Old 10-28-2008, 04:58 AM   #1
Drifting101's Avatar
Default Opinions on fans blowing or sucking?
Why do most companies want there fans to blow on to the heat sink whether it be on an esc or on the motor? Because when it is blowing on it this creates a higher pressure and with that becomes heat right? so with sucking just the fact of that it is creating low pressure it will help with cooling! What do you think?
This was a days discussion in my tent with my dad and a racing buddy
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-28-2008, 05:08 AM   #2
sosidge's Avatar
Put your hand on the "suck" side of a fan and then on the "blow" side of a fan - the pressure is much greater on the blow side, that means more air for cooling.
The fan pulls in air from a wide area and blows it on a much smaller area.
The warming effect of greater surface friction from airflow would be pretty insignificant.
Old 10-28-2008, 05:21 AM   #3
High pressure is hotter though so it creates a bit heat that isnt needed
So that is creating heat with pressure
And what if it is a hot day, blowing hot air into a high pressure area on to a hot heat sink
Schumacher
Old 10-28-2008, 06:34 AM   #4
joe of loath's Avatar
you won't generate any heat from the pressure of a fan. I would say blowing, as the 'suck' side draws air fro mall directions, and blows it in one direction. so mounting the fan on the blow side will improve efficicency (ie amount of air passing heatsink).
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 10-28-2008, 06:40 AM   #5
Drewdc90's Avatar
Yeah high pressure like in an air compressor generates heat but a fan makes crap all pressure and wouldn't heat up the air at all.
I rekon blowing on you motor makes a bigger difference but it'd be worth trying both.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 10-28-2008, 07:43 AM   #6
it wouldn't cause any noticeable heat. 1st law of thermodynamics no energy can be lost or gained only transferred.
so give the fan has one form of energy electricity, and brush less motors used in most fans are above 90% efficient there is not enough energy transferred to heat to affect the temperature of the air let alone when u take into account that the air is flowing.
gotta love engineering at uni
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Last edited by aus jd 2703; 10-28-2008 at 07:47 AM. Reason: re-thought a simpler answer
aus jd 2703 is offline   Reply With Quote
Old 10-28-2008, 07:50 AM   #7
damn you, I was trying to avoid mentioning the laws of thermodynamics
Old 10-28-2008, 07:56 AM   #8
fans blow, extractors suck.
What you want is to remove the heat generated by the motor, so you blow on it.
You can test this by burning youself with a soldering iron (if you are that way inclined) and see if "naturally" you blow on it or suck the burn...
TraceRacing is offline   Reply With Quote
Old 10-28-2008, 08:27 AM   #9
nc-hopsing's Avatar
Thats a good way to look at it!
Steve Butts
KYOSHO AMERICA.com -Peakmotors.com - kyoshoforum.com - Team SlantEyEs - Hardkore Paint - JBRL Off Road Series - JConcepts.net
nc-hopsing is offline   Reply With Quote
Old 10-28-2008, 08:32 AM   #10
has anyone else realised how wrong the title of this thread is?
Old 10-28-2008, 08:34 AM   #11
P2
P2's Avatar
Trader Rating: 15 (100%+)
When I'm hot, I usually point the fan toward me....I never stand behind the fan to cool off
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 10-28-2008, 08:38 AM   #12
94eg!'s Avatar
Trader Rating: 17 (100%+)
Besides, you wouldn't want to pull all the heat from the motor through the fan. This would shorten the fan's life significantly as it is air-cooled as well. Especially when strapped to a heat-sink...
PS: Which side of a fan do you cool yourself with? (P2 beat me to it... )
94eg! is offline   Reply With Quote
Old 10-28-2008, 09:16 AM   #13
Kenneth Tan's Avatar
Ha ha. Makes sense...
Kenneth Tan is offline   Reply With Quote
Old 10-28-2008, 10:15 AM   #14
~McSmooth~'s Avatar
Thumbs up
Could we get this thread moved to the NORCAR/Gate forum?
Thanks.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 10-28-2008, 06:28 PM   #15
Thanks.
Why?
Ok thanks for all the input guys but i will still test this with my new lrp heat sink and the 40x40 fan
Schumacher
