Old 10-27-2008, 09:16 AM   #1
Default DOWN TO MY LAST ITEM... BALANCE/CHARGER
AFTER 2 WEEKS I AM DOWN TO MY LAST ITEM FOR MY FIRST FORAY INTO CAR BUILDING.
jUST PURCHASED THE smc 5000 LIPO...SO NOW I AM IN NEED OF THE APPROPRIATE CHARGER/BALANCER.
LOOKS LIKE MOST NEED A SEPERATE POWER SUPPLY.
SO FAR I AM INTERESTED IN THE ICE CHARGER WITH A POWER SUPPLY AND THE CHECKPOINT BALANCER
OR THE ALL IN ONE UNIT THE E STATION BC 6 WHICH CAN ALSO PLUG INTO THE WALL.
NEED SOME DIRECTION PLEASE
THANKS
Fergup is offline   Reply With Quote
Old 10-27-2008, 09:23 AM   #2
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
http://www.nexusracing.com/product_i...oducts_id=1727
with
http://www.nexusracing.com/product_i...oducts_id=1728
combined total = $134.90
as compared to just $170 for just a ice charger and checkpoint balancer ( with out a power supply.)
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 10-27-2008, 09:45 AM   #3
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I use an Hyperion EOS 0606i AC/DC charger...it works well...simple and easy to use.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 10-27-2008, 11:03 AM   #4
94eg!'s Avatar
Trader Rating: 17 (100%+)
The Bantam E-station BC6 and Hyperion 0606i are very comprable. Both include a 50watt power supply which should be good for on-road 2S1P lipo batteries.
The Hyperion has a slight advantage in the 7.4v range because it has a max amperage of 6A, while the Bantam charger will only do 5A max. Either way thier max wattage is only 50A, so higher-voltage cells will charge at a lower amperage anyways...
My friend bought a Hyperion and says it gets quite hot, but works rather well. It's also nice that it includes a set of balance plugs, but they do not work with every type of battery. You would still have to get a balance tap for Trackpower/Orion packs...
The Bantam charger does offer a temp sensor as an option part...
94eg! is offline   Reply With Quote
Old 10-27-2008, 11:39 AM   #5
Thanks going hyperion
Old 10-27-2008, 11:43 AM   #6
take a quick look at the Venom AC/DC. It comes with all the adapters you will probably ever need as well as being multi chemistry, your LHS may have one in stock.
http://www3.towerhobbies.com/cgi-bin...&I=LXUAB8&P=ML
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 10-27-2008, 11:46 AM   #7
like that vewnom as well Comes down to $$$ now so thanks!!
Old 10-27-2008, 11:49 AM   #8
+1 for the 0606i, you get everything all in one unit.
Lazer Guy is offline   Reply With Quote
Old 10-27-2008, 12:52 PM   #9
TwoTone's Avatar
lol Ironically that's what I told you yo do on your last post, but you didn't want to spend that much.
One you add Power Supply and balancer cost into it, the Hyperion 606i is a great value and a very good charger.
TwoTone is offline   Reply With Quote
Old 10-27-2008, 12:52 PM   #10
TwoTone's Avatar
Once you add Power Supply and balancer cost into it, the Hyperion 606i is a great value and a very good charger.
