XRAY T2009
Old 02-24-2010, 02:47 PM
  #2221
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
what type pf surface i can see this on asphalt but i run on carpet
TRXRACER99 is offline
Old 02-24-2010, 04:05 PM
  #2222
sell682's Avatar
Trader Rating: 81 (99%+)
I need some gearing advice. I have a 17.5 lrp motor and a techin rs pro ecs. What gear ratio should I try. The track I run at has long straights and two chicains. What internal ratio should I have 1.7 or 1.9. Thanks a lot in advance.
sell682 is offline
Old 02-24-2010, 04:18 PM
  #2223
Andy63's Avatar
total ratio you should have about 4-5 depends how long straight is.
www.andrefossto.wordpress.com
Andy63 is offline
Old 02-24-2010, 05:28 PM
  #2224
Default reduce front end wobble
my front end wobbles alot, but only on 45 or more steering. I heard the ECS shafts help out alot, but are very expensive.
Is there a quick and cheap alternative to fixing this problem? I know cheap and xray dont really go hand in hand
captain stacker is offline
Old 02-24-2010, 09:46 PM
  #2225
Cribbin's Avatar
yeah i run ashpalt sorry i didnt think about that lol
Cribbin is offline
Old 02-25-2010, 12:18 AM
  #2226
Professor's Avatar
the ecs drives do help heaps xray ones are expensive but there is another brand (atomic i think is the brand mr cribbin can confirm ) also are equally as good & a lot cheaper, once again mr cribbin can confirm as he runs them
hope this helps
Professor is offline
Old 02-25-2010, 05:27 AM
  #2227
Dane's Avatar
Trader Rating: 24 (100%+)
Also make sure the driveshafts remain clean and well lubed. I also found that adjusting the ackerman can help with the vibrations.
Dane is offline
Old 02-25-2010, 05:48 AM
  #2228
thanks guys, the atomic ones look like xray's ECS but half the price, will give them a go!
Old 02-25-2010, 06:18 AM
  #2229
M-Technic's Avatar
Trader Rating: 15 (100%+)
The Atomics are also half as strong as the Xrays. I haven't seen a set last more than two weekends or so.
M-Technic is offline
Old 02-25-2010, 09:34 AM
  #2230
Dane's Avatar
XRAY might be more expensive, but you definitely get what you pay for.
Dane is offline
Old 02-25-2010, 03:54 PM
  #2231
Kodak Hodak's Avatar
Hey Guys,
As always i build and do blogs, currently in progress my new TOY the Xray T2PRO - http://xrayt2pro.blogspot.com/ will get some info attached to photos and setup sheets for the TEKIN speedy....
Enjoy
Frankie
Kodak Hodak is offline
Old 02-26-2010, 03:02 PM
  #2232
padailey's Avatar
I've got a '009 for sale locally but am having 2nd thoughts. I like how the car works but I've got a problem. It breaks almost every time I drive it. In our 17.5 TC class about 90% of the cars are T2's of some sort, but my '009 is the only one that breaks. C hubs, arms, steering blocks have all broke regularly. The other XRAY guys are shocked mine breaks so easily... I don't get it. Main difference is they have alum steering blocks. Don't want to spend the dough on them if I'm just going to keeping breaking other parts. I spent the money to have tough car.. but this about as brittle as anything I've ever had... maybe the worst.
Some thought it might be the spool so I put in a diff and it still broke. I'm not saying this to knock the car I just have NEVER seen an XRAY break like this.
Any thoughts?
padailey is offline
Old 02-26-2010, 03:15 PM
  #2233
clparsons123's Avatar
I don't know since Ive had my car Ive only broke a steering block . it be if your running softer parts (medium steering blocks or rear up rights) but truly i have never seen a broken xray arm so im lost with that one
clparsons123 is offline
Old 02-26-2010, 03:44 PM
  #2234
Dane's Avatar
Stay off the boards
Dane is offline
Old 02-26-2010, 05:53 PM
  #2235
few things...
1. do 48p gears fiit?
2. how do you guys like the chassis protectors?
3. what would be a good starting fdr and profile on an spx on an open asphault track? its 17.3 with and express duo2 motor.
Thanks,
Hayden
shaggy11 is offline
