Old 08-24-2009, 04:43 AM   #1591
Hi does anybody know if I can run the Reedy Lipo #711 in the 009 without the lipo converters to increase the deck height?
Any chance someone can post a piccy with it fitted
Thanks for your help
008-Racer is offline   Reply With Quote
Old 08-24-2009, 05:46 AM   #1592
Skiddins's Avatar
Originally Posted by yokemad View Post
Hi Guys
some says For tighter Tracks shorter wheelbase is better...
how about setting the wheelbase ?
should we set only back end or can we change the Front also?
If so what is the effect
Thanx in advance
I run the shorter rear wheelbase (1mm in front of the rear wishbones) and prefer it this way, you get more rear grip but it snap out harder when it does go.
Tried the longer wheelbase at the UK nationals yesterday and it made the rear a little less stable.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-24-2009, 07:25 AM   #1593
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
You can also try 1.5mm shims for finer adjustments
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 08-24-2009, 08:55 AM   #1594
yokemad's Avatar
Cheers dude
Have you ever change Front wheelbase?
yokemad is offline   Reply With Quote
Old 08-24-2009, 11:06 AM   #1595
Send a message via ICQ to markrichards Send a message via AIM to markrichards Send a message via MSN to markrichards
Default need a favour
I need to know the length (in mm) of the top brace stand off posts of the t2 and the older longer T1fk05 cars.
cheers
markrichards is offline   Reply With Quote
Old 08-24-2009, 03:29 PM   #1596
losithrasher's Avatar
what does your car gain by putting a shim beetween the shock and the shocktower?
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 08-24-2009, 03:30 PM   #1597
Skiddins's Avatar
Cheers dude
Only on my wet car, I belive it adds a lot of steering if tried in the dry, too much steering probably.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-24-2009, 03:32 PM   #1598
Skiddins's Avatar
You can change the angle of the shock to make sure it is dead vertical (front to back) instead of at a slight angle.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-24-2009, 04:37 PM   #1599
Johnny Wishbone's Avatar
It will give you forward bite without effecting dampening effect. It is like a second dimension of shock placement, you have the holes to move up and down and then you can go out for a split on the spring weight, more than 1mm is like going to the next hole on the shock tower.
Old 08-24-2009, 06:04 PM   #1600
Kirsbak's Avatar
Default xray t2 009
Hey fellow Xray drivers.
We just got LIPO, and I've installed everything running the 40C 5000 LRP battery.
The battery fits perfect, but with the - Connector ( Black ) Will not fit due to the top deck ?
Its 100% org. with the Lipo set added.
( If I bought the Lipo weight pack from Xray, I would need to have the Connectors placed infront of the car right?
My problem would be:
1: Longer cables = Bad
2: The Lipo has more weight in the back instead of the front ( Connector side has all the eletronics I presume to connect the 2 seperat batteries inside )
Anyone got a good picture of a LIPo setup ?
1:5 FG Evo009
1:6 Elcon Cleon
1:5 MCD Ultimate
Hyper 9E X 4 - Bring it!
Tamiya 416X
Kirsbak is offline   Reply With Quote
Old 08-24-2009, 08:52 PM   #1601
vazzo's Avatar
Trader Rating: 100 (100%+)
Hey Guys
It's probably been asked before. But whats the highest rating LIPO with corally connectors I can fit into the 009 without using lipo pads?
Thanks in advanced.
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 08-25-2009, 05:38 AM   #1602
Skiddins's Avatar
The extra length of the cables won't make any difference.
The lipo will weigh the same from either end as there is very little in the packs.
Better still, get a lipo with cable coming out of it as these have less resistance.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-25-2009, 12:27 PM   #1603
Skiddins's Avatar
Myself and several other people have taken to removing the grub screws completely that hold them together, then using a small piece of heatshrink, used like a sleeve to hold everything in position.
No binding, better protection for the grease from debris and dust etc. and they work fine.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-25-2009, 01:06 PM   #1604
Kirsbak's Avatar
Default .
There is currently no Lipo's with connectors allowed.
Cant believe there's nobody running the same LRP/t2 009 setup.
Else I'll have to shave alittle off the Top deck.
1:5 FG Evo009
1:6 Elcon Cleon
1:5 MCD Ultimate
Tamiya 416X
Old 08-25-2009, 05:17 PM   #1605
yokemad's Avatar
@Damian
Thanx Again for another good tip
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
