Old 10-30-2009, 08:17 AM   #2026
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Potoczak View Post
What kind of steering servo are you guys running in the 009, looking to finish up by build, thats the last piece i need to get it on the carpet and start testing>>>
I fun a futaba 9551... bitchen lowpro, digital, all metal gear servo. Fair price too.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-30-2009, 08:23 AM   #2027
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
The Futaba 9551 or KO 2413 seem to be popular. They are both low profile.
ChristopherKee is offline   Reply With Quote
Old 10-30-2009, 12:24 PM   #2028
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by RC8 View Post
Disect away! It still is borderline traction rolling, it needs to be driven very smoothly to prevent traction rolls. It is, however, pretty fast. I got within .1 second of Jeremy's lap record.
Why in the world are you running that stiff of a spring with rubber tires? When I talked with Pauly he said a stiff spring can make traction rolls worse. I would think you would want to go down to nothing higher than a 20 on the front and around a 15 on the rear.
Does the car traction roll right away or does it roll after awhile?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-30-2009, 12:49 PM   #2029
ottoman's Avatar
R/C Tech Charter Subscriber
35 LB front springs
I dont think we ever went over 17.5 lb fronts at the Novak and thats a high traction race
ottoman is offline   Reply With Quote
Old 10-30-2009, 12:56 PM   #2030
Suspended
GordonFreeman's Avatar
RC8 here (old account)
Just thought I needed to try something cause nothing else was working, it seemed to help a bit.
Gonna try wider front track next.
It's hard to tell where exactly it's traction rolling, I think it is mid corner.
Would too much rear toe cause this problem?
Oh, does anybody know what the "c" rated springs are for lbs/in?
We are the borg, you will conform, you will be assimilated. You will not stalk me to another web site.
GordonFreeman is offline   Reply With Quote
Old 10-30-2009, 01:02 PM   #2031
This is a very good set-up on high grip. This pretty much my starting set-up everywhere I go.
http://forum.teamxray.com/xform/inde...3&setup=t2_008
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 10-30-2009, 05:45 PM   #2032
Skiddins's Avatar
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-30-2009, 06:18 PM   #2033
Suspended
Originally Posted by Cpt.America View Post
Stiffer springs and oil
Hmmm...so which is it, I don't have the Xray bible in front of me. I would think stiffer spring would produce less body roll, isn't that what you would want if you are traction rolling?
Thanks for the spring chart, nice.
Old 10-30-2009, 06:51 PM   #2034
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
any time someone gives info from paulie, it is right......he told me the same thing
Team Losi Racing-Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 10-30-2009, 08:12 PM   #2035
RBLove's Avatar
Trader Rating: 72 (100%+)
A stiffer spring will not the let the car roll/lean. Once your tires grip the car has no place to go but on its lid. A softer spring will allow the car to roll as the tire grips.
RBLove is offline   Reply With Quote
Old 10-30-2009, 08:29 PM   #2036
nitro neil's Avatar
Trader Rating: 73 (100%+)
i have a problem. ive been trying to get my rear end softer and for some reason i just can't get it done. ive tried softer springs and thinner shock oil. I thought i may have binding in the suspension and i didn't.I'm using the standard plastic shocks w/3 hole pistons, yellow springs. mounted in the third hole from the top on the shock tower.any help is greatly appreciated
TLR, SPEKTRUM,HORIZON HOBBIES, JCONCEPTS, Tekin, MIP, ONeill Brothers Racing, Axis RC, Large Scale RC, Boom rc, Team Chase,
nitro neil is offline   Reply With Quote
Old 10-30-2009, 10:30 PM   #2037
If it traction rolls early, you're too stiff. If it traction rolls late, you're to soft. If you pull the throttle and it just flips over, you're... screwed
For early just go softer spring, for late roll try a heavier bar first, then spring. If you're on foam glue the outside edges, if you're on rubber, stop putting compound on the outside fronts. If you roll mid turn... well... I usually get the rear to slide a bit more... but thats me.
Old 10-31-2009, 01:49 AM   #2038
I have a Brand new, Unassembled, Orange T2'009 rubber kit for sale for $425 shipped. I have only sealed the chassis and shock tower edges with CA.
PM me if interested
DOTMAN is offline   Reply With Quote
Old 10-31-2009, 09:34 AM   #2039
Skiddins's Avatar
WHat makes you think it isn't already getting softer?
What are you trying to achieve?
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-31-2009, 03:26 PM   #2040
Suspended
Well, things are looking up. I glued the sidewalls of my tires, widened the track front and rear about 1mm/side and I am now using the Xray front brace. It bolts to the front of the chassis to stiffen it up I think.
Still turning a few 11.0s, we will see what happens tomorrow if and when traction comes up.
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
