Old 11-03-2008, 07:58 AM   #31
shadow102's Avatar
Trader Rating: 21 (96%+)
I know in my cyclone I have found rubber tires and low grip conditions the tamiya 3hole 1.1mm pistons with 40wt oil works very well
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 11-03-2008, 08:07 AM   #32
mac853's Avatar
Originally Posted by tc3team View Post
I have seen rp30 tyres blister too (on a low grip track), maybe they only suit certain driving styles? I try not to use them at all now and prefer sorex. For me, Sorex seem to give good consistancy indoors and outdoors.
Tyres are the most important thing when setting the car up, choose the wrong tyre and you simply wont get a good lap time no matter how many other things you change on the car.
My ta05 is 2 years old and probably not in the best condition. It is still capable of putting a good lap time in, all i'm saying is sometimes there is no need for a new chassis, you just need to understand why things are not working well enough
Unfortunately, blistering kind didn't happened with me on last time when using RPs, only with Sorex, but my last race using 32R with A medium insert didn't make feel any good. Off course day-by-day track condition change, we could not compare each tyres with different days. Maybe i have to bring all type of tyres with different conbination of inserts, isn't it?
mac853 is offline   Reply With Quote
Old 11-03-2008, 08:24 AM   #33
mac853's Avatar
It just depends which track condition and brand of oil, mine are Trinity, i need using 50WT with 2 holes to make my car better feel, without foam.
Old 11-03-2008, 09:57 AM   #34
tc3team's Avatar
maybe yes but to be honest, any good chassis that is setup well and looked after will put you in the A final with consistant laps.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-03-2008, 06:23 PM   #35
P956LH's Avatar
Get a baseline setup off somebody. There's bound to be a basic setup you can use from the 415 forum. I used to run on unprepared lots as well, and double diffs were the hot ticket. MSX is an awesome car, how can you get bored with it?
As for tires, I used to run the ING MS-40R (I don't know if they still make it anymore). They were low-profile, and was tolerant to dirt. The X-patterns are useless if they aren't belted, HPI quit making the Advan A038 a long, long time ago.
Sounds like you're overcomplicating some issues... a good baseline setup wouldn't require that much afterthought. Take off any swaybars (they're useless on a tight track), run diffs front and rear, and change the ackerman (run the forward hole on the knuckles). That's what I did to get my TB-02/TA05 dialed on a dirty, tight parking lot. Keeping the tires clean between runs (scrub with toothbrush and water) also helps.
TL-01, TB-02R, RS4 Pro 3, TA05R, Desert Truck.
P956LH is offline   Reply With Quote
Old 11-03-2008, 07:29 PM   #36
mac853's Avatar
If you want to talk about those "extinction" tyres, HPI 27R and 33R slick could be fit as well. Unfortunately, i just own a set of unglued 27R.
As well for Pit Shimizu slick tyres, i am not sure if they go well on my track, but from the information of the websites, they fit also on some concrete.
Old 11-04-2008, 02:06 AM   #37
tc3team's Avatar
Also find out what tyres other people are using. If it works for them it's likely to work for you too
Tamiya Championship Series Neil Rabara Racing Forum 21259 Yesterday 10:12 PM
Xray M18 Neil Rabara Electric On-Road 755 06-07-2013 02:38 PM
Pinion/spurs? rsxskyd Electric On-Road 30 09-21-2007 08:33 PM
Warpspeed Racing Art Jensen Electric On-Road 1145 10-03-2003 06:38 PM
