Old 08-16-2009, 05:28 AM   #1531
Cristian Silva's Avatar
Asphalt/rubber drivers, you guys using the 34 pulley or the 38?
Team Xray Australia - HEI International ~ www.hobbyexpress.com.au - www.smaracing.org
Cristian Silva is offline   Reply With Quote
Old 08-16-2009, 06:08 AM   #1532
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Cristian, with the pulleys use 34 for stock and superstock. In mod ise the 38 but in 10.5 i use 34. I cant notice much of a difference in 10.5, and it is easier to gear with the 1.7 internal. 38 is definatly better in mod though
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 08-16-2009, 09:53 AM   #1533
RLMW VQ's Avatar
i run the 38 in stock rubber the car is fast and i dont have any problems gearing it.
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Old 08-16-2009, 10:50 AM   #1534
yokemad's Avatar
Hi guys
I'm just wondering whats the bad effect of the using too much negative Camber?
I usually set -2 degree frnt and rear (on very low grip tight carpet ) and it feels good but on the otherside I've recently checked setup sheets and very few people uses -2 Camber...
It's a bit confusing
more negative on front =more steering
more negative at the back=less traction
is that correct?
Thanx in advance
yokemad is offline   Reply With Quote
Old 08-16-2009, 03:53 PM   #1535
RC MARKET's Avatar
Originally Posted by yokemad View Post
Hi guys
is that correct?
Thanx in advance
what tire & insert ?
RC MARKET is offline   Reply With Quote
Old 08-16-2009, 03:56 PM   #1536
LOSI123's Avatar
Trader Rating: 63 (100%+)
can you achieve fdr of around 9:1 with the 34T pulleys if you wanted to?
LOSI123 is offline   Reply With Quote
Old 08-16-2009, 09:51 PM   #1537
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
is that correct?
Not correct.
More negative on front = more front side to side traction
More negative on rear = more rear side to side traction
But its only one small piece of the puzzle. You also have roll center, camber gain, and a dozen other things that can affect or counter affect it also.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-17-2009, 03:38 AM   #1538
cyanyde's Avatar
If you're uncomfortable with too much neg camber, try increasing camber gain by changing the upper linkage on the shock tower boy rotating the ball joint. There's nothing wrong with going 2 degrees though. I use that sometimes. Gives a more even tire wear as well on tighter tracks. I use sorex 36/40 mostly.
cyanyde is offline   Reply With Quote
Old 08-17-2009, 06:39 AM   #1539
yokemad's Avatar
Originally Posted by Cpt.America View Post
Not correct.
It feels exactly like that but thing is even on very low asphalt setups team drivers not prefer to use -2 degree..,
And another point, is leaning rear tires inwards too much (-2) cause any negative effect (lack of traction) on slow corners?
but my car definitely feels much more controllable with -2 Camber
Thanx Guys
Old 08-17-2009, 12:05 PM   #1540
spurgear's Avatar
Send a message via MSN to spurgear
Can someone confirm the largest size of a lipo that can fit in the 009?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 08-17-2009, 02:18 PM   #1541
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Does anybody know where I can purchase the XRAY LiPo balancing weights (With L brackets) or have a set that they want to sell? I can't find a store with these in stock.
IIGQ4U is offline   Reply With Quote
Old 08-17-2009, 03:43 PM   #1542
Customworksking's Avatar
Trader Rating: 73 (100%+)
4000 T power
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 08-17-2009, 05:27 PM   #1543
fitting a lipo with or without the included lipo pads?
i fit a smc 5200 with a ppd weight tray and still have light showing under the lipo pad.
Dondor is offline   Reply With Quote
Old 08-17-2009, 05:54 PM   #1544
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
I fit an SMC 5400 and 6000 in my 008
i also use the lipo pads and a weight plate under the battery
Alex
hound_dogs_01 is offline   Reply With Quote
Old 08-17-2009, 07:45 PM   #1545
RFALLON's Avatar
Send a message via AIM to RFALLON
I fit an SMC 4100 with a lipo tray and without lipo pads
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
RFALLON is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
