Old 10-27-2008, 03:38 AM   #1
Default Comparison of different BL motors?
Hi,
I've searched but not found any comparison/tests of different the BL motors. I'm particularly interested in 5.5T and 17.5T as these two are legal here.
As we run limited wind-count classes its important to get the most powerful legal motor. I'm sure there are differences between LRP, SP, Novak, Hacker, Losi etc.
Is there a side-by-side comparison with real-life test number?
Its really strange that dyno-test or just actual real-life credible numbers are so hard to find or even don't exist. Maybe someone has tested many motor and has comparable numbers?
"Feels best" , "seems nice" , "Is great" , "Most people use it" etc really doesn't matter Numbers count!
lauri is offline   Reply With Quote
Old 10-28-2008, 11:59 AM   #2
No one has dyno-tested different brands of BL motors? No one has used some Power-Logger to get track-date about different brands of BL motors?
Old 10-28-2008, 12:24 PM   #3
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
No not really.
I think someone on the forum had some charts from a Robotrinc but I can't remember who or what brushless he tested.
But I'm not sure if bench test numbers will tell you which motor is better. I have found through my testing with 17.5's that each have a different feel but I could make each one just as fast depending on how I geared/timed/drove it. I'm sure the numbers would show something different with each...but which set of numbers would be correct? or show which one was best?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 10-28-2008, 12:43 PM   #4
Ahh here's that thread i was talking about...
http://www.rctech.net/forum/electric...brushless.html
Old 10-28-2008, 02:27 PM   #5
Thank you A LOT. That is just what I am talking about. Unfortunately guys have not been able to compare ESCs and motors side-by-side. With the dyno tests we could see how those super capacitors might help performance, how different ESCs handle different (same turn-count) motors. And of course - which ESC and motor gives the best overall/maximum performance.
This has been a positive news that we can use brushed motor dynos to compare brushless systems. Some of the figures themselves might not be 100% true, but comparing BL systems is possible.
Keep the info coming
Old 10-28-2008, 02:49 PM   #6
sportpak's Avatar
Trader Rating: 26 (100%+)
The best way to tell what you should run is see what other guys your racing against are running. See if they'll let you drive their stuff.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
lrp brushless esc raceblast Electric On-Road 840 04-02-2012 05:45 PM
10.5T motors aggregated informations - specifications and comparison lochness42 Electric On-Road 25 06-13-2009 10:14 AM
ROAR STOCK motors.... rule changes regarding BRUSHLESS Joel Lagace Electric On-Road 164 08-28-2007 09:07 PM
Anyone Tried 13.5 Sintered Against 19t? Skiddins Electric On-Road 23 08-12-2007 08:55 PM
Bonded & sinthered rotors MR JOLLY Electric On-Road 25 07-16-2007 01:36 PM
