Old 09-27-2009, 12:55 PM   #1861
Originally Posted by sm1nts2escape View Post
alittle more progress.The parts quality is top notch.The axles were a joy and are very light.
[IMG][/IMG]
just a little tip put some glue around the shock towers and top deck like u did on the chassis
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 09-27-2009, 04:19 PM   #1862
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
I'll do the body tommorow but this is as far as I am going to go till I get my electrronics.The build went along very nice but I have about 2.5 degrees of slop in the front knuckles that I need to eliminate.
[IMG][/IMG]
sm1nts2escape is offline   Reply With Quote
Old 09-27-2009, 05:28 PM   #1863
Con
I use the .010" shims out of #3911 assoc shim kit under the C-Hub bushings to take up that slop
Con is offline   Reply With Quote
Old 09-27-2009, 09:03 PM   #1864
Johnny Wishbone's Avatar
Originally Posted by CREWMAN View Post
Considering getting back into electric tc. the only difference between the 008 and the 009 is the anodizing and the top deck on the 009 is more lipo friendly correct?
I would be doing rubber on carpet so that means i want the euro kit right?
Thanks in advanced for any suggestions
Motor and battery placement are different as well.
Old 09-27-2009, 09:04 PM   #1865
Don't glue the top deck IMO.
Old 09-27-2009, 10:49 PM   #1866
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I sand the edges of the top decks and towers, less chance of splinters in the fingers and for the top deck to avoid chafing if the battery leads when rubbing on the edges. my $.02.. and also check and rechek the chassis adn top deck screws after acouple of runs, they tend to back out even with some light blue Loc-Tite.
But other than that have fun and you will be smilling ear to ear when it's dialed in
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 09-28-2009, 01:45 PM   #1867
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Whoever said xray instructions are the best lied!pics and pn's are all I see.Like when they have you build the arms the pins are shown with a pn but no measurments!I have a caliper and it would be easier to use that then examine the pics and refer to the parts list.
What? The xray instruction booklet is just awesome. They have "actual size" pictures of every single piece, great descriptions, awesome 3d cad pictures... a full and complete setup book.. the works. Nothing comes close to the Xray instruction book. If you're having problems... it isn't the book.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-28-2009, 02:08 PM   #1868
Goingfast's Avatar
Trader Rating: 29 (100%+)
ouch
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 09-28-2009, 02:52 PM   #1869
FK05 lover's Avatar
Trader Rating: 147 (99%+)
+1 go have a look at the quality of the others instructions manuals.....
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 09-28-2009, 03:02 PM   #1870
I agree, I have had a few touring cars over the years and the Xray instuctions are way better than any others
FLAT OUT is offline   Reply With Quote
Old 09-28-2009, 04:44 PM   #1871
I thought my mugens mrx instructions were better.They had the sizes of everything right there beside the pic of the part with the pn too.But like I said earlier I must have just been mad and not looking at them good enough cause the next day I had no problems.Thanks for the tip with the shims that is exactly where the play is coming from and that should take care of it.
Old 09-28-2009, 04:53 PM   #1872
Super Moderator
Yes, the sizes are there. With the Xray, the name of the screw refrences it's length... 10, 12 are 10 or 12mm screws for example.
- RCSpecialties -
Old 09-29-2009, 02:00 PM   #1873
Picked up an T2 009 a few weeks ago, very good quality. Managed to squeeze in a lipo pack with the standard top deck, took some trimming of the lugs on the bottom.
The reciever has been pinched for use in my 808 for the last few dry races of the year. Need to get some JR connectors to shorten up the servo and esc leads.
Just finished adding 140g of weight to bring it up to 1500g, plus a bit for tyre wear.
Any good base setups I can try for rubber tyres on indoor carpet tracks and also outdoors.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 09-29-2009, 08:32 PM   #1874
FK05 lover's Avatar
Standard set-up is never too far from the mark...a good start point
Old 09-30-2009, 05:09 PM   #1875
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Default T2r Pro
Looking to get into onroad racing. I happened to come across the T2r Pro. Just wanted some insight to see if this car is good for racing asphalt and carpet. I'm an experienced racer in offroad, but not really in onroad. So if somebody can give me some pro's and cons on getting this car. I would get the 009, but the car is to expensive for me.
Chad Burdick
ChadB. is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
