Old 09-18-2009, 12:04 PM   #1771
The Evicerator
Originally Posted by yokemad View Post
also which pin is the best for ecs driveshafts there are two different type v2 and one with flat spot ?
I 've already break two pins comes with drive shafts using top racing pins no problem so far but one of the driveshaft case pin hole has worned badly I thought that might be because of a little longer top pin...
cheers
I've actually never run anything other than the stock pins with the flat spots and I have not had any problems even with some pretty hard hits.
I wonder if people are having their pins break due to over-tightening ...?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 09-18-2009, 01:07 PM   #1772
yokemad's Avatar
Thanx Stewe
you know that 38/20 pulley conversion r u using stock belts or which one do we need ?
best regards
yokemad is offline   Reply With Quote
Old 09-18-2009, 01:27 PM   #1773
The Evicerator
Thanx Stewe
best regards
The belts you need are
# 30 5432 Front drive belt 513 mm
# 30 5446 Rear Drive belt 189 mm
Obviously you need to have the 38 tooth spool and rear diff pullies as well!
Steve Weiss
Old 09-18-2009, 04:06 PM   #1774
Skiddins's Avatar
Originally Posted by Besercoe View Post
Try sanding the thrust washer plates as well as the diff rings, the TW plates seem to be made out of hardened cheese, and not only develop a score line where the balls run, but also seem to develop large divots.
I also tried something out of the Photon, and stacked the cone washers inside each other, this makes diff adjustment a lot more sensitive, but it also gives a lot more drive out of the diff while maintaining a free diff action.
Black AE grease on the Thrust, and AE Silicone grease on the balls and plates, the tube with the red writing, not the black writing stealth grease
Why do some people recommend the standard Associated grease and some the Stealth grease, what's the difference?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-18-2009, 04:18 PM   #1775
Trader Rating: 37 (100%+)
Originally Posted by Cpt.America View Post
But if they DID include the ECS driveshafts in an 010, the kit would probably me $100 more than the 09. It would however be more "optimised"
My bet would be a new kit at no more than $550...or probably even the same price as the 009 considering the economy.
They'd save on not including the 'old' 009 parts.
"Fermentation may have been a greater discovery than fire."
-David Rains Wallace
jubilee is offline   Reply With Quote
Old 09-18-2009, 11:20 PM   #1776
ds400's Avatar
Default Xray t2009
I am sure there is a new designed car on the horizon , just by reading the monthly new column on the xray website. They were talking about testing done on newly designed motor mount and other parts. The suspension holders would be more like the tamiya, using toe block etc...
ds400 is offline   Reply With Quote
Old 09-18-2009, 11:48 PM   #1777
Trader Rating: 18 (100%+)
Send a message via AIM to scr_achy Send a message via Yahoo to scr_achy
Looking for gearing recommendations for 17.5 Brushless and stock brushed rubber on carpet. Track is fairly small with small straight and a good amount of turns.
I have 64 pitch now but wouldn't mind going 32.
Car is new to me and I only got time during lunch to pick up parts before our next race.
Thanks for ur help!
Founder- RcBros.com
It's all about the fun!
Toys: MF2,E X1-CR, 8ight, LCC, MRC, Axial, T209, Baja 5B
scr_achy is offline   Reply With Quote
Old 09-19-2009, 02:33 AM   #1778
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Hi can some tell me why is it that the Xray blatters swell so fast i cant use them more then 1 time i use Xray oil to stop it from swelling so fast.And by the next day i cant rebuild them because i cant bleed them though the shock cap as im running alloy shocks. any ideas
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 09-19-2009, 02:36 AM   #1779
Benzaah's Avatar
Trader Rating: 21 (96%+)
How would you explain over tight? I get worried that i have not tightened it enough and have i put enough locktite on it to have it hold. I have snapped 2 pins and stripped 3 of the little hex heads and had to replace that little drive coupling twice which is an expensive exercise. I guess i am over tightening them.
Originally Posted by P.I.M.P View Post
Hi can some tell me why is it that the Xray blatters swell so fast. any ideas
Switch to TRF shocks. You'll never look back...
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is online now   Reply With Quote
Old 09-19-2009, 02:45 AM   #1780
P.I.M.P's Avatar
Hi could you tell me what parts i need apart from the trf shocks
Vbc wildfire D06
clinton livingstone
Old 09-19-2009, 04:44 AM   #1781
Benzaah's Avatar
this advice previously came from Jim FK05 so i cant take credit. Use tc5r top shock mounts, part no ae 31250 shock bushing, you'll need four, one for each top mount and use the lower mount & spring plate off the xray shocks. Also on 08's & later leave out the black "o" ring that goes inside the shock where the oil goes. TRF mini shocks wont work either as i tried this in hope of making this work without buying new shocks.
Old 09-19-2009, 05:16 AM   #1782
P.I.M.P's Avatar
thanks what do you mean by leave out the o-ring out of the shock where the oil gos.
Vbc wildfire D06
clinton livingstone
Old 09-19-2009, 06:08 AM   #1783
FK05 lover's Avatar
Trader Rating: 147 (99%+)
When you assemble the TRF shock, the instructions ask you to fit a black "o" ring to the shock shaft before putting it into the shock housing.
If you don't leave this out on 08/09's you won't have enough shock length + therefore will have a few problems getting correct ride height, droop etc
Also use the original Xray lower shock mount, spring saddles + springs
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 09-19-2009, 09:57 AM   #1784
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
The associated shock bushings (ASC31250), is there anywhere we can get something similar in black? I can only find them of course in blue. Does anyone make a aftermarket shock bushing in black? Any help would be appreciated.....would hate to have blue on my black xray
EA Motorsports
picco007 is offline   Reply With Quote
Old 09-20-2009, 05:08 PM   #1785
New to on-road and xray all together. Got the 09 car all setup but have an issue. The belts run smooth as butter when not steering, but as soon as I steer left or right the main belt begins to chatter horribly. What should I be looking for to correct this problem?
Founder- RcBros.com
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
