Old 08-20-2009, 09:27 PM   #1561
rosko's Avatar
it was outdoor asphalt sprayed with vht
rosko is offline   Reply With Quote
Old 08-20-2009, 10:11 PM   #1562
thisguy2849's Avatar
Originally Posted by IIGQ4U View Post
Does anybody know where I can purchase the XRAY LiPo balancing weights (With L brackets) or have a set that they want to sell? I can't find a store with these in stock.
Superior Hobbies had them in stock last week
thisguy2849 is offline   Reply With Quote
Old 08-20-2009, 10:15 PM   #1563
Originally Posted by yokemad View Post
has any of you guys had a chance to drive 416?
if so what do you think about the car and the preformance against xray?
is that the car or the drivers they have on board?
cheers
I believe its both. I have driven 416 and it is a good car that works very well out of the box.
billythekid is offline   Reply With Quote
Old 08-20-2009, 10:18 PM   #1564
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
I just searched by part number and it said product not found.
IIGQ4U is offline   Reply With Quote
Old 08-20-2009, 10:20 PM   #1565
Originally Posted by hound_dogs_01 View Post
its not a new car just a different color anodizing....
instead of chrome('08) and ornage('09) is going to be black('10).... thats the rumors im hearing around the Marietta, GA area...
if you dont know whats in Marietta, GA look up www.nexusracing.com
Alex
I can't believe they are changing color again.
Old 08-21-2009, 02:08 AM   #1566
Broady Racing's Avatar
Send a message via MSN to Broady Racing
Hey guys, just converting my 009 to 64 pitch gearing, and I tried installing a 118t spur and it hits the bottom deck. Dose anyone know what the largest spur I can use without hitting bottom deck? thanks in advance
Broady Racing is offline   Reply With Quote
Old 08-21-2009, 02:25 AM   #1567
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
116t is the biggest You can use the 118t with the fwd motor positin though.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 08-21-2009, 02:45 AM   #1568
Thanks mate
Old 08-21-2009, 09:19 AM   #1569
Catalyst's Avatar
George I got mine from RCMushroom since I couldn't find them in stock state side.
Catalyst is offline   Reply With Quote
Old 08-21-2009, 04:08 PM   #1570
Default Setting front camber
Hello
I've build my Xray T2 009 (EU-edition 6-cells) but have the following problem
[my car is equipped with the one way axle (multi-diff)]:
My front wheels are leaning to the outside (so positive camber). When I try to alter the cambersettings (to the standard -1.5) and turn the wheels to the right or the left, the steering isn't loose.
Ive tried to change the width of the turnbuckles, but when I make them too narrow everything moves very badly. When I make the turnbuckles wider the steering is smooth but then I can't have the proper camber setting.
The axes are 52mm long (and like the manual states, I've used the spring steel axes on the front).
Can someone tell me what I'm doing wrong?
boba.slave is offline   Reply With Quote
Old 08-21-2009, 04:28 PM   #1571
Originally Posted by boba.slave View Post
Hello
First make sure you have the proper shim between the roll center block and the bulkhead(1.5), also remove the plastic shim between the outdrive and the one-way bearing on the multidiff. This should solve the issue.
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 08-22-2009, 02:02 PM   #1572
Thanks Joe! That was the magic tric!
Old 08-22-2009, 03:29 PM   #1573
RC MARKET's Avatar
Which item ?
RC MARKET is offline   Reply With Quote
Old 08-22-2009, 03:36 PM   #1574
No problem, happy Xraying
Joe
Old 08-22-2009, 04:48 PM   #1575
IIGQ4U's Avatar
Originally Posted by RC MARKET View Post
Which item ?
XRAY 309860, the LiPo weight set
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
