Old 08-26-2009, 03:54 AM   #1606
awth's Avatar
Hi guys,
I have quesiton regarding the drive train / internal transmission. The kit standard is 34T solid axle in the front, 20T pulley, and 38T Rear diff. As I understand, the front would turn faster than the rear, so it is pulling the car, does this offer more steering too?
I would like to know how does it (as kit 34T-20T-38T) compare to 38T-20T-38T and 34T-20T-34T, in speed (acceleration & top speed), stablity, or steering (entry, mid, and corner exit), if relevant.
Thank you in advance.
Alan
- Xray T3 EU & T2 009 EU
- Assoicated 12R5
awth is offline   Reply With Quote
Old 08-26-2009, 05:48 AM   #1607
RFALLON's Avatar
Send a message via AIM to RFALLON
The kit is 34 tooth all around...
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
RFALLON is offline   Reply With Quote
Old 08-26-2009, 08:59 AM   #1608
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Nope.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-26-2009, 09:51 AM   #1609
Johnny Wishbone's Avatar
A little off topic, but has anyone ever tried a 38/20 front with a 34/18 rear or swaped around setup?
Old 08-26-2009, 01:30 PM   #1610
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Skiddins View Post
Myself and several other people have taken to removing the grub screws completely that hold them together, then using a small piece of heatshrink, used like a sleeve to hold everything in position.
No binding, better protection for the grease from debris and dust etc. and they work fine.
Skiddins
I haven't run with the ecs yet. have you been losing pins out the joints?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-26-2009, 02:52 PM   #1611
cyanyde's Avatar
I just swap the pins with the ones we use in the wheel hex hubs. So far so good for me. Maybe that little extra length keeps everything in place a little better...
cyanyde is offline   Reply With Quote
Old 08-26-2009, 03:20 PM   #1612
Skiddins's Avatar
Most problems with driveshafts involve the pins coming out.
I have had them start to come out but have never had a 'full' failure.
No, but there's no movement at all since using heatshrink.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-26-2009, 08:03 PM   #1613
I had a full failure. Lost pin, lost yoke. Wallowed out the C hub. Destroyed the opening in the dogbone that fits into the pin of the axle. Useless now. Blue 242 Loctite was used.
I'll be using the shrink wrap techniqe if I decide to go back in with another. I just cant stomach purchasing another for the price right now.
Dondor is offline   Reply With Quote
Old 08-26-2009, 08:32 PM   #1614
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
http://www.teamxray.com/teamxray/new...20Column%20#33
Some interesting reading there.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-26-2009, 10:26 PM   #1615
xray09ACT's Avatar
ok reading the new column and looking at that photo that was taken i noticed a few things, maybe
rear shocks at the front of the rear shock tower?
centre layshaft layout = spur/belt/belt (talking od breaking spurs)
front diff seems to sit on thr right as opposed to the middle, kind of confirms above.
Wider lower deck. the edge seems to lign up with the sway bar mount on the arm, lipo ready?
xray09ACT is offline   Reply With Quote
Old 08-26-2009, 11:21 PM   #1616
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
doesnt look any wider too me but everything else you mentioned seems correct...
Alex
hound_dogs_01 is offline   Reply With Quote
Old 08-27-2009, 01:10 AM   #1617
Shocks are on the back of the tower per norm.
Front diff is on the left as per normal.
Thats just a stock photo from an event, they wouldnt be showing any of these new items in public, they do far too much private testing.
The only thing that looks odd from memory is the shape of the rear shock tower around where the camber links mount.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-27-2009, 01:41 AM   #1618
awth's Avatar
Oops.... you guys are right! It is 34T all around.
Alan
- Assoicated 12R5
Old 08-28-2009, 06:15 AM   #1619
mattyau's Avatar
Send a message via MSN to mattyau Send a message via Yahoo to mattyau
my 09 has came with black alu servo mounts instead of the orange, and they also have seemed to have supplied the optional parts to move the shocks forward in a bag labeled 0002 . anyone else end up with a kit like this. looks alil wierd with the black servo mounts against all the orange
.:T2'009:.
mattyau is offline   Reply With Quote
Old 08-28-2009, 06:28 AM   #1620
bjs227's Avatar
in all my xray kits i have always had the xray shock shims. I have 2 rubber cars and the only difference i saw as the the layshaft. In the first kit it was Orange ALu and in the my second it was black plastic.
Brandon J. Skewes A.K.A "Skittles"
genesisrcraceway.com - skewesjewelry.com - race-rewards.com
bjs227 is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
