Old 10-31-2008, 12:08 AM   #16
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by robk View Post
1. new rotor
2. new motor
Some guys claim if you hook a BL motor up to a CE turboDyno with the esc inline to the motor, and hit the throttle as you hit the start button you can dyno a BL motor. I have not seen this personally, but supposedly oval guys have tried it...
Who's going to keep throwing money at rotors if they get a dud more than once. A whole motor isn't cheap. There were solutions in the brushed game. I guess we'll have to wait for the rotor zapper to become available
STLNLST is offline   Reply With Quote
Old 10-31-2008, 02:57 AM   #17
Free-running motors with SP Power Analysis gadget doesn't give you very much information imho. You should be able to put a load on the motor, for an example an airplane propeller. The 3.175mm mounts for a propeller are available. You won't get torque result number, but you can compare different rotors, motors, escs... Only question is how many amps does it handle/measure?
Haven't yet myself done it to car brushless motors, but it should work like described.
IMHO the SP Power Analysis is only a rpm-monitor, servo tester, voltage and current meter in one box. It probably can't display RPM when sensorless motors are being measured!? With sensored motor you get RPM from the sensor-wire.
I would very much like to know how many amps does it measure?! I'm hoping its using at least 100A shunt inside the "power box"...
lauri is offline   Reply With Quote
Old 10-31-2008, 05:40 AM   #18
Trader Rating: 75 (100%+)
Send a message via Yahoo to Paul_67
Would the Fantom Facts Machine still be a viable option?
Since it has a flywheel that attaches to the motor, it seems like it would work just as well with brushless as it would with brushed.
Paul_67 is offline   Reply With Quote
Old 10-31-2008, 07:37 AM   #19
The Eagletree setup does the same and more (like GPS speed and temps) for cheaper.
SidewaysLS4 is offline   Reply With Quote
Old 10-31-2008, 09:07 AM   #20
I've used the Fantom dyno a little and it works but it's not the best. I think that they're working on a brushless version for early next year. The Turbodyno also works fine. Neother of the dyno's above likes anything above about a 10.5 because of the RPM that they turn and power that they make down low.
Fred_B is offline   Reply With Quote
Old 10-31-2008, 09:52 AM   #21
Trader Rating: 22 (100%+)
My thoughts are, on the SP device is just the same as the MM Motor Dyno, or any no load motor checker. You buy a motor, spin it up, run it on the track and after you own it and it starts to feel bad, spin it up and see how the performance is again. Any motor Dyno is a guide, not law. Even when I had a Fantom dyno, and chopped springs, switched brushes, stroked it nicely and played with the bushings, a crap motor is a crap motor. You are only using it to find out what numbers makes a good motor, and to verify consistant performance. The best part to me is, is if I have a good motor I know how it performs on the dyno and track, then when I am thinking it is garbage I can verify that fact.
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 01:18 PM
Better Brushed Motor??? RCRat Electric Off-Road 29 08-28-2008 08:02 AM
WCIC '06/'07 grabber Canadian R/C Scene 984 07-05-2007 11:55 PM
FSEARA Race 3 Superior Hobbies Apr 22-23 TimPotter Florida Racing 175 05-08-2006 03:05 PM
