more just ask
Old 10-19-2010, 02:42 PM   #2484
The way I fixed the loose rear-end, was that I raised the rear-shocks one hole on the shocktower.
Niklas Hansen
Old 10-20-2010, 06:13 AM   #2485
i tried to lower the shock on the rear and to rise the shocks at the front but with no such difference is still had the rear loose
Old 10-20-2010, 06:45 AM   #2486
Move the ackerman position back right back, make rear toe 4 degrees once your happy the back end is sticking slowly start to reduce to and reduce ackerman by move the arm forward.
Also what tyres are you using?
michael.branth is offline   Reply With Quote
Old 10-20-2010, 06:51 AM   #2487
we all use lrp vtec 27x or 30x but it seams that only i have the problem
Old 10-20-2010, 06:52 AM   #2488
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
2.2 springs all the way around if very hard to get a good set up with try a stiffer spring and the shock pistons you want a less holes in the front to let less oil threw and more in the rear or just go 3 holes all around that it the best set up i had in caret/asphalt.
TRXRACER99 is offline   Reply With Quote
Old 10-20-2010, 07:01 AM   #2489
should i go for stiffer front spring only or u suggesting to change all the springs for example 2.4?
Old 10-20-2010, 07:30 AM   #2490
That is also the opposite of what I said
One hole out on the rear shock-tower did the trick for me.
Niklas Hansen
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
