Old 01-10-2010, 04:14 AM   #2161
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Fast XXXS View Post
Whats the difference between the ECS drive pins, the ones with the flat spots or ones without, i know the ones with the flat spot are longer. I am wanting to get some spares, will either fit?
there are 2 different size pins in each driveshaft. I long and 1 short. Get the flat spot versions of each.
Hope that helps
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-11-2010, 04:14 PM   #2162
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
anyone else running 38/20T (1.9 gear ratio) from the T3 EU on their T2 009 EU? if so what is a good pinion to start out with? I have a Tekin RS running a 17.5 Tekin Redline...the first test is this wednesday, what do you guys think? thanks
badKarma is offline   Reply With Quote
Old 01-11-2010, 06:17 PM   #2163
badKarma's Avatar
more clarification on the above...I have 38/20T (1.9 gear ratio), and have a 106 spur...
Old 01-11-2010, 08:44 PM   #2164
Benzaah's Avatar
Trader Rating: 21 (96%+)
More info on your speedy settings are needed for a decent fdr range. the Tekin has turbo and if your using this then your better off asking in the Tekin thread for advice on this.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 01-12-2010, 09:35 AM   #2165
badKarma's Avatar
ok about the speedo settings...but is anyone else running the 38/20T (1.9) settings on their T2 009 EU?
Old 01-12-2010, 10:06 AM   #2166
dubble-m's Avatar
Hi Karma,
There's a good starting hotwire set-up on the Tekin website for 17.5 rubber.
http://www.teamtekin.com/hotwire/ESCsetups/index.html
As for FDR, try starting at 108/35 for an FDR of 5.86. I run a T2 009 with the 38T/20T pulley configuration and this combo works very well for indoor carpet.
Hope this helps.
MM
dubble-m is offline   Reply With Quote
Old 01-12-2010, 10:17 AM   #2167
I have a T2'008 running 38/20 (1.9x), but its 95% similar to 009 and I use Tekin RSpro + 10.5R rubber on asphalt. So far 1.9x with stock/super stock motor is very good. I use 48p pinions though
Tekin has Sensored and Dual mode:
For Dual mode + 17.5R, you can try FDR between 4.5 and 5.5, so pinion between 37 and 44
For Sensored mode + 17.5R, you can gear down and add timing/turbo. your FDR can increase to 6.5'ish, so pinion of size 31.
hardmankam is offline   Reply With Quote
Old 01-17-2010, 10:40 PM   #2168
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Originally Posted by dubble-m View Post
Hi Karma,
Mmmm
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 01-18-2010, 12:32 AM   #2169
Running a Nosram Stock Spec (Profile 7) with Tekin 13.5t (Timing on motor was 12 degrees) on the track attached. 38T pulleys and I was on 22/84. Worked perfect, loads of drive out of the corners but plenty of speed into the sweeper.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 01-18-2010, 11:41 AM   #2170
Trader Rating: 49 (100%+)
Default Futaba 9550 servo help
Can someone post a picture of a 9550 mounted in the Xray and the horn you are using. The horn I have hits the servo case in one direction and cannot get the 90 degree angle the manual talks about.
thanks.
rodneybarrett is offline   Reply With Quote
Old 01-18-2010, 11:46 AM   #2171
rcterp's Avatar
Trader Rating: 35 (100%+)
thanks.
I don't have a picture handy; but, are you using the spacers in front of the servo mounting tabs? That should get you in the ballpark.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 01-18-2010, 11:53 AM   #2172
Regional Moderator
CarbonJoe's Avatar
thanks.
You need to use some spacers to get everything to align. These are the parts you need (and should have gotten in the kit):
http://ashfordhobby.com/detail.aspx?ID=6140
Just use the servo horn marked "F" for Futaba.
The actual swing of the servo horn for the turning radius isn't anywhere near 90 degrees.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-18-2010, 05:52 PM   #2173
hollywood tc5's Avatar
hey guys what the deal with that exotek chassis good bad more consistent
BOSS MOTORSPORTS
wrecking ball,sox,hollywood
BOSS MOTORSPORTS
hollywood tc5 is offline   Reply With Quote
Old 01-19-2010, 11:03 PM   #2174
Default toughracing.com drivebelts ??
Hi there. Has anyone used the toughracing drivebelts. They are 1/3 the price so could save a fair few $$ over my 2 cars. (my 007 has gone hrough a few belts, 008 OK so far..)
http://www.toughracing.com/zc126d/in...&cPath=161_169
http://cgi.ebay.com/Xray-T2-008-009-...item3efc24eb46
1101 is offline   Reply With Quote
Old 01-25-2010, 06:48 AM   #2175
slolx50's Avatar
Why exactly do the two versions ( EU vs. US) use two different driveshaft lengths (52 vs 50)?
And if running rubber tires on the US or Foams on the EU require a change of shafts?
www.TheRCShack.com <----Check them out!
slolx50 is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
