Old 09-27-2003, 10:56 AM   #1
highwayman's Avatar
Default Keyence Zero Extreme Programing
Hi guys, need some help on my keyence zero extreme ESC, i cant seem to find my manual on how to program it. i got a new radio and i have to program my ESC to my M8...
If you can also show me how to adjust the drive frequence, it'll be highly appreciated.
thanks...
Jason
highwayman is offline   Reply With Quote
Old 09-27-2003, 11:08 AM   #2
Try here.
Setting Suggestion Manual
Zero Series Manual
James Nguyen is offline   Reply With Quote
Old 09-27-2003, 11:23 AM   #3
highwayman's Avatar
Thanks James Nguyen...
was able to open the "settings suggestion manual" but not the zero series manual.
sorry, to put it into novak terminology, but as a stop gap measure, cause im racing in a few hours... is how do you set the throttle and brake for the ESC, cause with the GT7, all you have to do is to press the button upon start up and press the trottle for full gas, and full brake...
Old 09-27-2003, 11:28 AM   #4
highwayman's Avatar
printed the setting suggestions already...
... as far as i can discern, to program the esc, i have to press the center key for 4 seconds, then, press it again for full throttle, the the center button again for full brake? did i get it right?
thanks...
- jason
Old 09-27-2003, 11:59 AM   #5
-Turn on the speedo.
-Hit the center button.
-Should go into "set".
-Hold center button for 4 seconds or so.
-should say like "nutr", that is the neutral point.
-make sure the radio it at neutral throttle and hit the right button.
-it should now go to "drHP", thats the throttle high point.
-Hold the trigger at full throttle and hit the right button again.
-should now go to "brHP", thats the brake high point.
-Hold the trigger at full brake and hit the right button again.
-now you should be back at "set"
-hit the center button and you should be done and out of the setting mode.
Do you know how to adjust the settings for drive frequency and neutral width and drive power?
Old 09-27-2003, 04:21 PM   #6
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
james ur correct, jusy checked the manual, yep thats what ya do
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-28-2003, 10:30 AM   #7
highwayman's Avatar
Got the programming! thanks !!! ran it today on the XXXT
about the others, drive freq etc, haven't read thru settings suggestion manual...
whats the difference between the drive freq and the drive power?
Old 09-28-2003, 11:30 AM   #8
Drive power is how much power it initially gives the motor. drive freq is how the power feels. punchy or smooth.
Keyence Rapida Pro & Keyence Zero V Extreme for sale! SuperNaut R/C Items: For Sale/Trade 0 09-20-2007 09:12 AM
Keyence Rapida Pro & Keyence Zero V Extreme for sale! SuperNaut R/C Items: For Sale/Trade 8 09-16-2007 03:53 PM
Keyence Zero V Extreme sportracer Electric On-Road 0 02-25-2005 02:33 PM
Keyence V Zero Extreme True R/C Racing R/C Items: For Sale/Trade 2 02-21-2005 06:26 PM
Keyence Zero V Extreme ESC F/S or F/T JJ187RC R/C Items: For Sale/Trade 16 10-18-2003 11:02 PM
