Old 03-16-2010, 05:42 AM   #2281
BLook_RCMan's Avatar
Default EU spec chassis needed
Hey, I picked up a 009 and found out it was the US Foam Spec. I am looking for the EU rubber spec. Anyone have a chassis and top plates they coul dsell or trade for my foam spec items. My chassis plates are in great condition - no scratches at all!!!
I would hate to tear it up on asphalt.
It ain't work if you love what you do...
BLook_RCMan is offline   Reply With Quote
Old 03-16-2010, 07:35 AM   #2282
alecladanga's Avatar
Originally Posted by Potoczak View Post
Hey Xray guys out there, i need to know if xray has ever changed the length of the shock bodies on any of the xray cars ( 08,09,t3). i am talking about the plastic ones not aluminum ones? I was going to replace one of the shock bodies on my 009 and the extra shock body i have is a little longer. Any input would be great. THANKS
Potoczak: the change in the length of the plastic shocks came about when they released the 008 and stayed the same until T3. The longer shock comes from the 007.
alecladanga is offline   Reply With Quote
Old 03-23-2010, 07:01 AM   #2283
hacker's Avatar
Trader Rating: 141 (100%+)
Default front outdrive
edit......found what I was looking for
http://www.redrc.net/2008/09/xray-t2...axle-adapters/
hacker is offline   Reply With Quote
Old 03-23-2010, 03:59 PM   #2284
has anyone tryed the Rubber-Spec Conversion Set - 38T Pulley on the t2009 is it a big difference over the standed pulleys and belts?
thanks
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 04-04-2010, 05:26 AM   #2285
sell682's Avatar
Trader Rating: 81 (99%+)
Im going to run EU w/ Rubber tires on Carpet. 17.5 motor.
What do you guys consider the standard carpet setup? Thanks
sell682 is offline   Reply With Quote
Old 04-04-2010, 07:49 AM   #2286
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
mwoods: difference is in on and off power transition. It makes it smoother and thus the car is easier to drive.
sell682: the best starting point is Paul Lemieux's IIC 2009 setup.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 04-04-2010, 10:03 AM   #2287
2009 setup.
Can you give a link to that?
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 04-04-2010, 08:28 PM   #2288
Dane's Avatar
http://forum.teamxray.com/xform/inde...3&setup=t2_008
Old 04-06-2010, 04:24 PM   #2289
Default shimmed shocks
HI Guys,
Can any one help me understand the idea behind the 2mm shims xray staes in there manual as adjusting the steering. By this I mean why moving the shocks 2mm away from the tower changes the cars handling?
If any one has tried this can you also help with what end to do it on what effect it has, i.e front shimmed- less steering, rear shimmed-more steering? Shims front and rear less all around?
One last thing, do you shim the top and bottom of the shock?
thanks in advance,
mi
michael.branth is offline   Reply With Quote
Old 04-06-2010, 09:24 PM   #2290
seankyew's Avatar
are there any steel 52mm cvds from other brands which can be used in the T2? the xray spring steel ones are expensive; i do not require such exotic material for my weekend runs.
thks.
seankyew is offline   Reply With Quote
Old 04-06-2010, 09:34 PM   #2291
drsfly's Avatar
Default steel
steel ones -- no not that I am aware of.
Some alum ones but I have not heard how they hold up.
I am guessing they would be fine---as with any material to a point.
If you plan to keep the car for a while or even upgrade to the t-3 they will transfer.So -- it is an investment.---- plus they are optimiz-- no I can't finish that.
Anyway they will not make your car faster--- but they seem to make it smoother so that may translate to better lap times.
later,
Darrald
drsfly is offline   Reply With Quote
Old 04-07-2010, 06:20 AM   #2292
trickd122's Avatar
Default lol
thks.
Xray has always been synonomus with Xpensive lol!!!
The Plus side to that is that they hold up pretty well...is it worth the premium price tag? well that's another matter for debate. The only part that I have seen the MOST issues so far is with the ECS drive Shafts!!!! and yes those are REALLY expensive.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 04-07-2010, 06:26 AM   #2293
Davin's Avatar
Trader Rating: 43 (98%+)
thks.
Ok Ill say it. If you do not require such exotic materials why do you own an Xray? Sell it and buy a used TC3 or an Ofna JL10e.
Davin is offline   Reply With Quote
Old 04-07-2010, 07:48 AM   #2294
seankyew's Avatar
thks for your advice. you are such a genius.
Old 04-07-2010, 09:15 AM   #2295
Davin's Avatar
Sorry for stating the obvious. But your like the guy who buys a Ferrari and whines about having to put premium fuel in it.
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
