Old 09-20-2009, 05:14 PM   #1786
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
ECS shafts.
IIGQ4U is offline   Reply With Quote
Old 09-20-2009, 05:23 PM   #1787
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default 009
Originally Posted by scr_achy View Post
New to on-road and xray all together. Got the 09 car all setup but have an issue. The belts run smooth as butter when not steering, but as soon as I steer left or right the main belt begins to chatter horribly. What should I be looking for to correct this problem?
how tight do u have it? what car rubber ,foam? 1way,spool?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 09-20-2009, 05:25 PM   #1788
Originally Posted by IIGQ4U View Post
ECS shafts.
that was next
Old 09-20-2009, 07:03 PM   #1789
Trader Rating: 37 (100%+)
Originally Posted by Customworksking View Post
that was next
Ridiculous a $100 "option" seems to be necessary for a $500 chassis to operate at it's best.
"Fermentation may have been a greater discovery than fire."
-David Rains Wallace
jubilee is offline   Reply With Quote
Old 09-20-2009, 08:19 PM   #1790
I have the 09 foam tire version & I put Jaco foams #6160 on the front & they hit the steering arms, the manual tells me to put the tires on a tire truer or file them down. I don't have a tire truer so how are you guys doing this, looks like a lot has to be taken on the inner tire & rim. I checked the shims in the front & they are correct, the front tracking width is 189mm, this is correct.
btsmith49 is offline   Reply With Quote
Old 09-20-2009, 09:00 PM   #1791
Trader Rating: 18 (100%+)
Send a message via AIM to scr_achy Send a message via Yahoo to scr_achy
T2-09 Rubber. Everything is loose and EPAs are set. After playing with it further it only does it at low speeds. If I'm on throttle it does not chatter while steering, only while going slow.
My guess is ECS may be needed but i'll deal with it for now before I drop even more money on a new car
Founder- RcBros.com
It's all about the fun!
Toys: MF2,E X1-CR, 8ight, LCC, MRC, Axial, T209, Baja 5B
scr_achy is offline   Reply With Quote
Old 09-20-2009, 09:07 PM   #1792
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Just run it bud, turn down the end points some and drive it. You gotta learn to drive on road before droping the cash on the ECS's. I dont run the ECS's, and its plenty fine. People drove fast forever without them
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 09-20-2009, 09:59 PM   #1793
turd ferguson's Avatar
Send a message via AIM to turd ferguson
The truer is the easiest way to sand down the inner edge. Ask someone at your track if they can do it for ya. Otherwise you can space the wheel out at the hex with either the wider Xray hexes or wheel shims. It will take some steering away but its much better than binding.
TrakPower, Speed Passion USA, Pro-line, Stickit1 Racing, LiveRC.com
turd ferguson is offline   Reply With Quote
Old 09-20-2009, 10:15 PM   #1794
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You used WAY too much loctite on the grubscrews in your driveshafts, and it has turned all the grease you put on the joint into glue. You need to dissasemble your driveshafts, scrape all the grease out (which is now glue), and start over. only used the TINNIEST drop of loctite on the grubscrew, and make sure you wipe up any excess before you grease your shafts.
Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-20-2009, 10:18 PM   #1795
Super Moderator
But its optimised! (i guess the stock driveshafts really arne't, if you have to buy an upgrade on a $500 chassis)
- RCSpecialties -
Old 09-20-2009, 10:25 PM   #1796
Cpt.
Ty, just bought the car used, so I'll tear them apart and give that a go
Founder- RcBros.com
Old 09-20-2009, 10:28 PM   #1797
Super Moderator
Im 90% sure that is what it is... happens to a lot, and happened to me on both the 09s I built. Just take the shaft out and see if it wobbles freely in all directions. My bet, is that one direction it is about locked (or really tight). That is a sign the little cupler is loctited into the hole, in the driveshaft. It is a pain in the arse to get out... have to scrape it out with something like an allen wrench or something. Soaking in wd-40 helps too.
cpt.
- RCSpecialties -
Old 09-21-2009, 06:51 AM   #1798
Skiddins's Avatar
All chassis do the same, but Xray actually offer an option to prevent it.
They are also a bit more delicate than the factory items in my opinion, so not givveing them to every cretin to destroy is probably a good thing.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-21-2009, 08:27 AM   #1799
pcar951's Avatar
Trader Rating: 19 (100%+)
Anyone tried the fiberglass (T2R) chassis on low grip yet??
pcar951 is offline   Reply With Quote
Old 09-21-2009, 08:56 AM   #1800
Skiddins
Can't say I buy this 100%. Maybe my ta05 was magic. The 007 I had, however, rattled like crazy.
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
