Old 05-20-2010, 11:45 PM   #2371
alecladanga's Avatar
Originally Posted by tc3jp View Post
I am getting an ungodly vibration when I turn the wheels right or left.
Someone said the "ecs" parts will fix this .
Searching Nexes racing, I came up with two options, part number: "305277" and part number:"305327" which ones do I need? and do I just need them for the front to solve this problem.A guy at the track had this same problem with his T-3 and he replaced them with the ecs parts.I saw him go full throttle while turning right and left and it was as smooth as glass,but I did not notice if he had them on the rear.I saw them on the front though.
Part number 305327 has the 52mm drive shaft.
305325 is the ecs with the 50mm drive shaft.
305227 is just the drive shaft for the ecs and not the complete set.
Thus, best to choose either 305327 or 305325. based on my experience alone, the shorter the drive shaft, the steering gets more aggressive or responds faster. however, the longer drive shaft is more stable.
alecladanga is offline   Reply With Quote
Old 05-21-2010, 01:49 AM   #2372
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
Can you run the Spec R gear diff in the t2 009?
http://www.egrracing.com/shop/gear-d...8t-p-3825.html
it says it fits the T3 but doesn't mention the t2 009.
And also if you can use the 38t gear diff, can you run it with the 20t standard centre pulley if you change the rear belt??
Thanks in advance
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 05-22-2010, 04:25 PM   #2373
Thanks in advance
Anyone???
Old 05-22-2010, 05:06 PM   #2374
vazzo's Avatar
Trader Rating: 100 (100%+)
pretty sure it will fit but it might knock the gear ratio around as it is bigger than the standard 34t ball diff pulley so you may have to put a 38t spool in front and 16t pulley and no you wouldnt be able to run the 20t pulley with the 38's as the belts wont reach or be hell tight on the loosest setting.
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 05-22-2010, 05:10 PM   #2375
Thought so. For the cost of it, it wouldnt be worth it I dont think because like you said you would have to go to a 16t centre pulley, and 38t spool, and 2 new belts to fit.
Old 05-24-2010, 11:35 AM   #2376
In the 009 rubber spec manual it states to insert two shims on the front and rear of the hinge pins, when installing the a-arms.
There is no room on my car to install these shims.
In fact I had to file a little on both ends of the arms so they would not bind on the hinge pins.I do have the X-H arms on this car.
Is this normal.?Are the washers part of the wheelbase adj.?
thanks
tc3jp is offline   Reply With Quote
Old 05-24-2010, 11:44 AM   #2377
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
thanks
The washers/shims are part of the wheelbase adjustment. Filing down the arms is NOT normal. Take pictures, poste em up.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-24-2010, 01:20 PM   #2378
I forgot to mention this is on the front a-arms on the car..
On the rear a-arms there is plenty of room for the shims..
I bought this car used here on rctech recently.I kinda got ripped.Every bearing in the car was shot.It was advertised as an all rubber spec car.It has a lot of foam spec parts on it.The chassis plate and top plate are about the only thing rubber spec. on the car .It has 50mm driveshafts front and rear.It has tamiya shocks on it, which is ok.
I would really like to send this car to someone who knows X-ray tc cars inside and out,just to see what I have got.The a-rms on the front have me confused.If I install them without the shims they will not move they are so tight.I did file them a bit to free them up.
thanks jimmy
Old 05-25-2010, 05:44 AM   #2379
vazzo's Avatar
Thumbs up SPEC-R Gear Diff for T2009
Hi Guys
Ive done some research into this and found one for the T2009, it's available through an ebay seller via this link http://cgi.ebay.com.au/Spec-R-Gear-D...item3a5b2c7348
The only modification you need to make is to use 50mm cvd's/ecs drive shafts in the rear instead of the standard 52mm.
If you want run the 38t T3 gear diff you need to run the 50mm shafts in the rear still and also upgrade the front spool to a 38t.
Hopefully Ive covered it all here.
Cheers
Adrian
Old 05-25-2010, 01:47 PM   #2380
[QUOTE=vazzo;7452620]Hi Guys
Cheers
Adrian
regards
Old 05-25-2010, 07:52 PM   #2381
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Anyone have issues with the rear sway bar rubbing the pulley click covers?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 05-25-2010, 10:23 PM   #2382
Super Moderator
on an 09?
- RCSpecialties -
Old 05-25-2010, 10:26 PM   #2383
vazzo's Avatar
No mate. Are they proper xray sway bars?
Old 05-26-2010, 07:12 AM   #2384
Dane's Avatar
on an 09?
Well on a 08 but it's the same thing.... I'm running the 1.9 pulleys if that makes a difference.
Yeah the sway bar is right... are the plastic holders on the rear different from the front?
Last edited by Dane; 05-26-2010 at 09:11 AM. Reason: added note about 1.9 conversion
Old 05-26-2010, 09:11 AM   #2385
Super Moderator
No, and they aren't anywhere CLOSE to rubbing on the diff covers... the only thing I can think of is if you werent a strange pully or something.. take a pic and show us.
- RCSpecialties -
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
