XRAY T2’009
#1817
Just about all the plastic pieces fit all three cars. Everything you listed will interchange. In fact the 009 EU chassis will fit the 007.(At least the excel spreadsheet I have from RCAmerica says it will) The main differences from 007 to 009 is bulkheads, shocks are a little shorter, and top deck.
#1818
The Evicerator
TTT!
#1821
#1823
I'm wrong, the 007 arm outer pin hole is maybe about 1mm shorter that the 008/009, sorry.
#1825
For sure they will work, like I said you have to change them out in pairs though as the lower shock mount will be whacked from one side to the other.
#1826
The 007 front arms have 2 shock mount positions while the 008/009 has 1. The length of the arm is the same. The width at the arm on the inner pin is narrower on the 008/009 car. So you will need a total of 2mm shimming if you use a 008/009 arm on a 007.
The rear arms on the 007 are narrower and has 2 shock mount locations. Where as the 008/009 only has 1. We normally run the 007 rear arms on the 008/009 foam car not on the EU car.
Both 008/009 front and rear arm shock mount locations is the center between the 2 holes on the 007 arms.
#1827
#1829
Sorry, all I did was answer the mans question, he asked if the parts would work, and the answer was yes. But thanks for the details, I'm sure he appreciates it.
And FK, it's not your time or money to waste.
I actually had to look that acronym up.
But yes I do know some racers use the 008/009 arms on the 007 to achieve the middle shock mount location on the arm also. Just one more tuning option alot of racers don't think about.
