Old 10-26-2008, 03:42 PM   #1
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Default Temp Gun Revelation!
I thought I would share something I came across while letting my mind wander on a trip back from racing.
I bought a PE1 temp gun about 3 years ago when I first started getting serious about electric on road racing. I used it all the time and it was always returned to its home in my pit box after use and sitting around all day on my table. I never really dropped it or abused it.
When I went to asphalt Nats with a buddy who also has a PE1 temp gun, we discovered our guns didn't give the same reading for the same motor at the same time. We solicited a third temp gun (I can't remember what brand) and found mine was 10 degrees under and my buddy's was 10 degrees over at 150 degrees. I was kinda bummed and just thought maybe I had finally wore mine out. We also found that they read correctly at room temperature, but the hotter the motor was the further off our readings became.
So last week I bought a new TGX1 temp gun. I have had the same gearing in my 12th scale for quite a while and was getting around 130 degrees after 8 minutes with my PE1. I temped it throughout the day with the new temp gun and like I expected I received very different readings. I had actually been closer to 150*.
When I read the instructions for the new temp gun it mentioned to make sure to keep the sensor area clean as it could affect the accuracy. This prompted me to look at the sensor area of my PE1. Sure enough it was covered in dust and lint and foam tire dust. I took a q-tip and gently dusted the sensor area off. I nuked a cup of water in the microwave for 1:30 and then temped it with with both guns at the same time at the same spot. They were within a degree of each other.
I can't help but wonder if any of the few motors I have smoked were due to an inaccurate temp reading.
Here's my guess as to a theory.
The guns we use are IR temp guns. I imagine the IR beam was partially reading the temp of the dust and debris on the lens cover thus bringing the temp down a few degrees. It works fine at room temp because the dust and debris is actually at room temp. The hotter you get the further the difference in temp between the motor and debris on the lens.
A bit of an A-Ha moment for me. : )
Old 10-26-2008, 03:44 PM   #2
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
A-ha!
very nice, i'll go clean mine now.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 10-26-2008, 05:28 PM   #3
RCSteve93's Avatar
I just bought my first temp gun today... a PE-1. I read the manual... Guess what... the manual recommends cleaning frequently with motor spray or alcohol and a Q-Tip.
RCSteve93 is offline   Reply With Quote
Old 10-26-2008, 05:35 PM   #4
snoopyrc's Avatar
Yeah but now you know it really matters.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 10-26-2008, 05:36 PM   #5
RCSteve93's Avatar
I trust the manual.
Old 10-26-2008, 05:43 PM   #6
snoopyrc's Avatar
Old 10-26-2008, 10:21 PM   #7
Mason's Avatar
DOH!
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 10-26-2008, 11:27 PM   #8
snoopyrc's Avatar
Its good to know you have something you can trust.
Old 10-27-2008, 04:07 AM   #9
Drifting101's Avatar
Originally Posted by RCSteve93 View Post
I trust the manual.
A manual whats that?
I also have a PE-1 my aswell clean mine too
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 09:46 AM
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 11:48 AM
Revelation Raceway Ron C. Racing Forum 5782 01-16-2013 08:13 AM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Is modified engine any better than stock one? Kevin Kim Nitro Off-Road 34 10-08-2007 01:53 AM
Crystal Park Racing - 20th AUG JAG Racing Nitro On-Road 132 10-04-2005 06:00 AM
