Old 09-21-2009, 09:07 AM   #1801
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Skiddins View Post
All chassis do the same,
My TC4's dont' chatter at all.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-21-2009, 03:53 PM   #1802
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Originally Posted by pcar951 View Post
Anyone tried the fiberglass (T2R) chassis on low grip yet??
There's one at our home track who seems to quite well on low grip though I would imagine set up would be different due to the greater flex..
Also encounter one at a high grip track recently + it was a rocket..
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 09-21-2009, 04:00 PM   #1803
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I love the T2R-PRO. The flex in the Chassis is awsome for parking lot tracks. I said it before when others are practically driving on ice and having a drift race the T2R WILL dominate the race, even on carpert/rubber racing and high bite asphalt. I even put the cassis on my 008 for some added flex.
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 09-21-2009, 07:42 PM   #1804
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Phew, glad you got that right,lol. I pm'd Mr Alt some of my findings...
I'm about to make some changes for 10.5 now. Too much on power push.
Got the front roll centers in mind (lower). Its got a touch more exit power than the 17.5 .....
I call my Pro - a FLEX-RAY.
fleetmaster is offline   Reply With Quote
Old 09-21-2009, 09:04 PM   #1805
FK05 lover's Avatar
Notice I didn't mention any names...Don't want you getting a big head now..
Old 09-22-2009, 07:01 AM   #1806
yokemad's Avatar
Hi guys
Sorry If it's been asked before but What does Medium Diff Setting means on the setup sheets?
thanx in advance
yokemad is offline   Reply With Quote
Old 09-22-2009, 09:12 AM   #1807
Super Moderator
Originally Posted by yokemad View Post
Hi guys
thanx in advance
That would be how tight or loose the diff is screwed together.
- RCSpecialties -
Old 09-22-2009, 10:00 AM   #1808
yokemad's Avatar
so Medium setting:
Diff Slips If you force it ,is that right?
Old 09-22-2009, 10:07 AM   #1809
Super Moderator
so Medium setting:
It's a relative term... but yeah. If you hold both rear tires, and spin your spur gear with your thumb, it should spin forward with just a bit of force. If its really hard to spin it forward, it is too tight.
- RCSpecialties -
Old 09-22-2009, 11:11 AM   #1810
yokemad's Avatar
Thanx very much Sir
Old 09-23-2009, 01:13 AM   #1811
cyanyde's Avatar
how I adjust my diff is by testing it on track. I'll tighen it until the back end doesn't kick out coming out of a turn.
cyanyde is offline   Reply With Quote
Old 09-23-2009, 01:30 AM   #1812
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can anyone tell me where on the xray website i could download a manual for an xray 007 and 008 ?
Also anyone know if the 007 or 008 arms, front and rear hubs, c-hubs, knuckles fit the 009?
LOSI123 is offline   Reply With Quote
Old 09-23-2009, 04:45 AM   #1813
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
Hey,
All the parts off the T2 '008 will definitely fit the T2 '009. Only exception is the Chassis.
I think most of the plastic parts on the T2 '007 are different to the T2 '009.
Here is a link to the Instruction Manual of a T2 '009, which is the same as a T2 '008 basically. I'm not sure about the T2 '007 Instruction manual, but i'm pretty confident that there aren't too many parts off that car that will fit either the T2 '008 or T2 '009.
Hope this helps,
Ryan.
Awesomatix - Muchmore - Protoform - Silverback - Radtec - LeeSpeed - Hiro Seiko - SG PitDesign - Plaig
RC MAKER - www.rcmaker.com.au
AWESOMATIX - R1 WURKS - VOLANTE
Ryan Maker is offline   Reply With Quote
Old 09-23-2009, 06:00 AM   #1814
Benzaah's Avatar
Trader Rating: 21 (96%+)
T2R here too. I stopped using my T2'008 i love it that much on low to med grip. I run it in 17.5 atm box stock with the 2.6 and 2.8 kit springs from an 008. Trying anti dive in the front at the moment and liking that. Car is a weapon and can drive under and over just about anything its just my driving lets it down . Im still fiddling with the ackerman and front toe settings to get it to turn in the way i like it at high speed as we have a very large high speed outdoor Nitro track.
I have tried the graphite upper decks and shock towers from the 008 to see how that went and it did not have enough flex and felt weird. Just using the top rear graphite flex plate is good and using the rear shock tower gets it to push a little in the rear which i found nice and consistent to drive but i ended up back with the stock parts to rebuild the 008 for a new high grip track that's coming
I wouldn't mind changing to some 6 degree caster blocks to see if i can get that bit more exit grip and speed and the Alu Quick roll center adjusters as all the local 009 drivers swear by them. Might try pro squat in the rear too and see how that goes. Any advice on the above changes would be appreciated. Cheers Benzaah
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 09-23-2009, 06:39 AM   #1815
Skiddins's Avatar
You must have a lucky 'freak'
I haven't come across a car with a spool that doesn't have chatter at full lock.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
