Old 10-28-2008, 06:11 PM   #1
more$thanbrains's Avatar
Send a message via MSN to more$thanbrains
Default Orion Vortex 17.5 BL 1/12 Rollout
what is a good baseline rollout for the orion vortex 17.5 motors
1/12 pan/ tight track/ carpet
Xray~Titan~Ko Propo~Orion~Muchmore~Dekelz.com
T2 007 US/EU~CRC Gen-XL~MO3-Pro~NT1~Corally C10X
'73 Ford Bronco sittin on 36" swampers~ 10" lift
more$thanbrains is offline   Reply With Quote
Old 10-29-2008, 05:59 AM   #2
John Tag's Avatar
Trader Rating: 42 (100%+)
start at 90MM and ajust from there.....
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 10-29-2008, 09:14 AM   #3
mauromj's Avatar
Trader Rating: 20 (100%+)
Is their a list of rollout numbers anywhere on the internet? I have a 27t motor and dont know where to start.
mauromj is offline   Reply With Quote
Old 10-29-2008, 09:49 AM   #4
I ran a CO27 at 28/88 with a mid size tire and I was happy with it even though I could have pulled more gear on a clean run. (road course of course)
Eddie_E is offline   Reply With Quote
Old 10-29-2008, 10:05 AM   #5
Regional Moderator
CarbonJoe's Avatar
A decent rule of thumb is 2x the rollout that you would run with a CO27. For example, like John Tag suggested, we used to run a rollout of 1.80 inches (~45.72 mm) with a CO27, and we're running around 3.6 inches (91.44 mm) with a 17.5. Try something around that and then adjust accordingly for your track. Check lap times and motor temps.
A 3.6 inch rollout is 1.75 inch tires, 78 spur, 51 pinion.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
