Old 04-07-2010, 09:26 AM   #2296
hacker's Avatar
Trader Rating: 141 (100%+)
you dont understand.
he is using his xray on weekends in the parking lot
and during the week he races his tt01
hacker is offline   Reply With Quote
Old 04-07-2010, 12:56 PM   #2297
Davin's Avatar
Trader Rating: 43 (98%+)
ROFLMAO
Davin is offline   Reply With Quote
Old 04-07-2010, 06:48 PM   #2298
seankyew's Avatar
Originally Posted by Davin View Post
Sorry for stating the obvious. But your like the guy who buys a Ferrari and whines about having to put premium fuel in it.
I do not see anything wrong in looking for steel cvds as a cost effective replacement for the T2. As far as I know Ferraris do use steel components/axles. But then again a Ferrari does not come with plastic shocks; however a tt01 does.
Xray makes great cars, but there's no need to worship and defend everything they sell. I will stop my comments here and prepare my car for the 'weekend parking lot racing'. It will not be fair to other forum users if we let this debate drag on. I'll let you have the last word/closing statement, which I'm sure you (and your sidekick) will insist. Have a great weekend and enjoy your RC!
seankyew is offline   Reply With Quote
Old 04-07-2010, 08:28 PM   #2299
hacker's Avatar
on a serious note, I always believe 'you get what you pay for'.
I have atomic universals on my car as it allows my car to steer 'wobble' free on anything more than 50% steering travel. They are cheap, compared to xray's aftermarket ecs shafts. However I have had a few dnf's due to the pins breaking, and also the actual shaft breaking too. When they fail completely, I will just use the standard xray cvd's as they are indestructible.
Old 04-07-2010, 09:18 PM   #2300
Potoczak's Avatar
Trader Rating: 112 (100%+)
Is it a good investment to upgrade the 009 to the 38t pulley set? Will i notice a big difference?? Any advise would be great!! Thanks
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 04-08-2010, 01:09 AM   #2301
Originally Posted by seankyew View Post
are there any steel 52mm cvds from other brands which can be used in the T2? the xray spring steel ones are expensive; i do not require such exotic material for my weekend runs.
thks.
try 3racing, they make T2 CVD's , cant comment on how good they are. RCMart sells them
I use a 007 for fun 'weekend runs', ( 008 for more serious stuff )
007 makes a great basher as its just so tough. It cost me less than a new TT01 :-)
1101 is offline   Reply With Quote
Old 04-08-2010, 05:59 AM   #2302
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
difference is in on and off power transition. It makes it smoother and thus the car is easier to drive.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 04-10-2010, 04:11 AM   #2303
Originally Posted by michael.branth View Post
HI Guys,
Can any one help me understand the idea behind the 2mm shims xray staes in there manual as adjusting the steering. By this I mean why moving the shocks 2mm away from the tower changes the cars handling?
If any one has tried this can you also help with what end to do it on what effect it has, i.e front shimmed- less steering, rear shimmed-more steering? Shims front and rear less all around?
One last thing, do you shim the top and bottom of the shock?
thanks in advance,
mi
NO one??????
michael.branth is offline   Reply With Quote
Old 04-10-2010, 07:48 AM   #2304
Dane's Avatar
I have not tested it personally but from what I've heard/read is that shimming the shocks out makes the car easier to drive. I will test this this weekend on my 008
Old 04-10-2010, 08:00 AM   #2305
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
NO one??????
Shimming the top of the shock will make it feel more inclined. The feeling will be not as direct. If you want a setting between the holes on the shock tower add some shims.
Jaz406 is offline   Reply With Quote
Old 04-12-2010, 04:59 AM   #2306
Thanks mate, usefull information, I'll be trying the top of my front shocks shimmed out a smooth the transition.
BUT!!!! I still can not figure out why the manual states that moving the shocks away from there mountings by 2mm would make the car smoother and easier to drive through chicanes??
yo, mi
Old 04-12-2010, 10:32 AM   #2307
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Need high speed steering.
Hello fellas! I was hoping I could get some help dialing in some more highspeed steering into my 09. Low speed, and medium speed steering is perfect, the car handles like a dream. But, we have a really highspeed sweeper, and id like to be able to hold full throttle through it with my tekin turbo still engaged, but when I do, the car pushes a bit too much... so id like to do some small tweaking to get more steering, under highspeed.
Ill try to list my setep best I can here:
Track - outdoor medium traction asphault, sprayed with mountain dew
front camber -2
rear camber -2
rear toe in -2
front toe out +1
upper roll center adujustments - lower and inner hole front, lower and outer hole, rear
Ride height 5.2mm front and back
2.8 springs front and back
35 weight oil front and back (I think 3 hole pistons? i forget).
Everywhere but top speed sweaper, the car handles perfectly...
Thanks for any help you can provide, let me know if you need any other measurements off my car.
-cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-12-2010, 10:55 AM   #2308
Dane's Avatar
How much caster are you running? going with 6 degrees with give you more high speed steering if you don't have it already.
Old 04-12-2010, 11:11 AM   #2309
Super Moderator
Im running the default out-of-the-box caster blocks... is that 4?
- RCSpecialties -
Old 04-12-2010, 11:41 AM   #2310
Dane's Avatar
4 is correct. Try 6. If it gives you too much steering, use the 6 degree blocks with front kickup.
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
