Old 08-28-2009, 06:32 AM   #1621
mattyau's Avatar
Send a message via MSN to mattyau Send a message via Yahoo to mattyau
come to think of it my layshaft is black alu aswell
.:T2'009:.
mattyau is offline   Reply With Quote
Old 08-28-2009, 06:50 AM   #1622
bjs227's Avatar
Trader Rating: 16 (100%+)
maybe it is alu. I put my second one together in about 2hrs. And really didnt have alot of time to inspect the part. But i did notice it was black
Brandon J. Skewes A.K.A "Skittles"
genesisrcraceway.com - skewesjewelry.com - race-rewards.com
bjs227 is offline   Reply With Quote
Old 08-28-2009, 07:03 AM   #1623
Trader Rating: 31 (100%+)
mattyau... I noticed this with my kit as well, the parts are the same just different colour is all, I wasn't really impressed at first, but it looks pretty trick once it's all together, black out all your wiring and components and everything seems to hide really nicely.
$$$... is offline   Reply With Quote
Old 08-28-2009, 07:39 AM   #1624
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by bjs227 View Post
in all my xray kits i have always had the xray shock shims. I have 2 rubber cars and the only difference i saw as the the layshaft. In the first kit it was Orange ALu and in the my second it was black plastic.
Yes the layshafts are made of a different alumn (not plastic) and when anodized it doesnt match the other orange. I think this is why they made them black instead.
Different grades of alumn will take anodize differently. And depending where and how the alumn is used is why there is different grades.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-28-2009, 11:28 AM   #1625
Can someone post the setup the factory guys ran at the euros?
billythekid is offline   Reply With Quote
Old 08-29-2009, 09:17 AM   #1626
alecladanga's Avatar
hi guys
i upgraded from a t2 07 to a t2 09 at the start of the year and it has been performing well.
recently at a club meet, one of the shocks got broken and my replacement part was the longer 07 shocks.
I placed 2 of these 07 shocks at the rear and quite surprisingly, my rear wasn't loose anymore and had more of a grip.
Just want to ask if anyone had done the same (put the 07 longer shocks at the rear of an 09) and what were the results?
thanks in advance.
I run 13.5BL on asphalt.
alecladanga is offline   Reply With Quote
Old 08-29-2009, 06:51 PM   #1627
johndayo101's Avatar
Trader Rating: 128 (100%+)
Default ecs 52mm
i have a problems with ecs 52mm vibrating when turning. is this normal?
http://www.youtube.com/watch?v=lfR4LknK4gk
johndayo101 is offline   Reply With Quote
Old 08-29-2009, 07:08 PM   #1628
mattyau's Avatar
im just starting out so im a noob.i believe the chatter is normal, i think putting abit of graphite grease around the drive shaft coupling and abit on the bottom of the drive shaft where the pin would move helps afair bit. did you make sure when you built the esc and was securing the pin into the coupling that pin was centered and the drive shaft rotated freely around the drive axle. as i had a the same type problem when i first built mine.
.:T2'009:.
Old 08-29-2009, 07:31 PM   #1629
i cleaned and rebuild them. but never checked thorougly. this is the first time i rebuild them.. i was thinking is when you turn the steering left right the ecs is hitting the c hubs and makes it to vibrate. correct me if im wrong.
Old 08-29-2009, 07:57 PM   #1630
davepull's Avatar
http://www.titaniumracing.com/menu.asp?menu_id=17 they have some great hop ups for the 009
davepull is offline   Reply With Quote
Old 08-29-2009, 08:41 PM   #1631
mickrcarver's Avatar
Trader Rating: 98 (99%+)
a couple of things, do you have the large open c hubs (new style) I know the 009 comes with them but if you broke one you may have replaced it with an older chub with smaller opening. also check the pins in the ecs as they seem to fall out and hit the inside of the steer knuckle
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 08-29-2009, 09:02 PM   #1632
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
It looks to me like maybe you used too much locktite on your grub screws. Same thing happened to me. Too much locktite, and some of it gets on your axle grease, the grease hardens, and the axles no longer flex/bend well. Take your shafts out and see if they flop around freely, or if they seem to bind. If so.... its your locktite.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-29-2009, 09:19 PM   #1633
thanks for the reply guys.
it might be the loctite. i put a little bit much cause i dont wanna loose those pins again. rebuild time
Old 08-29-2009, 09:31 PM   #1634
cwoods34's Avatar
Time for me to rebuild the diffs, and I have a question. When I bought the car the diffs needed new balls and plates, so I put new parts in with lube and they were flawless. I think the plates just need to be sanded a touch and re-lubed. Is there a certain grit of sandpaper that works really well? Or with these do you just purchase new plates?
When the first rebuild time came, I just took the new plates I had put in and flipped them over, since the outdrives don't really wear out the plates as much as the diff balls. It seemed to work like new, but now THAT side is a bit more worn, and I really don't like the idea of dropping in a new rebuild kit every time they wear out. Tips or tricks anyone? Thanks a ton!
Upgraded earlier this year from TC4's in VTA and stock foam to 007's, I don't think I will own anything except XRAY from now on After 1 race night I had the 007 turning faster laps than the FT TC4 that I had ran for about 5 months!
Lots of great information in this thread!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 08-29-2009, 10:23 PM   #1635
mattyau's Avatar
1000 grit u should be able to make it smooth again
tho the diff rings are pretty cheap even when u replace it u can sand the new one's before you put it in theres a tool u can get that muchmore makes so you dont have to use your fingers
.:T2'009:.
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
