Old 01-25-2010, 10:44 AM   #2176
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Originally Posted by rodneybarrett View Post
Can someone post a picture of a 9550 mounted in the Xray and the horn you are using. The horn I have hits the servo case in one direction and cannot get the 90 degree angle the manual talks about.
thanks.
I know what you mean, I had the same problem. I just trimmed down the part that hit the servo so it cleared (just). You may also need to trim the thread on the ball joint.
dontfeelcold is offline   Reply With Quote
Old 01-25-2010, 10:49 AM   #2177
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Is there an intelligent way to tell which belt is slipping?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 01-25-2010, 11:00 AM   #2178
rcterp's Avatar
Trader Rating: 35 (100%+)
Look at the teeth on the belt, if it's slipping it'll start looking worn.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 01-25-2010, 09:28 PM   #2179
Potoczak's Avatar
Trader Rating: 112 (100%+)
Hey Guys does anybody know where i can find the shock standoffs, i have been looking on every site but cannot find them????
Potoczak is offline   Reply With Quote
Old 01-25-2010, 11:12 PM   #2180
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
shock standoffs as in the 1.5mm shims for between the shock tower and the shock cap?
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-26-2010, 12:12 AM   #2181
xray2050's Avatar
Trader Rating: 14 (100%+)
So far so good with the Tough Belts.
xray2050 is offline   Reply With Quote
Old 01-31-2010, 07:09 AM   #2182
JRXS_chris's Avatar
How do you guys balance this chassis using Lipo running at 1350gs? The only way I can do it is with a slight overhang of the Lipo.
As you can guess by my user name balancing hasn't been much of an issue for me in the past
JRXS_chris is offline   Reply With Quote
Old 01-31-2010, 08:18 AM   #2183
Its pretty much a necessity to hang the lipo out of the car.
I'm using the lipo weights, car is balanced and the lipo is secure, however its 30g overweight. Looking at making a carbon lipo holder to move the battery out further and still use a strap to hold the battery in.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 01-31-2010, 09:10 AM   #2184
I use the LiPo weight kit in my T2'009, and tried putting equal weight in all 4 corners (to get the weight up) and it was actually battery-heavy (with LiPo!) - removed 5g from the battery-side and it was balanced perfectly.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 01-31-2010, 10:04 AM   #2185
JRXS_chris's Avatar
It's normal then. That's good.
I'll have to make some of them 'L' things I see all the time
Old 01-31-2010, 11:09 AM   #2186
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
at the novak race i had
1 t2 009
2 tekin rs (short wires)
3 trinity duo2
4 futaba digital non low profile
3 true rc 5000 2s lipo
jaco blues
battery tray (slot type) weighed about 100g
i had to add 3 7g waits behind the motor
with body and clips and transponder this all came out to be 1426g 1 g above minimum weight. i had the lipo slanted out enough to were it was not hitting the top deck
hope this helps.
Aric
TRXRACER99 is offline   Reply With Quote
Old 02-03-2010, 06:10 PM   #2187
just wondering if anyone has tried the exotek lipo chassis? would like to hear feedback if you have. thanks
franc furter is offline   Reply With Quote
Old 02-05-2010, 06:22 PM   #2188
Trader Rating: 19 (100%+)
most of the time its your rear belt because it has more pressure on it than the front belt but listen to rcterp he know these kinds of thing i race with him every weekend
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-05-2010, 11:29 PM   #2189
fullout's Avatar
Send a message via MSN to fullout
My 009 shows no signs of the rear belt skipping, but the front is for sure. You can see what looks like wear on it. I bought a replacement front but never bothered getting the rear. This is on my 009 running 13.5 rubber tires on carpet with a spool. Hopefully this helps.
fullout is offline   Reply With Quote
Old 02-06-2010, 11:37 AM   #2190
Trader Rating: 198 (100%+)
If anyone is interested in some parts I have some for sale.
http://www.rctech.net/forum/r-c-item...-t3-parts.html
http://www.rctech.net/forum/r-c-item...ht-600cst.html
http://www.rctech.net/forum/r-c-item...outdrives.html
http://www.rctech.net/forum/r-c-item...es-shafts.html
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
