Old 10-01-2009, 09:16 PM   #1906
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by IIGQ4U View Post
Glad that Steve was able to help. He has been a great help to me as well. How did you do at Ripon?
Do you race around norcal?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-01-2009, 09:25 PM   #1907
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Originally Posted by LOSI123 View Post
Help needed,
Near the end of my t2009 eu build manual it shows putting the front shocks on the car and it has a note saying to space out the shocks as an option and it will make the car easier to drive/less steering. my ? is that it says do this for the "FRONT " shocks next to the rear & also the front shocks.
Anyone know what it does for the back end / front end.
surly its a bit of a typo, maybe?
Have used (top+bottom) of front shocks spaced on low/med grip successfully, it was nicer to drive
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 10-01-2009, 09:30 PM   #1908
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
No, I am in SoCal and so is KingofBMain. What are you doing in the XRAY thread?
IIGQ4U is offline   Reply With Quote
Old 10-01-2009, 09:33 PM   #1909
Ohhh. Your no fun
Haha thought id stop by. Your car looks sick BTW. Those black wire markers are sick. I got me a few
Old 10-01-2009, 09:35 PM   #1910
IIGQ4U's Avatar
Thanks, I told you that they are legit. Your new body is sick, as well as your new car.
I have been lurking in the Mi4 thread a lot
Old 10-02-2009, 01:01 AM   #1911
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
That's XRAY's fault, not mine. I can't rotate the shaft 90 and reinstall. My issue with the ECS is the fact that mine are binding. The couplings are binding in the shaft. Thread lock is not the culprit either... I am going to send them in to Hudy America as I just purchased the units.
The ECS' can't be assembled "out of phase". Yours aren't out of phase either. Assuming you rebuilt them and greased them properly with Hudy graphite grease before installing them, you should pull them out and disassemble them, clean all parts thoroughly and reassemble one piece at a time checking for binding at every step. If you find the couplings are binding, try interchanging them to see if they have a better fit in a different position.
Also, looking at your pics, are you aware there are two different length pins? Each shaft takes one short and one long. It looks to me like you have both long pins on one shaft... an easy mistake to make if you reassembled them at the same.
BigDogRacing is offline   Reply With Quote
Old 10-02-2009, 01:05 AM   #1912
Chris Adams's Avatar
Lutz to the rescue!
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 10-02-2009, 02:39 AM   #1913
LOSI123's Avatar
Trader Rating: 63 (100%+)
thanks
Also anyone know is the muchmore shock oils are rated the same as xray shock oils.
i know they are both in the hundreds and not tenths eg: 300 350 400 etc.....
kit setup of my 009 eu has 350 oil and i noticed a lot of pro driver setups stating 600 and 700 shock oil?
LOSI123 is offline   Reply With Quote
Old 10-02-2009, 04:00 AM   #1914
Skiddins's Avatar
thanks
CST ratings for oil, 350, 500 etc are linear, meaning 600 has twice the viscosity of 300 etc.
Where as the 'W' ratings are not 'tenths' of the CST ratings, they are a different system of measurement (not a very good one) and are not linear, has no known standard, and subsequently varies from manufacturer to manufacturer
Yes, I believe that the CST ratings should be virtually the same between Much More and Xray
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-02-2009, 04:37 AM   #1915
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
[QUOTE=LOSI123;6418967]thanks
QUOTE]
They are close but not exactly the same. Ive got all the muchmore oils cause they are just as good as the xray oil And alot cheaper. They arent the same though because the xray 350 is alot thinner than the muchmore 350 They are the only ones i can compare...
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 10-02-2009, 07:46 AM   #1916
IIGQ4U's Avatar
I have already done that and assembled them one at a time. Remember, I have three of these. The steel coupling is binding inside of the shaft. I tried to switch them and same result. I am sending them back to Hudy America and hopefully they can take care of the problem.
Old 10-02-2009, 02:01 PM   #1917
gonzo416's Avatar
Trader Rating: 39 (98%+)
I need help!!
I rebuilt my diffs but they are still gritty. I have rebuilt them many time before and this has never happened. I sanded the rings on the thrust assembly and diff rings.
gonzo416 is offline   Reply With Quote
Old 10-02-2009, 02:05 PM   #1918
Originally Posted by gonzo416 View Post
I need help!!
Change out the cone washers. Best bet is to just get a new diff next time.
Texas EOS 2018!
Old 10-02-2009, 02:50 PM   #1919
Trader Rating: 33 (100%+)
I need help!!
Most of the time it's the thrust bearing, you may need to replace it.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 10-02-2009, 03:19 PM   #1920
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
100% garantee you the problem is that loctite touched your graphite grease. If it touches at all, it spreads around to all the grease and turns it into like a glue. Iv done it myself, and have fixed the exact same issue on other xrays who had the same problem.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
