Old 10-15-2009, 01:24 PM   #1981
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
Originally Posted by yokemad View Post
38/20 needs longer belts
I think T3 will come like that 1.9...
i have the pulleys...what is the belt part number???
Team Losi Racing-Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 10-15-2009, 08:20 PM   #1982
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can anyone tell me the size of the holes in the 3 hole pistons (not adjustable)
that come with the 009 eu kit shocks (plastic shocks)
LOSI123 is offline   Reply With Quote
Old 10-16-2009, 04:22 AM   #1983
Originally Posted by FLAT OUT View Post
I have noticed a quite alot of play in the steering of my 009, Mostly this is where the front upper camber link joins the c hub. I can wiggle it around and see the top screw that joins the camber link to the c hub moving. Has any one used the new XRay 302661 5mm closed ball ?? did they cut out the slop. Does any one have any tips to get rid of slop/play
Any one ???????? And yes I have built the c hubs correctly
FLAT OUT is offline   Reply With Quote
Old 10-16-2009, 06:18 AM   #1984
kartermdb's Avatar
Trader Rating: 15 (100%+)
305432 for front and 305446 for rear
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 10-16-2009, 06:56 AM   #1985
Skiddins's Avatar
If I recall they have two or three different sizes of hole on the sprue, not just the number of holes.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-16-2009, 07:09 AM   #1986
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
The ballcups are alot better for reducing slop, but the problem will still exist after a while. On my car the play just comes from the cup becoming loose. So im just going to replace the ball cups for the next big race meeting. The other spot is the steering link( Arm from the servo). Hold that arm, and see how much slop is reduced. I havent got a ball cup there, but i might put one there now since i have discovered this.
But yes the Ballcups are heaps better
Hope that helps,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 10-17-2009, 04:27 PM   #1987
LOSI123's Avatar
it seems as if they are 1mm holes in all of the plastic shock pistons (non adjustable pistons)
as my 1mm drill bit fits in all holes really tight and snug.
And whats with this thread droping in popularity almost instantly at the sniff of a new xray, a bit sad , t he other day i had to search page 3 to find it.
Old 10-17-2009, 10:38 PM   #1988
Trader Rating: 23 (100%+)
Where are the best deals for the 009 right now?
MDawson is offline   Reply With Quote
Old 10-17-2009, 10:49 PM   #1989
RCFREAK's Avatar
Trader Rating: 17 (100%+)
for sale forums.... just keep lookin out for them, since new car will be released soon....
Arv.
EA MOTORSPORTS// KO PROPO// ORCA// 180 RACEWAY
RCFREAK is offline   Reply With Quote
Old 10-18-2009, 03:21 AM   #1990
if you are getting rid of your tc5 let me know
redline1 is offline   Reply With Quote
Old 10-18-2009, 03:50 AM   #1991
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default Batteries
Hi Guys,
I am about to buy some new batteries, i want to buy ones with deans plugs. I have the lipo battery weights, so the batteries does stick out a little.
I am after 5000 with the highest c rating, and must be roar approved.
What ones are the best to get ( racing stock )
regards
Brad
Yokomo BD818 | Sanwa | HW | Zombie | Team Yokomo | Meakin Park | Bayside | Hearns Hobbie | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 10-18-2009, 05:41 AM   #1992
Originally Posted by OHBRAD View Post
Hi Guys,
regards
Brad
Probably go with the smc 5200 50c
Antoni
Antoni Caretti
Old 10-18-2009, 10:34 PM   #1993
WheelNut's Avatar
Send a message via MSN to WheelNut
Thought I'd share the mod I did to my T2 today. It's an 007, but I figure this would work exactly the same on an 009. This setup is a little bit different than most of the lipo wieght mods I've seen, because the weights are running right next to the centre line of the car. The best part though is that it is really cheap, and if your in college like me that is quite important!
It's not too pretty yet since I just threw it together today, so there is a bit of finishing that needs to be done on the battery retainers. The battery retainers were made from an old XB8 TQ radio tray I had lying around. The black anodizing is cool. I've got to redo the wiring as well since the power wires are to short to reach now. I also had ripped out all the electronics in an attempt to mount the on the battery side of the car, which wasn't a problem for the ESC (Tekin FX Pro, tiny), but after much rearranging I felt that this setup would put more mass to the centre of the car.
The lead running down the centre holds the battery in place and is taped in with Parma silicone tape. I've got 144g of lead there. The car weighs in at about 1450g. We are using a 1500g limit up north here this winter, so I've got to add a bit more weight yet, but we'll see what the tech scales read first. My scale is a postal style spring loaded scale, so I can't imagine it's ultra accurate.
The car should balance R/L perfectly once I mount my motor cooling fan. The battery is an SMC S-Max 4500mah, which weighs in at about 250g (If I remember correctly).
The best part about this is that there are no weights placed at the extreme front, rear, or right side of the car. All the ballast weight goes right down the centre. Plus the weights are mostly hidden.
Carpet season doesn't start here for a few more weeks yet, so it'll be a little while before I get a chance to test this setup out on the track.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 10-20-2009, 05:33 PM   #1994
Default Xray 009 spring rates
Could some one tell me the spring weights for the 009 springs i.e 2.2 = 16lbs 2.4 = ?? and so on. thanks
Old 10-20-2009, 06:38 PM   #1995
Benzaah's Avatar
Trader Rating: 21 (96%+)
Hi Guys,
regards
Brad
Antoni
Plus 1
I have the smc 40c packs and they are the ducks guts. They fit nice and snug with the lipo weight set too. Nexus racing will be your best bet to get them quick. http://www.nexusracing.com/product_i...oducts_id=2928
Adelaide RC - XRAY Xb2’16de & Xb4’16
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
