Old 08-31-2009, 11:38 PM   #1666
Team-RTR's Avatar
Originally Posted by Ryan Maker View Post
Hey Josh,
I think you will probably fit a 18-19 tooth Pinion Minimum. It depends what motor you will be running, and the size of your track as to what Pinion you will want to run. But Yeah, 18 is Probably the smallest you will fit.
If you have any more questions, just post on here and i will do my best to help you out.
Ryan.
on the flipside, what is the largest pinion size you could run with 84t spur?
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 09-01-2009, 12:25 AM   #1667
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Originally Posted by LOSI123 View Post
Will a 87t and a 90t spur fit the 009 EU as the manual has them listed as option parts, but with the 84t spur in the car it sits prety low and close to bottom of the bottom deck..
48 pitch
90T does fit, that's what we used in the Drag 08 (+ holds NSW's fastest ET record)
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 09-01-2009, 12:46 AM   #1668
LOSI123's Avatar
Trader Rating: 63 (100%+)
thx
LOSI123 is offline   Reply With Quote
Old 09-01-2009, 04:44 AM   #1669
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Cant exactly remember, but i think its around 28t. If your planning on running stock, then you will need a lot smaller. Something in the low 70's For ss 78 should be the go.
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 09-01-2009, 05:03 AM   #1670
FK05 lover's Avatar
Antoni
+1
Old 09-02-2009, 05:02 AM   #1671
Team-RTR's Avatar
how important is it to run the offset spur gears? or does it not really make a difference?
Old 09-02-2009, 05:26 AM   #1672
miller tyme's Avatar
If your running round cells you need to to keep the pinion comfortably away fromthe battery bar. With Lipo I find they tend to sit further out to the chassis edge and that's not as big of a concern. Spur width would be since distance between belts is narrow.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 09-02-2009, 07:44 AM   #1673
Team-RTR's Avatar
What are some decent brand of 48p spur gears you guys run? the xenon spur i tried was junk, not only was it way too thick but the holes didnt even line up properly!
Old 09-02-2009, 07:59 AM   #1674
mattyau's Avatar
Send a message via MSN to mattyau Send a message via Yahoo to mattyau
try RW Racing Spur Gears, tho they say there made for xray i still have run into problems mounting the 69t as the holes dont much to well but 75t seemed fine
.:T2'009:.
mattyau is offline   Reply With Quote
Old 09-03-2009, 08:27 AM   #1675
nitro neil's Avatar
Trader Rating: 73 (100%+)
Hey guys I'm shopping for a lipo plate one I can use like 5000 with. I realy don't want to raise the top plate and I would also like someting that would make the battery sit off the chassis aswell any suggestions where I can get this and links to who has this. Thanks
TLR, SPEKTRUM,HORIZON HOBBIES, JCONCEPTS, Tekin, MIP, ONeill Brothers Racing, Axis RC, Large Scale RC, Boom rc, Team Chase,
nitro neil is offline   Reply With Quote
Old 09-03-2009, 08:59 AM   #1676
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Manutech Tray is just awesome, I have two of them. If you have a dremel, you can take time to drill out the holes to get a perfect balance... stormerhobbies.com is the place to get it.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-03-2009, 09:01 AM   #1677
drsfly's Avatar
Default lipo plate
Neil,
Eric has some plates at the track.
PPD billet makes some and he can be found in the for sale section-- under ppd billet or verndog. Sorry I don't have link.
It also depends which lipo you want to run. The new ones(SMC) are quite heavy and I had to lighten my plates(drill them out) to get the car balanced as opposed to the other batts I was using.
Eric has some that come in 2 pieces so you may not have to lighten them.
Later,
Darrald
drsfly is offline   Reply With Quote
Old 09-03-2009, 03:23 PM   #1678
losithrasher's Avatar
for people running thunderpower 40cs and the lipo wheights, how do you have your car balanced? im having trouble figuring out if my car is really balanced with the hudy balancing tool.
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 09-03-2009, 04:15 PM   #1679
Benzaah's Avatar
Trader Rating: 21 (96%+)
Zeppin racing have some individual lipo weights for the xray and they come in packs of 6. I am thinking of gettng these as i have the Xray lipo weights and an extra 2 of these zeppin ones would get rid of all the ugly lead i have on board. They say they prevent tweak like some of the solid plates can do as the chassis can still flex like it needs to. Link here http://www.zeppinracing.com/product_info.php?pid=85
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 09-03-2009, 04:34 PM   #1680
Super Moderator
Originally Posted by Benzaah View Post
Zeppin racing have just released some individual lipo weights for the xray and they come in packs of 6. I am thinking of gettng these as i have the Xray lipo weights and an extra 2 of these zeppin ones would get rid of all the ugly lead i have on board. They say they prevent tweak like some of the solid plates can do as the chassis can still flex like it needs to. Link here http://www.zeppinracing.com/product_info.php?pid=85
But where can you buy them?
- RCSpecialties -
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
