Old 03-11-2010, 07:24 PM   #2266
hollywood tc5's Avatar
Originally Posted by Cribbin View Post
they shouldn't be tight at all. loosen them off so they have some movement. mine are 6 months old and they look like new still, and that is with a 10.5
what position sould it be in
BOSS MOTORSPORTS
wrecking ball,sox,hollywood
BOSS MOTORSPORTS
hollywood tc5 is offline   Reply With Quote
Old 03-11-2010, 08:32 PM   #2267
FK05 lover's Avatar
Trader Rating: 147 (99%+)
yes, they're not guitar strings
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 03-11-2010, 09:48 PM   #2268
they weren't tight there really loose it in the lower tightest settings
BOSS MOTORSPORTS
BOSS MOTORSPORTS
Old 03-12-2010, 12:56 PM   #2269
Andy63's Avatar
you should have the 3 tightest setup for the big belt. the rear belt doesnt matter so much, just that the rear belt isnt too tight, becuse when you are off throttle your car might feel like its hooking the rear.
or you can do it like this, feel on other cars belts and then go from there. if you still have the problem, then change belt.
www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 03-12-2010, 09:16 PM   #2270
Anyone have a good starting point for a VTA setup for a T2 009 EU on asphalt?
I get befuzzled trying to search the xray set up sheets.
Thanks in advance.
Dondor is offline   Reply With Quote
Old 03-13-2010, 08:29 AM   #2271
Trader Rating: 13 (93%+)
Default XRAY Set-Up?
Hey guys. I've been racing off-road for a few years and I'm gonna give onroad a try. I just picked up a XRAY t2 007 for starters. Any set-up infor would be great. I have no idea what I'm doing here.
Thanks.
The Chad
The Chad is offline   Reply With Quote
Old 03-13-2010, 10:00 AM   #2272
Regional Moderator
CarbonJoe's Avatar
Your best bet is to go to Xray's web site and look for a setup sheet for the '007 for the type of track / tire you plan on running.
http://www.teamxray.com/xforum/xsheets.php
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-13-2010, 10:18 AM   #2273
Thanks Joe! And nice pic.....
Old 03-14-2010, 01:27 AM   #2274
Cribbin's Avatar
depends how old they are. mine are one notch tighter from centre front and rear but you need to set it for your own belts
Bro-Kin Racing Group
X-Ray T3
X-Ray T2 '007
Castle Hill Raceway
Futaba LRP Tekin
Cribbin is offline   Reply With Quote
Old 03-14-2010, 02:52 PM   #2275
Default Thrust Bearing
Has anyone found a cheaper alternative to the xray diff thrust bearing or can you buy the plates that go either side of the thrust bearing seperately (i known xray don't do them possibly another manufacturer)?
boosta1276 is offline   Reply With Quote
Old 03-14-2010, 03:03 PM   #2276
Regional Moderator
CarbonJoe's Avatar
I've been using the thrust bearings from AvidRC.com
They are $3 each instead of $27, so if they last a month, it's worth just replacing them.
Old 03-14-2010, 03:14 PM   #2277
thnks for that joe what are the measurements on the internal holes on the plates are they the same as the xray version (3.0mm + 3.2mm)?
Old 03-14-2010, 03:35 PM   #2278
Regional Moderator
CarbonJoe's Avatar
No, I think that they are just 3.0mm on both sides. They work just fine, though.
http://www.avidrc.com/product/13/thr...-bearings.html
Old 03-14-2010, 04:10 PM   #2279
Cheers Joe
Old 03-14-2010, 08:54 PM   #2280
Potoczak's Avatar
Trader Rating: 112 (100%+)
Hey Xray guys out there, i need to know if xray has ever changed the length of the shock bodies on any of the xray cars ( 08,09,t3). i am talking about the plastic ones not aluminum ones? I was going to replace one of the shock bodies on my 009 and the extra shock body i have is a little longer. Any input would be great. THANKS
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
