Old 11-08-2009, 02:56 PM   #2041
Default Pin (10mm) getting loose in T2 drive axle (front transmission)
Hello
Can someone help me with the following problem?
I'm driving a T2'009 EU-version with a one-way axle (instead of a spool). The pin (10mm) in the T2 drive axle (front) is getting loose while driving. I've followed the instructions meaning that I did the greasing of the T2 drive shaft coupling and the drive shaft 52 mm, and thread locking the hex screw SB M3x2.5.
Although the hex screw is still tight, the pin gets out of the T2 drive axle at one end, hitting the composite steering block. And because of this the T2 drive axle doesn't work like it should (because the pin is sticking out the drive axle on one side).
I hope you understand what I'm trying to tell...
boba.slave is offline   Reply With Quote
Old 11-08-2009, 03:33 PM   #2042
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Originally Posted by boba.slave View Post
Hello
If you crank the screw down tight enough it should stay. If you can't get it tight enough you have two choices.
1. Cut a notch in the pin so the grub screw can sit in the notch to keep it from moving. Kind of like notch in the pin that holds on your C-Hubs.
2. Heat shrink the ends of the axels.
ChristopherKee is offline   Reply With Quote
Old 11-08-2009, 04:42 PM   #2043
cyclone x's Avatar
anybody selling a 009 us edition if so pm me please thanks
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 11-14-2009, 07:25 AM   #2044
Default Xray T2 009 inner ackermann question
I have the Eu spec 009, in the instruction book it says build with the notch in the top deck and chassis facing forward, what difference will it make having it face the rear ????
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 11-14-2009, 07:58 AM   #2045
thisguy2849's Avatar
Hello
I had this same problem with my 09 nd the solution was to contact rcamerica and get the proper length pin.
thisguy2849 is offline   Reply With Quote
Old 11-14-2009, 11:39 AM   #2046
fullout's Avatar
Send a message via MSN to fullout
Hello
This exact same thing happened to me. Every run the pin in the cvd would come out. It seemed the grub screw wasn't gripping the pin hard enough . I rebuilt it a few times making sure i thread locked it but the same thing kept happening. So i took both front cvd's and tried switching the grub screws and sure enough it worked. Must of been a small machining issue i guess. But now all is well. On the upside, all my friends running other brands were having all kinds of other issues, so to me this was a minor issue with an easy fix. These are great cars overall.
fullout is offline   Reply With Quote
Old 11-14-2009, 04:50 PM   #2047
lbckevin's Avatar
Trader Rating: 91 (99%+)
Check out the for sale section... Dodgeguy is selling a nice one, so is SOHLMAN
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 11-15-2009, 12:37 PM   #2048
Any one ??
Old 11-15-2009, 06:30 PM   #2049
Any one ??
Changes ackerman and steering throw.
Old 11-15-2009, 10:08 PM   #2050
Trader Rating: 23 (100%+)
I can vouch for Dodgeguy's car. He sits right next to me in the pits and is very maticulous about his stuff. He's selling as he has a new T3. You won't find one better!
SteveL is offline   Reply With Quote
Old 11-16-2009, 02:53 PM   #2051
Trader Rating: 25 (100%+)
Can anyone tell me if they see a difference in the way the car drives with the 38tooth pullies? I am running 17.5 rubber, I am using 34 tooth pullies now, just wondering if its something to try.
matt rem is offline   Reply With Quote
Old 11-16-2009, 02:56 PM   #2052
The Evicerator
The 38/20 conversion smooths out the transitions in handling between on and off power.
Overall it makes the car drive more consistant to me.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 11-16-2009, 03:29 PM   #2053
lbckevin's Avatar
Steve...
what pinion and spur are you running in your car for 13.5 ? I sold my tamiya and got a new xray.
Kevin Smith
Old 11-16-2009, 10:05 PM   #2054
mtbboy's Avatar
Gentlemen.....
And Mr, Weiss.
Is there any reason that the t3 setups wouldn't be transferrable to the 009?
And if there is how exactly.?
Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 11-16-2009, 10:30 PM   #2055
Monster Myers's Avatar
Originally Posted by DOTMAN View Post
I have a Brand new, Unassembled, Orange T2'009 rubber kit for sale for $425 shipped. I have only sealed the chassis and shock tower edges with CA.
PM me if interested
YHPM
Monster Myers is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
